plus8917 plus8917 is offline
Car: e92 335i
Default Please help me with the Westgate measurement. - 09-25-2017, 05:51 AM
As shown below, I would like to know the exact size of the bushing or the outer diameter of the flap of the flap of the flap.
The dimensions that are identifiable in the picture are approximately 1.2 ㎜.
Attempting to insert a washer in place of free play to clear the 30 ff warning.
Please share the correct size or confirmation page.
I am Korean.
It may be hard, but please ask for the correct grammar.
NitroX5 NitroX5 is offline
Car: '07 E92 335i
Default 12-06-2017, 08:13 AM
I can only measure the stock shaft size if you want... If you up to order an aftermarket one from ebay it may has different dimensions.
It should have a little play to move freely anyway, be careful if you going to tight it up.
(advice:a little try to tighten the "coin" at the end of the flapper, it can make a lot of chatter noise especially at open exhaust)
'07 335i - JB4 FBO, FMIC, Milltek Exhaust, Walnut blasted, CC to atmosphere, Tial BOV & chargepipe, E40 mix | KW3,
poly bushings
Car: '07 E92 335i
Default 12-07-2017, 01:36 AM
Stock size: 11.3 / 11.4mm
It was really hard to measure, tried to do it on unworn area.
