335xiboost's Avatar
335xiboost 335xiboost is offline
Car: 2008 335xi jb+ VSRF ******* DP DCI cabin filter delete
Default Just installed MMP PI kit - 05-19-2017, 08:37 PM
Have all bolts ons possible MMP stage 3 turbos now installed the PI injector kit but am having some trouble downloading the software on the PI controller. Anyone have experience with the AIC6?
08 335xi FBO stage 3 hybrids PI MHD JB4 FOR SALE
08 335xi 6spd manual single project
07 Cayman 5sp
04 Gallardo gated 6spd
NA55 NA55 is offline
Default 05-20-2017, 07:46 AM
Doesn't the PI controller come pre flashed? Where did you buy it from? Maybe contact them for support?
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 05-20-2017, 09:26 AM
There are lots of threads on this forum you can look up regarding AIC6 setup.
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes, M5 Rear Suspension
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Trans Swap, MFactory SMFW, Spec Stg 3+ Clutch, UUC SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor
- JB4, Hexon RR550s, Custom Inlets, AR ***, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB Ext. PCV, BMS OCC
Car: 2010 535i
Default 05-20-2017, 03:53 PM
Default 05-20-2017, 05:00 PM
AIC6 is a total PITA to use... Part of the reason we no longer support it.
335xiboost's Avatar
Default 05-21-2017, 04:45 PM
Terry do you sell the JB4 compatible until standalone? It would make sense to have it pre loaded but I don't think it is...the MHD BEF for hybrid E85 PI is to be used along with the AIC6 correct?
07 Cayman 5sp
335xiboost's Avatar
Default 05-21-2017, 09:57 PM
I've been reading through everything I can on the site and I can't seem to get the software to connect so I can flash it. Would using the same cable I use for MHD BEF cause an issue? I get an error communicating with ECU every time so I can't even do anything with the software
07 Cayman 5sp
Dave @ Fuel-it!'s Avatar
Default 05-22-2017, 08:56 AM
The cable used to connect to the AIC6 is completely different from the dcan / OTG used to do the BEF.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
335xiboost's Avatar
Talking 05-22-2017, 05:14 PM
I found out its like the wire used to hook up the JB4 to a tablet but it needs all the prongs unlike the JB4 needing just 3. Car is a BEAST now will have it at the track soon gonna post some logs once I move it over 22psi that I'm running now in MAP 6...much smoother with the port doesn't seem to struggle at higher RPM like it did prior to PI.
07 Cayman 5sp
