Hoffman0070 Hoffman0070 is offline
Car: 2008 BMW 135i Manual
Default Issue with 4th gear - 06-09-2018, 10:27 AM
This might be the wrong place and if so I'm sorry.
I'm trying to get down to the bottom of an issue I have sometimes when I put the car in 4th (manual transmission) about 1 in every 50 shifts the car goes into 4th the car will just rev and nothing else, no resistance or anything. It's like it's in neutral. When I does this I have to force it back into neutral as it gets jammed where 4th is meant to be. I never have any issues any other time and all shifts are silky smooth other then when it jams, tia
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 06-09-2018, 11:49 AM
hmm ... sounds mechanical, maybe synchros are messed up, or slightly bent shift fork?
if it was hydraulic or slave cyl, would expect first gear at a stop would be grinding or difficult before 4th.
2009 535i Sport - 548whp
Software :
JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: VTT GC Lites | MFactory Helical LSD | Inlets | Outlet | VRSF 3" D-P's | VRSF 7" FMIC | Fuel-It! S2 LPFP | Fuel-It! TBI | BMS DCI | ER CP | Forge DV's | Koni FSD
Default 06-11-2018, 09:03 PM
Sounds like syncros. This happens to my second gear, like nothing is there.
Default 06-23-2018, 09:22 AM
That's what I was thinking, does it only happen to you when you are running through the gears? Never happens to me if I'm driving normally
