itzZshaan itzZshaan is offline
Car: F10 535i M-Sport
Default F10 535i Codes & Logs Review Please - 07-17-2017, 11:33 AM
Ran map 1 with the BMS intake and sprint booster for a few months on an e30 blend with no issues. Just installed a ******* ******** (for offroad use only of course) and MPE and switched to Map 2, did not touch the JB4 and was under the hood only to unplug and replug the O2 sensor wires. After about 20 miles of driving, I've had the following codes come up (also see attached). Car still drives like normal and the two logs attached are from before the codes popped up.
I understand I need to change the setting on my OBD II in dash menu 4 to "delete fault codes" to get rid of the CEL but before doing that I want to make sure that these codes are related to the ******* ******** or if I may have other issues?
I'd also like opinions on the logs with Map 2 on e30 blends.
Running N55_FSERIES_OBDII_PWG_11_T1 including FF connection and BT connect kit. FUA = 51 and FUD = 130 with only bit 1 and bit 7 enabled. No other changes to settings. Please let me know if you need any other info and thank in advance for any help!
Codes:
121002 MAP sensor, short to ground
119001 Rail sensor short circuit +
104402 MAP sensor short circuit -
102001 Air mass, plausibility -- Tuner code, ignore
101F01 Throttle valve opening angle pressure -- Ignore, tuner code
122108 BOV plausability -- Ignore, tuner code
213601 power management, closed-circuit protection: closed-circuit current violation
0000F1 No Description Found
Default 07-17-2017, 06:49 PM
Update - I changed menu 4 to delete fault codes and drove about 20 mins no problem. Re-read the codes from the app and only showed the following:
180001 ******* ******** detected
Needless to say no CEL on the dash as well which is nice, but still wondering if the codes thrown above were directly related to the **? I checked my MAP sensor and all looked fine. Thoughts...?
Default 07-17-2017, 07:01 PM
I'd see if those return. If so, you'll need to verify your JB4 connections.
Where are you getting power for the JB4 from and where do you have power for the JB4 mobile connect kit installed?
Default 07-17-2017, 08:40 PM
I'll definitely keep on eye on the codes, but just to confirm, I will no longer see the CEL pop up on the dash, correct? I'll just have to read codes from the mobile app every now and then to see what it's pulling?
As for the power connection, I have the jb4 powered by connecting to the 10mm nut under the black plastic cap per the instructions. However, I may switch the source to the thick red wire in the harness using a posi-tap per this post: http://www.n54tech.com/forums/showpo...33&postcount=4
And the mobile connect kit is powered by the red wire in the harness using the supplied posi-tap. Also FYI I've had the JB4 installed for about 275 miles running Map 1 before the codes from the first post came up this morning after installing the ** 2 day/50 miles ago.
Default 07-18-2017, 09:04 AM
Okay, keep an eye out and see if the codes return. I'd definitely recommend changing the power to the switched source.
Default 07-18-2017, 09:24 AM
Yup, just waiting for my posi-taps to come in on Thursday and will be switching to the switched source asap.
Also I meant to update this as soon as I got in the office but got tied up. The CEL popped up again on the dash on the drive in this morning and the additional code is:
122108 BOV plausibility -- Ignore, tuner code.
I wanted to include this here to keep track of the history but this isn't one of the original faults you want me to keep an eye out for right (I assume no since it says ignore)?
Did you have a chance to take a look at the logs btw? I'll see if I can get a couple more tonight but since the sample rate is slow, there aren't too many data points to review (but it may be enough for your professional opinion ).
2013 F10 535i M Sport - JB4, BMS Intake, VRSF D.P., SprintBooster v2, M Performance Exhaust, E30 fuel
Default 07-18-2017, 09:26 AM
Correct...that is normal and can be ignored.
You'll need to resolve this issue and do better logs.
Default 07-18-2017, 10:04 AM
Better logs coming soon! But to make sure I can get the most data possible, I will turn off "bit7 - Slow down CANbus sample rate - required for some vehicles with older software" unles you suggest otherwise. For some reason I thought this might help, but I think I got it confused with the EWG v11 update below, which I'm hoping was also an update for the PWG v11 firmware.
"By default cyl1 and cyl5 only are logged to speed up sample rate. Other cylinders are loggable via a FUD bit 6."
Default 07-18-2017, 07:47 PM
Alright did a few 3rd gear pulls 2k-7k rpm but something's off since the logs aren't picking up rpm and a lot of the parameters are static. Also I saw peak boost on the app at around 16 psi after each pull, but I'm not seeing that in the logs. Not sure if its a mobile app or BTMK or jb4 issue.
The last log is me just going through the gears at partial throttle which felt a lot better than the 3rd gear pulls. The 3rd gear WOT pulls didn't feel too great, like building boost, a surge of boost for a sec, then falling off again. I may try Map 5 tomorrow morning to see if I feel any difference and if I'm actually able to get logs with rpm, afr, etc.
Default 07-18-2017, 08:45 PM
Nothing useful there.
What happens if you enable bit 7 and set FUA to 0?
Default 07-19-2017, 08:24 AM
Enabled bit 7 and set FUA to 0 and did three 3rd gear pulls... first two seem better, with the second pull capturing the most data. Don't know what's up with the third one.
Also the CEL keeps popping back up even after I enable menu 4. Should I not delete the codes from the app to keep the light off?
Default 07-19-2017, 10:50 AM
That looks a lot better and the logs look normal.
For menu 4, see this update...
http://www.n54tech.com/forums/showthread.php?t=47748
Default 07-19-2017, 11:32 AM
Ah, I missed that one.. it should be stickied!
Anyways thanks for reviewing the logs. Happy hear they're normal but any chance I can play with more than 14-16 psi of boost? Maybe try Map 5 or 7 or increase boost safety?
Default 07-20-2017, 10:22 AM
You can certainly play with map 5 but we'll have to see what the logs look like on map 7. On E30 you should be okay as the stock turbo runs out of steam pretty quickly so boost drops off dramatically.
Default 07-22-2017, 08:38 PM
Map 7 logs for your review sir. The logs don't show it, but my peak boost after as shown in the app was 19.7 psi (but not sure if I hit that peak in the first or second pull). Car felt pretty good... your thoughts?
Default 07-23-2017, 09:39 PM
19.7 is probably a boost spike at shift.
Map 7 log looks okay. I'd raise FOL to 70 and add another gallon of E85.
Default 07-26-2017, 09:10 AM
FOL set to 70 and added a gallon of e85 (7 gallons total) with the rest 93 when I filled up last night. I did a 3rd gear pull but forgot to put it in sport + so the log is in comfort. Didn't get a chance to do another pull but will try again on my way home tonight. I've also included a cruise log after the fill up in case it helps. Will report back again tonight.
Default 07-26-2017, 06:11 PM
Log isn't at WOT so it doesn't really offer up much info on stock boost.
FUD should be set to 2 for the 535i as well.
Default 07-29-2017, 10:13 AM
I have bit2 AND bit7 enabled per post #10, so FUD is showing 130. Should I keep bit7 enabled or see how the logs look with it off?
These two pulls felt pretty good, what ya think? Any more room for safe power?
Default 07-30-2017, 09:57 AM
Logs are pretty short but look normal. Turbo is maxed out up top.
Default 07-30-2017, 12:04 PM
Man I wish I could get ya better logs, lmk if there's anyway to get more data points from the F10 DME and I'm happy to troubleshoot. I wonder if I might have better luck with the USB cable... anyways looks like 7 gallons of E with Map 7 is my peak performance tune but ok to DD with it too right? I rarely have a chance to go full WOT in my commute but just want to make sure I don't have to revert back to Map 2 or 5 if I don't need to (assuming I keep up the E). Thanks again for all your help!
Default 07-31-2017, 10:02 AM
Yes, map 7 looks fine with the current fueling.
You can also start your JB4 mobile logs manually or adjust your auto-logging parameters.
Default 07-31-2017, 02:44 PM
I only manually log right now to keep the log tab clean with WOT pulls only. Now that we're set on Map 7, I'll turn on auto-log for maybe >70% throttle pulls to have a record of things
