Default 05-12-2017, 02:06 PM
I don't know. Only tested on our 550 and M5.
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
BurgerTuning.com
Car: F80 M3
Default 05-13-2017, 02:09 PM
Some photos of the prototype F10 stealth tank. So nice. Perfectly hidden under the trunk deck lid.
Car: 335i, 2009
Default 05-15-2017, 12:52 PM
This gets photo of the month for sure.. :D
335i E90 2009 ///M Sport Auto
Drivetrain--------ForgeStar F14 Wheels 18" (245 & 275 PSS) | Alpina Transmission Flash | Wavetrac LSD
X5 50i 2013 ///M Sport
Stock
Six Pot's Avatar
Six Pot Six Pot is offline
Default 05-15-2017, 07:48 PM
Take my money!
2011 BMW VO 1M | JB4 ISO | MHD | FuelIT Stage 1 | Spec Twin Disk | VSRF 335d CP w/ TiAL | AR D*P* | MMP Inlets | ETS IC | Slek Front Lip / Diffuser | Apex EC7 Wheels | KW HAS
Default 05-15-2017, 09:19 PM
Wow that's awesome, I didn't even know that was done!
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 05-17-2017, 10:22 AM
I need one really bad
F10 N63tu Frozen Grey with full OEM M5 conversion on prototype JB4+BCM+S2 turbos+F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
DLSJ5 DLSJ5 is offline
Car: E92 M3
Default 05-17-2017, 01:51 PM
BMS just keeps giving us what we want, great stuff Terry and his team!
16 F82 M4 ZCP - DCT - JB4 - Meth - 1/2 Mile 161MPH
08 E92 M3 - DCT - Built Motor - ESS VT3-750 SC
710 WHP/495 WTQ STD CF @ 14.4psi
6.1s 60-130MPH (Drag Strip)
174.12 MPH Shift-S3ctor Standing 1/2 Mile - E9X WR
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 05-19-2017, 11:43 AM
Not worried about having Meth next to battery?
-Tweaked CTS Turbo FMIC | Custom CTS Turbo D0wnP1pe | BM3 E30 - X4 M40i
- MY17 F80 ZCP | BM3 E30 | Pending: CTS Turbo D0wnP1pe/CP/HeatExchanger & Mid-pipe
$ECA $XRP $XLM $TRX $ADA[/B]
Default 05-19-2017, 12:13 PM
It's isolated in the tank and both are behind the crash bumper, so I don't foresee any issues with it.
M335's Avatar
Car: 2011 E90 335i
Default 06-13-2017, 08:12 PM
Terry, any updates on water/methanol tank?
Default 06-13-2017, 08:27 PM
We'll update the thread when we have them in stock!
Ant397 Ant397 is offline
Car: 2016 F10 M5 Comp, UK.
Default 06-19-2017, 10:08 PM
Is it worth holding off for this? I'm just about to place a WMI order from you for my F10 M5, how far off do you estimate? Or for the time being, which tank should I purchase for best fit in the F10 until it's available?? Is 20' of hose sufficient in the kit for the F10?
Default 06-20-2017, 08:16 AM
20' of hose is generally more than enough. If you are in a hurry get the 2g low profile tank and run that in the trunk against the rear seat. Then later if you want the F10 specific tank it's an easy swap. Just leave slack in your lines when installing.
Default 07-13-2017, 08:07 AM
Just got the first 6 tanks off the production line... Look and fit great.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 07-13-2017, 09:39 AM
Good work man, looks pretty clean.
Mods: Stock for now
Car: 335i, 2009
Default 07-13-2017, 11:12 AM
Best looking trunk setup yet. Looks like experience pays off!
Stock
Default 07-13-2017, 12:52 PM
Did test fitting on our development cars and all is good... We've got 4 tanks in stock, more on the way. They are priced at $229 and can be ordered here: http://www.burgertuning.com/meth.html
On the line routing there are two ways it can be placed but having tested each I think I prefer the longer feed loop. The tank includes two 90 degree fittings for the pump, pump mounting screws, and the compression fitting for the tank itself.
Lowon's Avatar
Car: Bmw M2
Default 07-13-2017, 02:20 PM
Is there any reason why you prefer the longer loop? Like performance wise that is.
Otherwise aesthetically Imo the shorter loop is much cleaner.
Mods: Stock for now
Default 07-13-2017, 02:24 PM
With the tank installed neither is visible. The short line is tricky due to the angles, so you could wind up kinking it if not done just right. Anyway it's at your discretion as an installer how you want to handle it.
Lowon's Avatar
Car: Bmw M2
Default 07-13-2017, 03:30 PM
I see.
Mods: Stock for now
Default 07-14-2017, 12:18 PM
So who is ready to test the tank out?
CJ2 CJ2 is offline
Car: 335i F30
Default 07-15-2017, 09:33 AM
I'm ready to test a tank! Let me know how to proceed!
2013 F10 M5 | PS2 | JB4+BCM | Bootmod3 | BMS Intake | BMS CP's | ER **'s | SSP Spec-R | Meth
10/15/16 Goodbye old friend - 2012 F30 335i | PURE stage 2 turbo | JB4 | BMS intake | ER down pipe | ER charge pipe | ER FMIC | E60 | Meth
Default 07-15-2017, 09:36 AM
They are on our website for sale.
CJ2 CJ2 is offline
Car: 335i F30
Itchy trigger finger.. Looks like they're available on the website
M335's Avatar
Car: 2011 E90 335i
Default 12-28-2017, 02:44 PM
Terry do you have any pictures with installation wmi on m5/550i?
