(#4301)
dh58 dh58 is offline
Default 08-23-2017, 03:07 AM
Originally Posted by Dmac @ BMS/DMD
Are you running out of space on the device? For Android just use ES File Explorer (JB4 Mobile Data folder).
iOS:
Open iTunes on Computer ->
Connect Device ->
Select Device ->
Select Apps ->
Scroll To Bottom ->
Select JB4 Mobile ->
Select your log files and save them.
Nope, have over 100GB free. I'm on iOS and thank you for this! Will try it out
PHAILUR PHAILUR is offline
Car: 335i n54
Default 09-01-2017, 10:44 AM
Hey Donnie,.
I just ordered
-Anti-Lag
-T-map
-2 step
Anything you have that might assist with those installs would be greatly appreciated!
Any walk through videos or any additional files that need to be uploaded?
'09 e92 jet black 6sMT
VRSF ** • VRSF Charge pipe• VRSF 7.5" intercooler• VRSF2" inlets• VRSF DCI•aFe intake scoops•HKS BOV•RB pcv valve•BMS Jb4 g5 w/ Bluetooth •BMS Oil catch can•BMS Clutch valve•NGK plugs•Bosch coils• 450lph Walbro for e85•Master Clutch lightened flywheel-ACT 6 puck clutch•turbo back straight pipe w/ all deleted
bayly135imSport bayly135imSport is offline
Car: BMW 135i
Default 09-02-2017, 08:09 AM
so I can't download the OSX interface I click the link and it says this drop box file has not been found or has been made private
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 09-02-2017, 09:02 AM
Hey Donnie. My Connect Kit just stopped connecting today for no known reason. It just says "No Network/No Server". I checked everything and all looks normal as it was installed a couple months ago. Any ideas??
Nick
2009 E82 135i: M6 / Alpine White / M-Sport / MHD Stage 1 / Performance Exhaust / Blackline Tails / CDV Mod / BMS PCV / Gloss Black Grilles
DCI's and exhaust things going on soon!!
Car: 2015 F22 M235i
Default 09-03-2017, 05:48 AM
Nick
Disregard. It's working now. I think the Connect Kit Server was down for a bit. Not sure how that effects the Connect Kit...:
Nick
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 09-03-2017, 11:59 AM
Originally Posted by PHAILUR
Hey Donnie,.
I just ordered
-Anti-Lag
-T-map
-2 step
I don't have anything, but I'm sure someone can help you. Make a post in the support section.
Fixed. Dropbox made some changes to their file permissions recently.
Nick
Could have just had a weak connection. Glad it's working now.
shoepac11's Avatar
shoepac11 shoepac11 is offline
Car: 2008 335i E90
Default 09-04-2017, 08:33 AM
Updated firmware this morning, now meth won't work and boost is low. Any ideas?
Disregard.. problem solved.
2008 e90 6mt
FBO/BMS meth
RB turbos
RB inlets
G5 iso
back end flash
fuel-it stg 2
cnm135i cnm135i is offline
Car: m135i
Default 09-04-2017, 07:58 PM
Hi
The app will not accept "0" as a value and crashes if I eg try to leave it blank and save?! Will only save a value of 1... I am 100% sure I have not written "0-space" by mistake and only changed this parameter.
I'll try with the PC later.
Huawei Nova, Android 7, ISO 7_T6 FW
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Car: 2008 135i
Default 09-05-2017, 11:36 AM
Originally Posted by cnm135i
Hi
1) Don't leave it blank. It has to have a value in it.
2) That's not the value that is incorrect as 0 is a perfectly valid input. Take screenshots of your full user settings before you try to save them then email me. support@jb4connectkit.com
Car: m135i
Default 09-06-2017, 06:56 PM
Hi Donnie
I found that the Boost Failsafe max Value had changed to 25 so my previous value of 28 was causing the issue. All good now
Possioble to have the APP tell which value is unacceptable?
PS: Thanks a bunch for implementing the "double-tap" map change! I LOVE IT
kennis827 kennis827 is offline
Car: bmw m6 f13 cp 2014
Default 09-13-2017, 09:38 AM
hey Dmac,
how can i remove permanently the catles detected code in the jb4 mobile app, my car m6 is outside of US now, using jb4 beta for m6 f13, thank you!! It shows like every 5minutes
Bullitt1841's Avatar
Default 09-13-2017, 09:47 AM
Originally Posted by kennis827
hey Dmac,
Contact Donnie or BMS via email directly.
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Default 09-13-2017, 10:16 AM
thank you! hey do you have donnie's email?
CedarPerformance CedarPerformance is offline
Car: All of 'em
Default 09-13-2017, 11:15 AM
hey Dmac,
You can only auto-clear, you cannot remove the code completely with the jb4.
Default 09-13-2017, 11:47 AM
It's in the first post and also 4 posts above yours.
jb4connectkit+support@gmail.com
rygre rygre is offline
Car: 2016 340i
Default 09-13-2017, 04:32 PM
Anyone have any idea idea about this?
Device: S8+
OS: 7.0 android
Engine type: b58
App build: not sure where to find this
Kit Revision: Rev 3
JB4 Firmware Version: new, I assume 8
Problem experienced: says kit not owned, see attached screen shot
Car: 2008 135i
Default 09-13-2017, 09:42 PM
Hi Donnie
I'll check it out. Glad you got it figured out.
Device: S8+
OS: 7.0 android
Engine type: b58
Kit Revision: Rev 3
Resolved.
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 09-15-2017, 08:53 AM
Resolved.
I'm getting the same message, I emailed you about it
Car: 2011 E90 335i
Default 09-15-2017, 11:12 AM
Sent you a PM
Car: 2011 E90 335i
Default 09-15-2017, 12:20 PM
Works now thanks bro
phoebee phoebee is offline
Car: 428i
Default 09-15-2017, 10:13 PM
F32 428i 2014+ n26 93octane jb4 on iphone.
when gauge light tone down on jb4mobile?
I saw changing tone(green→dark green) gauge IAT.
maybe higher than 50℃??
Car: 2008 135i
Default 09-16-2017, 10:13 PM
I don't understand your question.
*App Update:
iOS beta is now live. Let me know how the new beta works for you all with the new JB4 firmware update (MPH output, etc.).
ganque ganque is offline
Car: 2013 135i M Sport
Default 09-16-2017, 10:19 PM
Hi Dmac! Have you thought on adding sound alarm warnings for situations like lean AFRs, overboost condition, low/max fuel trims, oil temp, or meth safety?
It'll be awesome to get auditive alarms under any of those conditions.
Slammin Slammin is offline
Car: 2013 535 M-Sport
Default 09-16-2017, 11:07 PM
Wow, awesome suggestion!!!!
2013 535 M-Sport, JB4, BMS intake
Car: 2008 135i
Default 09-20-2017, 11:47 AM
Already had it functional in iOS for a few months, but need to get around to polishing it at some point.
Update:
Expecting Android beta out today.
**IF YOU HAVE ANY ISSUES OR BUG REPORTS PLEASE POST HERE OR EMAIL ME (support@jb4connectkit.com).**
