Default F Series N55 PWG ISO Firmware and Details - 05-30-2017, 10:28 AM
We'll use this thread for official updates, directions, and documentation for the F series PWG N55 ISO firmware. Generally 2013 335i models and other F series PWG vehicles like the 2010-2013 F10, and some M135 and M235 models.
This BETA firmware and related JB4 board modification is suggested for F series PWG vehicles running larger than stock turbos, or those running stock turbos, who like to experiment.
Setup notes:
1) After cutting diode and loading firmware adjust PID Gain to 25, and auto shift reduction to 60, as starting points.
2) RPM FF gain is disabled in this firmware so you'll need to manually enter a
dutybias profile to match your turbocharger.
Starting point for factory/stock turbo:
Starting point for hybrid turbo:
3) JB4 maps are generally the same as F series integrated firmware. FutureUseD settings are as follows:
Firmware Notes:
ISO_10:
1) Added logic to autotune duty bias by RPM.
2) Update to prevent startup sweep coming up randomly.
3) Fixed speedo calibration for in dash menu system.
4) Added option 2/2 for boost on fuel & meth on speedo ring.
5) Adjusted some of the PID tables to try to stabilize boost. More changes probably needed here.
ISO_9:
1) Redesigned logging engine for much faster sampling of all CANbus channels. Normal speed logging is around 10hz for all CANbus channels now, and slow speed logging remains an option for cars with older software and drops sampling down to around 6hz.
2) Removed FUD.5 option. Logging is always full time active now if JB4 is enabled.
ISO_7_T12:
1) Updated port injection mapping, fuel enrichment values of 0 now disable port injection all together.
ISO_7_T3:
1) Mapped FutureUseD bit4 so that a value of 0 prevents JB4 from targeting below the factory boost target (default setting for those running a factory back end flash map), and a value of 1 allows the JB4 to target independently of the flash boost boost target (useful for back end flash maps with higher targets).
*F Series PWG ISO:
FUD:
bit0 - Disable in dash BC button controls
bit1 - Alternative in dash BC F10 compatibility mode
bit2 - Unused
bit3 - Disable wastegate/FF adaption learning for diagnostic purposes
bit4 - Allow JB4 boost target to drop below below flash boost target
bit5 - Turn on CANbus logging full time
bit6 - Unused
bit7 - Slow down CANbus sample rate - required for some vehicles with older software
FutureUseA: 0-50 offset target between DME_BT and ECU_PSI under full load. A setting of 0 runs the default value of
30. Lower values will result in ECU_PSI closer to DME_BT with more throttle movement, and higher values ECU_PSI
further way from DME_BT with less throttle movement.
6 Cyl Timing: Remapped to represent gas pedal aggressiveness. A value of 0 being the least aggressive and a value of 50 the most aggressive setting.
To run this firmware the following modification is required to the JB4 board to remove/disconnect its boost solenoid diode:
Default 05-30-2017, 10:29 AM
Note previous discussion on this subject was posted here: http://www.n54tech.com/forums/showthread.php?t=46430
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 05-31-2017, 01:39 AM
good job terry
If I want to select several options in FUD
How to do it?
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
cnm135i cnm135i is offline
Car: m135i
Default 05-31-2017, 11:27 PM
Originally Posted by dror135
good job terry
How to do it?
You will need a laptop to set the bit. JB4 Mobil app doesn't support this (at least my Android doesn't).
Default 05-31-2017, 10:43 AM
You click FutureUseD and there are yes/no prompts.
dror135's Avatar
Default 05-31-2017, 11:33 AM
hi terry i was with ISO 6
on iSO 7
still ff learning ( FUD set 5 )
why ?
Sanesh21's Avatar
Sanesh21 Sanesh21 is offline
Car: 2013 F21 M135i MT
Default 05-31-2017, 11:56 AM
Thanks for creating this thread Terry
2013 F21 M135i 6MT
JB4 / PWG / BMS intake / BMS meth kit / FSB / ER CP / Down Pipe / VTT stg1 / Pure inlet / GFB DV+ / AFE air scoop / N20 Tmap / Rev3 Connect / M performance exhaust / ACS springs / H&R Trak spacers / M Performance V2 steering
dror135's Avatar
Default 06-01-2017, 01:02 AM
thx i know thats
but on laptop There is no option "Turn on CANbus logging full time"
these the wizard of bits on the PC
bit1: disable waesgate adaption
bit2: use water temp intead of oil temp .......
bit3:disable fuel open loop learning
bit4:enable meth input algorithm ......
bit5:show bank2 fuel trims undder timing AVG
bit6:disable ff rpm gain
bit7:use alternative anti rattle wastegate positioning
thx
F30_SixSpeed F30_SixSpeed is offline
Car: 335i M Sport
Default 06-01-2017, 08:34 AM
This is great to see. What is the main benefit of using this firmware... better boost control for PWG turbo cars? Terry - do you think there is a benefit using this with maxed out stock turbo setup?
2013 335i 6MT | FBO | JB4 w/ Bluetooth | e40 | 400whp/473wtrq
jaaf jaaf is offline
Car: 12' F30 335i
Default 06-01-2017, 09:26 AM
So I've been having boost issues within the past few weeks. I was gradually losing boost which caused "boost level below expected" codes. So I went ahead and did this mod and downloaded the firmware to see if anything would change.. Now I have less than 3psi throughout the RPM range lol. Once I take the jb4 off, the car drives fine again. At first I thought I was losing boost from a mechanical leak such as the chargepipe or diverted valve. But now I'm leaning more towards the jb4. Possibly my settings within the Bluetooth app?someone help, I'd love to have full power before bimmerfest this weekend lol. My pwg f30 is fbo btw.
Car: 2013 535i (N55 F10)
Default 06-01-2017, 09:39 AM
Feature Request - As discussed in email with you and Steve, the ability to read "E" Content from physical sensor as DutyCycle on this firmware for those running PI and "E" Sensor.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1995 e36 M3 - Future Track Car
Default 06-01-2017, 10:04 AM
Yes, I'll start adding the logic to this firmware.
For those with boost problems send in logs so we can work on it. At some point I'd like to retire the F series PWG integrated firmware.
Car: 12' F30 335i
Default 06-01-2017, 11:08 AM
Sorry for the ignorance but I've never sent logs.. I'm guessing WOT 3rd and 4th, gear map 4?
MrDave MrDave is offline
Car: n55 335i
Default 06-01-2017, 11:15 AM
Im having issues with my recent jb4 install (by performance centre sunderland) i will get a log tomorrow and send it over im really hoping you can shed some light.
this is the graph from map6, as you can see its not great.
Default 06-01-2017, 01:20 PM
Unless you loaded the BETA F series ISO firmware it has nothing to do with this thread. Post the JB4 logs and info in the support forum for tuning help.
Car: 12' F30 335i
Default 06-01-2017, 01:17 PM
ok so I just downloaded the newest ISO 7 (T3) and the car finally builds some boost again but it's still nowhere near what it was pushing before. Who/where do I send logs to?
This thread is fine for now just to keep the F series ISO logs in one place. Later, we'll go back to normal support forum only log rules.
Car: 12' F30 335i
Default 06-01-2017, 02:07 PM
Here's my first log.. let me know if I did anything wrong.
Default 06-01-2017, 02:51 PM
I wonder if you have a boost leak going on? In any event change FF to 120 to speed up adaption and do another similar log.
Car: 12' F30 335i
Default 06-01-2017, 03:04 PM
Will do. I checked and double checked the intercooler connections and chargepipe . Ddnt find anything loose.
Car: 12' F30 335i
Default 06-01-2017, 03:32 PM
Ok here is it with 120 FF:
Car: m135i
Default 06-01-2017, 11:45 PM
You'll need to do a proper leak test. Add pressure to the intake tube and listen for leaks. Also when doing logs then do a pull from 2000 to 6500rpm in 4th gear - remember DSC OFF.
Car: 12' F30 335i
Default 06-02-2017, 11:06 AM
I'll try to get that done asap, thank you!
And Terry, thank you again!
911Y4's Avatar
911Y4 911Y4 is offline
Car: 435
Thumbs up ISO 7 T3 Log (E45, 20psi flat, stock FMIC, FBO) - 06-02-2017, 11:16 PM
Good morning Terry,
Here is my log of ISO 7 T3 (E45+dual cm5 meth 50/50, FBO+stock FMIC, 4th to 5th gear 20psi flat target, BEF)
Overall, the ISO 7 is almost perfect, with boost aggressieness index set to 45, the car had no more lag. Here is just some minor issue:
1. Small overboost at tip-in
2. timing dip at tip in
*3. fuel trim sometimes is stuck at value of 25, regardless of pedal input and boost variation, also AFR went very high.
Thank you very much in advance for your further instruction!
Best,
Li Wang
BMW F30 335xi PWG N55 1/4mile 11.111ET @ 126mph
BMS JB4 ISO / PTF Bootmod3 / Pure N55 stg2 Turbo / Fuel-it PI + stg2 LPFP/ Wagner EVO 2 Competition FMIC / E30 + Meth
In Shanghai
Car: m135i
Default 06-04-2017, 07:35 PM
Originally Posted by 911Y4
Good morning Terry,
Best,
Li Wang
Seeing AFR like this scare the **** out of me!!!
Terry
Is the AFR safety not working or can nothing be done with trims stuck? Is it an O2 sensor failure causing open-loop? I experienced something similar back in November last year and changed my O2 sensor on your recommendation. Back then you also made a custom FW with "trims 25" protection for me, but I was not able to fully validate if it worked or not. I also still see short periods of "trims 25" in my logs from time to time.
November with ISO_4:
neejay
