(#476)
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-18-2017, 04:59 PM
Originally Posted by UnderPressure
I flashed back to stock, I can't find an option to flash to V1.1 or 1.2 last file flashed says unknown OTS map. Where do I find the older maps. I'm going to drive the car tonight on the stock map if it doesn't rain tonight.
When you go to flash, I believe it allows you to select which version you want to flash. Haven't tried to flash back to older maps since I installed but I have read that others have. It would be best to contact Clemens and let him know of the problem so they can resolve it quicker.
VTT Stage 2+ | JB4 G5 w/ Trebila BEF | Fuel-It Stage 3 | XHP Stage 3 | VTT Inlets | MMP Outlets | BMS Meth Dual 10/5CM | VRSF 7" FMIC | VRSF **'s | BMS CP | BMS DCI | Turbosmart Dual Port | 3.5 TMAP | BMS OCC | VTT PVC | BMS Anti-Lag | NGK 5992 | M3 Rear Upper Controls And Godspeed TB's | Lock-Down Brace | 235/285-18 PSS
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 09-18-2017, 05:45 PM
I've been on Stage 3 v1.3 for a few months and updated to v1.4 on Saturday. It was my (mis)understanding that we're supposed to leave it in D mode and drive gently with lots of coasting for ~50 miles before trying out S mode. This helps to ensure proper adaptations.
2008 E90 335xi AT 63K MILES
MHD CUSTOM 93 OCT 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, FORGE DV BLUE SPRINGS, BMS DCI, BMS T-STAT DELETE, BMS OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS
PR IGNITION - COMING SOON!
UnderPressure's Avatar
UnderPressure UnderPressure is offline
Car: BMW 535i
Default 09-18-2017, 07:54 PM
With the stock map no codes and no problems , I never saw an option to flash to an older version just V1.4 . And I forgot I had to drive easy in D mode for 50 Miles, but could that cause the problem. I'm wondering if this is a 5 series issue I also have had that slight shutter at 1500 to 2000 RPMs I think I was going from 2nd to 3rd gear. I just read about that several posts back.
2010 535i xdrive M Sport , JB4 G5 ISO / BMS pump Flash / xHP stg. 3 TCU flash / BMS DCI /ER charge pipe ,ER FMIC / RB PCV valve/, 30% E85
Car: 07 BMW 335i
Default 09-18-2017, 07:59 PM
That might have been the issue. Maybe there was excessive slip or something else that cause the code because it wasn't fully adapted. I would suggest reinstalling v1.4 and just take it easy for a little bit. If after it's adapted and you throw the code again, then you should post or reach out to Clemens to work out the bug.
Car: BMW 535i
Default 09-18-2017, 08:29 PM
Okay thanks, maybe I'll flash 1.4 again and let it adapt . Looks like this wasn't just an update they re wrote the hole map so it does require adaption. I still can't figure out how to flash back to a previous version.
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 09-19-2017, 12:26 AM
Sorry, guys. Problem is already fixed. Please re-download (in the Misc Menu) and reflash.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
Jeffman's Avatar
Car: 335xi
Default 09-19-2017, 03:41 AM
So just to be clear, everyone who downloaded Stage 3 v1.4 prior to today needs to re-download and reflash?
Thank you.
RayBan81's Avatar
Car: 335i E91
Default 09-19-2017, 08:38 AM
Thank you.
Yes.
Car: 2008 E93
Default 09-19-2017, 11:05 AM
So from 1.3 to 1.4 we need to let it adapt b4 WOT ?
Car: 2008 E93
Default 09-19-2017, 02:09 PM
Nvm...just flashed V 1.4
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 09-21-2017, 11:56 AM
so for someone with the Aplina flash already, what benefits does this flash offer that? is drive mode any different?
my transmission didnt shift as i hit redline the other day, and went into limp mode with a transmission error message on the idrive. I'm wondering if this could help with whatever is going on with my transmission slipping..
2009 335i e92 n54 | FBO | JB4 | e85 flash |
RayBan81's Avatar
Car: 335i E91
Default 09-22-2017, 09:57 AM
It's different everywhere.
I'm probably the false one, as I'm biased, but just look in the app-store or facebook reviews. You will find plenty of comments on xHP vs. Alpina.
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default custom map file - 09-23-2017, 02:31 PM
i am trying to put a custom map in but says if i remember correctly to put in custom tunes but i have found no place to do that. where is it located??
09 conv mhd v7 tune xhp stage 3 bms intake ***
255/19 front 275/ 19 rear e85
RayBan81's Avatar
Car: 335i E91
Default 09-25-2017, 04:41 AM
It's in the xHP Flashtool folder on the device. Use a file browser to navigate there.
rays 335i's Avatar
Car: 07 335 coupe
Default 09-25-2017, 02:15 PM
can you give me a screen shot or step by step where its at .....i have opened i think everything
RayBan81's Avatar
Car: 335i E91
Default 09-26-2017, 03:29 AM
No, because that is different, depending on your phone. Copying files is a generic thing...that has nothing to do with xHP.
Maybe download an app like "File Commander" if you don't have a file browser on your phone yet.
