Turbo Lover
Car: 300zx TT, 1M
Tuner: 361 Motorsports
11-24-2009, 08:11 AM
Originally Posted by brianhn1
Want to try to put some Bacardi 151 in your little tank? 75.5% ethanol content! I'll source some.
Hell, try some 190 Proof Everclear, not fun stuff to take shots of though! I like how the turbo just gives up and says "F*ck it" after 5500rpm.  Great numbers Terry, I'm sure you will be in the 500 club with some better flowing turbos.
E93/335i
Car: 2008 E93 335i
11-24-2009, 07:33 PM
Originally Posted by Former_Boosted_IS
STETT has the charge pipe now and a whole lot of members own it including me.
Yes, I'm aware of it. I'm subscribed to both of his CHARGE pipe and METH GB threads on E90....
12.770 @ 112.81 mph with MS109 on MAP 10 || slip||
JB4|Helix FMIC|AR DPs|Injen DCI|N54 Forge DV|ER CP|Koni FSD w/Eibach-Pro|Front Strut Bar|H&R Rear Sway Bar|Brembo BBK|Hankook Ventus V12|19" DPE SP16|15%Tint|Matt Blk Grills|CF Roundels|CF Front H-Lip|CF H-Diffuser|ACS Pedals|GP8500K|Reflector Del|SmartTop|Debadged
Stalker
11-26-2009, 02:47 PM
Originally Posted by e90AW335i
Looks good.
My next question would be; do you think a car with jb3, dci, and meth only can break 400rwhp?
That would be the same as my set up. You would think I am getting pretty close to that number by my performance figures.
11 335d M-sport JBD 12.9 @ 108.3
12 LEAF 106 MPGe
08 335i Sedan 11.11 @ 129.43
08 335i Coupe JB3 2.0 11.33 @ 132.77
60-130mph: 6.95 seconds
Car: 135i, 335i, X5D
Tuner: BMS
11-28-2009, 10:59 AM
I think meth+dci can break 400rw with the 18 ohm resistors. Warren if you ever want to try I'm happy to pay for the dyno time at SpecialtyZ. Curious what that 9.9 60-130 beast puts out.
11-28-2009, 11:03 AM
Has Warren stock board or 18ohm?
He beats Ferrari 360, which does 0-60mph @ 3.9s.
Tuner: BMS
11-28-2009, 11:06 AM
I think lately he is on the 18ohm, which was worth 1-1.5mph over the stock board.
Banned
Car: N54, 2011 Mustang 5.0
11-28-2009, 11:12 AM
The two cars I want to see dynoed: Warren's (hotrod182) 335i and OldBooster's 135i
I bet Warren is right at 400rwhp, and I bet Oldbooster is closer to 500rwhp with his setup (including NOS).
11-29-2009, 10:08 AM
So basically just BMS/CM Meth kit & DCI max out the 24ohm board and 18ohm board is needed to capitalize the full potential?
Tuner: BMS
11-29-2009, 10:27 AM
It's more a risk tolerance thing. If you want to be safe stick with the 24 ohm.
I want cheese on my BMS
Car: '07 335i/A
Tuner: JB4
11-29-2010, 12:36 AM
Originally Posted by Septro
450ish.. wow just wow. Those are more than stock M5 type of numbers..
11.5s anyone on the track??? Place your bets!!
507hp=450hp?
Car: 335xi Coupe
Tuner: JB3
11-15-2011, 12:51 AM
Decided to do a little dyno testing today. I had planned on doing 91 octane + alky testing, but wimped out at the last moment and added a couple gallons of 104. So closer to 94 octane + alky. Using a 75% mix of denatured alcohol from home depot and 25% water. Ran in to the usual problems at this power level. Spark blowing out, boost leaks from somewhere (wastegate opening?), etc. But all in all was happy with the results.
Boost around 18psi! Probably a few more HP in there with better nozzle placement, etc... Tuning continues...
Details on car:
2008 135i automatic non-sport
JB3 w/ custom board (12 ohm safety resistors)
Riss downpipes and catback
BMS dual cone intake
Code3 Intercooler
Coolingmist meth tank/pump/nozzle, BMS controller
Kosei K1s w/ drag radials
Only one word comes to mind and that is SWEET  You have to love that motor!
Rob
9 seconds or bust.
Car: N54, M10, ALH/AEB
Tuner: Red Bull
11-15-2011, 01:40 PM
That is awesome.
Tuner: BMS
11-15-2011, 01:45 PM
Blast from the past LOL!
Car: bmw 335i
Tuner: active autowerke
Question -
02-28-2012, 07:57 AM
There is a relationship between the alky/water ratio, and octane to cooling benefits. Same relationship exists with nozzle placement. But I'm still processing it all now as far as the N54 is concerned. Not sure on meth vs. denatured alcohol. Need to source some for testing.
SORRY TERRY, I NEED KNOW IF TEH JB4 HAVE A SLD INSIDE OR I NEED BUY ONE
THANKS
02-28-2012, 08:08 AM
THANKS
its included in the CPS module i think.
07 335i AT - TD St.2 Turbos - COBB (Custom Cobb mapping by http://www.protuningfreaks.com/) - JB4G5 - Ported Head - Okada Coils - NGK 5992 Plugs - Injen Intake - Helix IC - Snow Stg. 3 - Stett CP - AR DPs - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Tuner: BMS
02-28-2012, 09:57 AM
THANKS
No it's a separate box that goes in the harness.
Tuner: BMS
05-11-2012, 09:45 AM
Very old thread. But note BMS' stock turbo dyno record is 456.87whp.
So far with the JB4 highest we've made is 446rw but I think there is another 10rw in there...
http://www.n54tech.com/forums/showthread.php?t=15050
| Thread Tools |
| Display Modes |
