(#1351)
a331200 a331200 is offline
Car: BMW 525Li 2014
Default 05-01-2017, 06:10 PM
For those with the 528 N20 who were not able to get the BC button working for map switching, I think we finally fixed that. Email me to get the firmware to test!
How to solve?
Herc Herc is offline
Car: F20 125i
Default 05-01-2017, 09:28 PM
You email at BMS and they will send you a new update that need to be uploaded from either the phone app or laptop
Chappieho Chappieho is offline
Car: F30
Default 05-03-2017, 02:15 AM
I have JB4 Bluetooth. How do I find the update firmware?
Car: F20 125i
Default 05-03-2017, 07:02 AM
Via the app go to settings choose read only. If you have an N20 and it says 13/3/5 you are updated. For B48 you need to check current and go to the B48 section and verify if there is a new one.
Car: F30
Default 05-03-2017, 07:46 AM
okay.Thank you so much
Car: F20 125i
Default 05-03-2017, 08:43 AM
You welcome
liveevil liveevil is offline
Car: F34 320i
Default 05-04-2017, 10:54 PM
If we're talking 320 then yes keep it on map5 at 17psi.. The guys who have problems with engine rods, etc, run 22psi+.
If it is an EWG N20 320i, would the map 1 be adding 4psi or targeting 21psi. Similarly for map 2. I am currently running map5 with ER catted ********.
Car: F20 125i
Default 05-04-2017, 11:18 PM
Dear liveevil:
Map 1: PWG models absolute target 21psi peak, EWG models additive 4psi peak over stock.
Map 2: PWG models absolute target 22psi peak, EWG models additive 6psi peak over stock.
the 20i i think is maxing at 13 and the 28i either 17 or 18 at stock cant recall the absolute stock values. Never the less follow Terrys recommendation.
Dear Terry regarding the rods is that for 20i only or for 28i as well?
Car: F34 320i
Default 05-05-2017, 11:33 PM
http://mywikimotors.com/bmw-n20/
According to link, 8psi for stock n20 20i and 17psi for stock n20 28i.
For an ewg 20i, is it 12psi (8+4) on map 1, 14psi on map 2 and up to 17psi on map 5?
I have workshops telling me to run map2, because it is punchier and more consistent, but Terry seems to suggest Map5
Car: F20 125i
Default 05-06-2017, 02:50 AM
I wouldnt trust wikimotors it has unreliable information. The best option for me is to make a run on map 4 and monitor maximum Psi. Nevertheless am sorry for the wrong info regarding the 20i.
Regarding what the workshops say i have one Q. How can a workshop has a better experience and opinion regarding a product from the creator and founder of it..... Bottom line however as we say in Greek = You are must hear out everyone's opinion but at the end of the day you must do what your guts or brain suggest and take sole responsibility in the case of an negative outcome.
Car: F34 320i
Default 05-06-2017, 04:54 AM
Thanks. I just want to know whether for ewg n20, whether it is absolute target of 21/22psi or +4/6psi.
I agree with your statement with what brain suggest, which is what I am trying to do...if absolute target, means map 2 will be punchier than 5 (but also more dangerous)
Car: F20 125i
Default 05-06-2017, 05:05 AM
+4 and +6 is straight forward. The info is found at the first page and Terrys post of this section
Most aggressive is map 7 regardless
Punchier does not mean better as well.
Jrod33084 Jrod33084 is offline
Car: 2013 328i M sport
Default 05-10-2017, 01:11 PM
I haven't been back on this thread in quite some time. I am just wondering if there has been any updates on the JB4 firmware attached files in the opening post? I've been running jb4 for the past year and just want to keep things updated. It has probably been that long since I've checked.
Car: F20 125i
Default 05-11-2017, 07:25 AM
13/3/5 is the latest firmware.
barfastic barfastic is offline
Car: BMW 228i
Default 05-19-2017, 06:19 AM
Is it me - or was there a firmware update? Is there a changelog?
cabeca_rj cabeca_rj is offline
Car: n20 pwg
Default 05-19-2017, 02:50 PM
hello
needing some help
have a n20 z4 PWG..i bought the jb4 obd2 pwg version
but my car has canbus,does any one has any mod solution ?
thanks
williammm williammm is offline
Car: BMW F30 328i
Default 05-19-2017, 08:42 PM
@ Terry,
I have a F10 N20 engine PWG. After installing JB4 (OBDII & BT Rev 3), i keep getting Drivetrain error during drive.
What could be the likely issue?
Car: F20 125i
Default 05-19-2017, 10:13 PM
I think so too or they just erased some... cant remember the hex file i had uploaded. probably we need to email them for verification
Car: BMW F30 328i
Default 05-20-2017, 09:27 AM
Originally Posted by williammm
@ Terry,
Below are the errors from Jb4 mobile:
120308 Boost pressure lower than expected
138701 Radiator shutter, top, upper stop: recognized too early
Car: F20 125i
Default 05-20-2017, 09:47 AM
You might need to post it at the support sub forum along with a log file so someone can assist you.
Car: F20 125i
Default 05-20-2017, 11:38 PM
I email BMS regarding the hex files that the member barfastic took notice of the change. They have change and they advise that we update to the newest version
Car: BMW 228i
Default 05-21-2017, 11:30 PM
Herc,
Did they mention what changed? if they added any features or temp sensor readings?
M
Car: F20 125i
Default 05-21-2017, 11:53 PM
No in all No temps change i test it a while ago
I posted on the support thread to advise us on significant changes but no answer yet
EDIT:
I found that my previous setting on my boost limiter altered to higher values
Also found my boost fail safety at 32.6 psi instead of 23
BMS please comment
Default 05-22-2017, 08:22 PM
Wow that seems way too high for the boost safety. Hopefully they give more details.
Car: F20 125i
Default 05-22-2017, 10:32 PM
well i hope it was a glitch. However having 4 values in total random numbers ie 32.6 as boost fail safety or 12.9 instead of 8 for my 1st gear boost limiter is rather strange
