(#176)
milfriez milfriez is offline
Car: 07 335xi
Default 06-17-2018, 11:01 AM
Without having the horizontal notch, there is nowhere for the clip to seat into to allow the rest of the clip to seat into the groove around the inlet/outlets that I can tell.
I suppose I could cut off the horizontal portion of the clips, but I feel like that defeats the locking mechanism.
Am I missing something here?
Default 06-17-2018, 11:11 AM
You are. What locks the clip in is the grooves going inside the cut outs that retain the chargepipes. If you still need help though email support and they can get you some photos to further clarify.
Car: 07 335xi
Default 06-17-2018, 11:16 AM
Gotcha, armed with this and a suggestion from our friends at e90post, someone just said start at the bottom and jam it up on there. I was trying to start at one side, and swing it down and across like they show on some of the YT videos.
Apparently what you said is correct, its not the horizontal notch that locks in place, its the mid-point on the c-clip that slides into those cutouts. Sorry for being a N00b, but for the life of me I was just not getting these things to lock in place. Good now.
Default 06-17-2018, 03:57 PM
No worries glad it's sorted!
XXXDrive XXXDrive is offline
Car: 2010 E92 335
Default Race intercooler - 06-19-2018, 01:35 PM
I have a 13 335is and it looks like the cold side j pipe is a s pipe and the couplers I got with my race intercooler is not going to work. No band to cut on my j pipe. Can someone clarify
Default 06-19-2018, 01:51 PM
If you have a one piece chargepipe you'll need our extra J pipe, either in 2.5" or 3". We'll have both ready this week hopefully.
Car: 2010 E92 335
Default 06-19-2018, 01:57 PM
It's my daily so I'm dead in the water, I hope this week....thanks for clarification
Default 06-19-2018, 02:49 PM
If desperate just cut the factory chargepipe for now.
Default 06-19-2018, 03:27 PM
Jpipe will be in tomorrow and should be ready for shipping by Friday!
Car: 2010 E92 335
Default Name this part - 06-19-2018, 07:21 PM
Found this behind the front bumper, looks like it needs to be moved to fit the race intercooler......name this part
Default 06-19-2018, 07:37 PM
Ambient temperature sensor.
Car: 2010 E92 335
Default 06-19-2018, 08:03 PM
Cool! Thanks back to fitting this thing
Default 06-20-2018, 07:06 AM
Just pull it off and zip tie it around the corner :D
Car: 2010 E92 335
Default 06-23-2018, 02:18 AM
She's in, had to trim the silicone couplers to get it to fit ....FYI
artsoasis artsoasis is offline
Car: 335iS
Default 06-23-2018, 06:52 AM
Payam,
Can you send the J pipe for those of us who purchased the intercooler originally?
We would need that and a cold side coupler for those of us who had to cut it.
Iíll even pay for shipping.
If not can we buy those two parts separate?
Default 06-23-2018, 09:33 AM
Yes, we supply the longer couplers just in case people have custom chargepipes etc.
Default 06-23-2018, 09:35 AM
Originally Posted by artsoasis
Payam,
Cutting and removing the stock silicone from the plastic J pipe is necessary for the install. Unless there is something different that I'm missing.
The 3" pipe is optional, it's not standard so you'd have to purchase it separately when on the site.
Will post pictures later today!
Default 06-23-2018, 02:05 PM
Couple photos of the 2.5" J Pipe (for cars that have the one piece factory CP, uses couplers included with our IC), and the 3" J Pipe kit that comes with matching 3" couplers for the intercooler and chargepipe. We'll have both kits on our site shortly.
2.5" pipe $29, 3" kit $59.
Snowman Snowman is offline
Car: BMW M135I
Default 06-24-2018, 05:48 AM
What would the benefit be to go for the J-bend 3"?
Im thinking of getting the CP and IC aswell and might just throw in that to..
Default 06-24-2018, 05:39 PM
The 3" is a tight fit but good for larger turbos and higher hp applications.
Car: 2010 E92 335
Default Race intercooler logs - 06-24-2018, 09:24 PM
13 335is fbo e40 inlets outlet and just added race intercooler
Updated to race intercooler due to race with 392 charger showed Iat are out of control. In one log I was running e50 and higher boost and in the other e40 with lower boost
Default 06-25-2018, 07:49 AM
That is insane difference!
IAT with Our Race Intercooler only went up 2* LOL compared to the other intercooler 70* you can't even compare them.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 06-25-2018, 08:33 AM
What intercooler was on the car previously?
Car: 2010 E92 335
Default Race intercooler - 06-25-2018, 11:02 AM
It was a knockoff 5'' stepped from arm. It was ok before going fbo and adding inlets\outlet, also revealed hpfp struggles with e50 even with stage 2 bucketless
Default 06-27-2018, 09:06 AM
Nice comparison photo!
