(#351)
Default 10-15-2015, 08:48 AM
Meth sprays on maps 3, 6, and 7 by default.
To have it hold a specific boost level while in anti-lag mode you'd also need a dedicated anti-lag boost target. Which is also something we're working on adding. The hold up on that right now is the interface. I can't add any more fields without having to redo 10x JB4 firmware versions and confusing customers with firmware to interface mismatch issues for years to come. Which we don't want to deal with.
So to get it done quickly we need to retask an existing user adjustable for it. One option might be to use the 1st gear boost limit field as the anti-lag boost limit value. Another option would be to take the map 6 1500rpm boost value as the anti-lag limit. Both values would limit the anti-lag gear regardless of gear or map, of course.
Thoughts?
The Leopard's Avatar
Car: E92
Default 10-15-2015, 01:13 PM
Thoughts?
As a fellow developer, I'd much rather a declaritive approach and have the interface show what it is (e.g. "Anti-lag max boost"). I think having a version control with a backwards compatible interface would be ideal.
That being said, given the two options presented, I'd do the map 6 1500rpm setting as it is basically useless (PWM is 100 at WOT on spool-up anyway).
Max boost in first gear is still useful independent of anti-lag.
These updates are awesome Terry. We appreciate it.
AL user.
TS N54
str8shot str8shot is offline
Car: N54 135i
Default 10-15-2015, 01:47 PM
AL user.
X2 ^
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
Default 10-15-2015, 01:50 PM
At some point we're going to have to redesign the interface anyway to allow for the PI integration tuning. So I'm just holding off any major interface changes until then.
Do we have a second on the map6 1500rpm boost target doubling as the anti-lag target?
duracell8 duracell8 is offline
Car: 2008 535i
Default 10-15-2015, 01:51 PM
I dont use map 6 so I second it...
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: N54 135i
Default 10-15-2015, 02:29 PM
Same here - if I lost first gear boost reduction my tires would cry.
Joey_335i Joey_335i is offline
Car: 2007 335i
Thumbs up 10-21-2015, 01:07 AM
Thoughts?
Map 6 1500rpm boost value sounds perfect to change!
Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default 10-22-2015, 07:40 PM
installed
Worked fine for a couple days.
Then it got really cold, in the 30s and then this didn't work. I see that I have to change something for "cold weather cars", I have to go into the flash?
Or do u have a flash for it?
Thank you
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 10-22-2015, 07:43 PM
Thoughts?
Why not use the 3rd gear limit spot? If people are doing this they need to set up their car properly.
335- stock
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 10-22-2015, 07:51 PM
Because then you restrict the boost limit outside of anti-lag function
Default 10-22-2015, 08:17 PM
installed
Thank you
Do some logs of it not working and lets check it out.
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 10-23-2015, 04:02 AM
Terry if you use the map 6 function, How will this effect map 6 users? Also if you use a stand alone meth kit like HSF4 how will using the anti lag feature work or will it work?
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
Default 10-23-2015, 03:06 PM
The map6 boost target at 1500 is useless anyway as no one is getting to target below 2000rpm.
Shouldn't be any problem using anti-lag with any meth kit.
deltalima0's Avatar
Car: 07 BMW 335
Default 10-23-2015, 07:32 PM
Really need to get this and try a 2nd gear launch at the track.
LsWhat LsWhat is offline
Car: 2008 335xi
Default 10-27-2015, 05:10 AM
Man for cold weather areas, I have to reflash whenever I want to drive when it is sub 40... I just tuned it out for now, any way to fix this yet? Like maybe switch the iat target to like sub 0, or even 220+?
Default 10-27-2015, 07:41 AM
None of the cold weather guys are willing to provide any logs on it so not much we can do until we see the data.
Car: 2008 335xi
Default 10-27-2015, 08:46 AM
Not really sure if you need a log to figure it out terry. It's 22* out in the morning, I drive my car on the highway, the iat is 32*. It goes to -25* timing. Anything over let's say.. 70 load and I'm in anti lag timing, never mind if I put my foot to the floor.
11.03 @ 129.67. Quickest awd 335, and still on stock turbos
Default 10-27-2015, 08:51 AM
Where does IAT go when engaging anti-lag mode when the IAT is 32? We can shift how the JB4 applies the function in cold weather and then you can adjust the flash table so the effect does not kick in until say 20 degrees.
Car: E92
Default 10-27-2015, 08:55 AM
Terry, when do you anticipate having the A-L max boost setting implemented?
I get surge when I try to use this every time.
TS N54
Car: 2008 335xi
Default 10-27-2015, 08:56 AM
Ok tomorrow morning I will check where the iat drops too. I was under the impression that it was always around 20-21 * iat when holding the button
Default 10-27-2015, 08:57 AM
It's been posted for a week or so under v31.8, bottom of the N54 sticky, for evaluation.
Default 10-27-2015, 08:58 AM
The JB4 is set to do that but we need to find logic that works for all climate conditions. I just don't have any data on sub 40 degree weather cars to consider. Provide the data and we can work on it.
Jboyorak Jboyorak is offline
In the northern climates, we would actually have to use below zero, or maybe switch it to above 150 degrees. 20 degrees would still be to close to our normal range. Heck, I can get below that with methonal right now 😉
Default 10-27-2015, 09:00 AM
I think we can go to around -20f if needed. Keep the data rolling.
Car: E92
Default 10-27-2015, 09:49 AM
The ST sticky has to 12_2 firmware as the latest. [edit] I see the ISO firmware, but which version do we use for ST, 12_2?
TS N54
