RCB RCB is offline
Car: E61 535XIt
Default 03-24-2016, 06:55 AM
Originally Posted by DV135i
Something they check for when you get your car smogged.
Here in MA our cars would not be able to get an inspection sticker unless the rear O2 sensor monitor cleared (readiness test). If the RMV scan can tell that the DME has been tampered with the car is then flagged and can only be reinspected at a RMV inspection station. So it becomes a major issue if any of this isn't below the surface.
I would want to know without a doubt that coding out the rear O2 sensors would fly under the radar before I install *** and did this.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
omarmarji's Avatar
Car: n54 335
Default 06-19-2016, 08:25 PM
DID WHAT DMAC SAID, WORKED PERFECT, THANK YOU
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
konvikt21 konvikt21 is offline
Car: 2008 335i 6mt
Default 07-05-2016, 10:27 AM
whats the easiest way to find these values in the hex? Any way to search? IJE0S..
Doc Race Single Turbo Kit PTE5862 - e93 6MT - ADE PI - Fuel-It Stage 2 Bucketless - JB4/MHD - MFactory 3.46 LSD - MFactory SMFW - Spec Stage 3+ Clutch
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 10-23-2017, 08:06 AM
Originally Posted by Dmac @ BMS/DMD
Been running with my rear O2s unplugged from the DME for awhile now on 32psi.
What I did:
Remove pins 19 and 20 on the small black subconnector
Code out 2C9E and 2C9F in the flash
I had previously did this procedure but I've since reconnected the rear o2 sensors and I'm not sure if I connected the pins right. Does this look correct?
Single Turbo Z4 that's constantly broken
samstryker's Avatar
samstryker samstryker is offline
Car: 2008 535xiT e61
Default 12-30-2017, 05:00 PM
What I did:
These codes weren't available in the public XDFs so I had to add their definitions in myself. Let me know if you have any questions.
Is it necessary to remove the pins from the sub connector or can I just leave the sensors themselves unplugged?
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 01-03-2018, 03:14 PM
Bump for answer on if DMAC's solution will allow '02 readiness'.
also bump for answer on if you can just leave it this way full-time, and trims and bank-to-bank variance will not be negatively affected.
2009 535i Sport - 548whp
Software :
JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: VTT GC Lites | MFactory Helical LSD | Inlets | Outlet | VRSF 3" D-P's | VRSF 7" FMIC | Fuel-It! S2 LPFP | Fuel-It! TBI | BMS DCI | ER CP | Forge DV's | Koni FSD
samstryker's Avatar
Default 01-04-2018, 11:13 AM
+1
I've been running with them unplugged for about a week now and logs look clean
DV135i's Avatar
DV135i DV135i is offline
Default 01-05-2018, 09:37 AM
Definitely interested in knowing if o2 readiness can be achieved after disabling the o2's.
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR **'s~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
Puganator46 Puganator46 is offline
Car: 08 335xi
Default 06-12-2018, 12:31 PM
Is it possible to do the flashing through the mhd BEF?
08 335xi-Jb4 with MHD backend flash. DOC precision 6266 single turbo. BMS charge pipe with Tial BOV. On3 performance 7" intercooler. Stage 3 fuel-it lpfp. New index 12 injectors. New OEM hpfp.NGK 97506 2-step colder plugs, RB external pvc system with duel occ.
Default 06-12-2018, 04:28 PM
Are you trying to disable O2 via flash through MHD?
Car: 08 335xi
Default 06-13-2018, 05:18 AM
Yes!!! Lol also some other engine codes. I'm not concerned about the o2 readiness either. I don't see where mhd is an open flash program. I have access to ncsexpert, bmw coding tool, winKP, ista, etc and have done coding just need to know how to access the engine codes. Thank for the reply!!!!!!!
Car: 08 335xi
Default 06-18-2018, 09:03 AM
<Bump>
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-22-2018, 03:20 AM
Use tunerpro
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Car: 08 335xi
Default 06-23-2018, 01:41 PM
Originally Posted by Haynpunch
Use tunerpro
I've only done a little research on the tuner pro, is this going to take place of the mhd? Or can I just make the changes I want while my car has the mhd BEF on it
langsbr langsbr is offline
Car: Acura TL
Default 06-23-2018, 05:44 PM
This thread spans a few years worth of work. I know the XDF now has the ability to toggle codes - but what of pins 19 and 20 in the DME?
I've read where it's been stated that the secondary O2s are needed to keep fuel trims correct, but Dmac said he removed them and all was good. Is that still the case, or has more been learned regarding DME behavior?
Car: 08 335xi
Default 06-23-2018, 06:52 PM
Yes this has definitely been an on going topic lol, from the research I've found the rear o2 are only for c_a_t performance. So without c_a_t_s the rear sensors can cause the fronts to get out of calabration but besides that it's just an annoying CEL and from my experience a occasional rough idle until I clear the catalytic converter check/trimming codes.
335iE91's Avatar
335iE91 335iE91 is offline
Car: '08 e91 335i
Default 06-24-2018, 09:54 AM
I’ve also been told that the rear sensors are used to calibrate the fronts. Seemed strange you can run the same ots maps with or without c@t$. Then again, if you’re Not running the rear sensors, how would the front sensors be calibrated? And are the rear sensors also still enabled in the single turbo ots maps?
'08 e91 335i Auto
Jb4 G5, Mhd backend, Xhp stage 3, Vrsf **'s, Secondary *** delete, Occ and Dci, RB pcv, FTP oil thermostat, Billstein b14, M3 lower controle arms, Poly subframe bushings
Car: 08 335xi
Default 06-26-2018, 07:28 AM
Originally Posted by 335iE91
Iíve also been told that the rear sensors are used to calibrate the fronts. Seemed strange you can run the same ots maps with or without c@t$. Then again, if youíre Not running the rear sensors, how would the front sensors be calibrated? And are the rear sensors also still enabled in the single turbo ots maps?
I would think the sensors calibrate on there own and basically the car makes adjustments between the two readings I presume that without c_a_t_s the fluctuations can get them out of calabration. You can run the maps with or without c_a_t_s because the rear sensors only pertain to the *** performance which "shouldnt" affect the cars performance. And yes they are enabled in ST maps
335iE91's Avatar
Car: '08 e91 335i
Default 06-30-2018, 09:59 PM
Agreed. But then the rear sensors should be switched off with open *** (ots map or not) to prevent the front sensors getting out of calibration, right?
'08 e91 335i Auto
Car: 08 335xi
Default 07-03-2018, 11:43 AM
Ya that's what I was hoping for as well but the ST map doesn't seem to be that way. I'm just trying to figure out if I can use an open flash tuner to delete them without having to change from the mhd BEF that I've already paid for!!!
335iE91's Avatar
Car: '08 e91 335i
Default 07-03-2018, 12:05 PM
Seach on YouTube for: ‘Single turbo 335i vs. emissions testing’
'08 e91 335i Auto
335iE91's Avatar
Car: '08 e91 335i
Default 07-04-2018, 04:41 AM
For those of you who are not running rear o2 sensors:
Has anyone ever measured their afrís with an actual probe (on the dyno), and compared those numbers to a log of the same run? Twins or single
'08 e91 335i Auto
Car: 08 335xi
Default 07-05-2018, 05:32 AM
I would think you could see this on logs
