(#376)
cnm135i cnm135i is offline
Car: m135i
Default 09-28-2017, 11:24 PM
Like to elaborate on Sicmadek's explanation...
There are no "normal" WGDC values. The WGDC is a measure for how much air (boost) you demand from the turbo. Small turbo at 5000rpm/15psi might run 80% WGDC and a bigger turbo 50%. What you usually can see from your WGDC is whether you have a boostleak as this would require higher WGDC than normal. So yes it depend on your boost target and ambient temperature mostly.
M135i, PWG, Pure Stg2, bootmod3 + JB4
Car: m135i
Default 09-29-2017, 08:28 PM
Check this out guys! Soon there will be progressive meth control for the ISO-brothers also
http://www.n54tech.com/forums/showth...381#post561381
jaaf jaaf is offline
Car: 12' F30 335i
Default 10-07-2017, 12:27 PM
Hey guys so I've been ISO for a while now and the car has been so sporadic about the way it's drives. I'm constantly getting the "boost pressure lower than expected" code in addition to an occasional hick up around 1500-3000rpm. I feel like the boost comes on much later than before I did this mod. Screen shots and logs attached.
Default 10-07-2017, 12:28 PM
Looks like a boost leak given the high WGDC relative to boost pressure.
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 10-07-2017, 01:05 PM
Fol is only 30, why?
2013 335i sportline pwg 8at~jb4 iso~e40~bms oil cooler valve~bms intake~wagner c-less~ap catback~phoenix ic~gfb dv+~pure inlet pipe~er tic pipe~vrsf cp~ngk's @ .022~h&r super sports~437m
Car: 12' F30 335i
Default 10-07-2017, 02:11 PM
I thought I did a good job of checking for leaks but I guess it's possible I missed something.
Car: 12' F30 335i
Default 10-07-2017, 02:12 PM
Lol idk, what should it be at??
neejay neejay is offline
Car: 2011 535i M-Sport
Default 10-07-2017, 02:36 PM
Weird how we have/had the EXACT same issues. Apparently the goal is to migrate everyone onto the ISO file... But I think I'll be soldering back to the normal one temporarily.
2011 535i M-Sport - JB4, ER Chargepipe, BMS Intake, Megan Supremo Exhaust
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 10-07-2017, 02:39 PM
set 6-cyl timing logging to 25, It takes 0 to 50 values.
should solve your issue.
PureTurbo N55
Car: 12' F30 335i
Default 10-07-2017, 02:48 PM
Didn't work for me
Default 10-07-2017, 02:55 PM
I'll try it shortly here (my current "6-cyl timing logging/pedal aggressiveness" is currently at 20)
Car: m135i
Default 10-07-2017, 05:10 PM
For the hiccups - try to disconnect the MAF - this resolved all hiccup related/cold driving issues for me
Default 10-07-2017, 07:59 PM
Run whatever you'd like, but all future firmware updates will be in an ISO format. So if something isn't working right capture it in a log, etc, to diagnose. It's working well enough for hundreds of people that whatever isn't working for you, its something with your specific setup that can probably be easily addressed.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 10-07-2017, 08:50 PM
When i disconnect my MAF i get constant Drivetrain Malfunction and i can't figure out why.
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 Map 7/50:50 E85 & 93 octane/Custom tuned exhaust/stock turbo
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 10-08-2017, 04:36 AM
Didn't work for me
Before cyl6 timing loggin or in other means pedal aggressiveness
I had the low boost error. But after using it i never had that error
Fyi i set it to 45.(purestage2)
PureTurbo N55
E36graduate E36graduate is offline
Car: 335xi Sport
Default 10-11-2017, 06:45 AM
ISO firmware + Rev3 = FUD bits not the same as sticky? Example: bit 7 was supposed to be for slow canbus but REV3 FUD bit 7 is alternative anti rattle waste gate positioning??
Assume Rev3 is incorrect?
Default 10-11-2017, 08:21 AM
I doubt REV3 has the right bit names programmed for F PWG ISO firmware. Use bit descriptions in first post.
Car: 335xi Sport
Default 10-11-2017, 08:29 AM
Thanks T - I did and car woke up very, very nicely!!!
Default 10-13-2017, 10:42 AM
Yeah, no doubt it's on my end 100%, I'm not blaming anyone else. I just need to make the time. I'll be posting another log(s) today/this weekend. I won't quit just yet!
Thanks, this simple change is working better. I had to dial it back to 40 though. I got a "too much boost" error code with 45 lol. It's been great on 40 though.
Default 10-13-2017, 12:16 PM
How exactly does the pedal aggressiveness effect boost?
Default 10-13-2017, 12:18 PM
Just raise your boost limit and use 45 lol
Car: 335xi Sport
Default 10-13-2017, 02:14 PM
Any settings to provide more throttle response? Seems like a bit of lag with ISO and my PWG n55........boost takes a second to hit and then hits all at once....
Default 10-13-2017, 02:33 PM
Best if you post a log and a screen shot of your user settings
