cmkim_11 cmkim_11 is offline
Default Help with Log Review - 06-23-2018, 01:02 AM
2013 F30 320i N20 PWG.
Injen intake,
VRSF intercooler,
VRSF D/P,
ER CP and TIC,
GFB DV+,
Supersprint exhaust.
95 RON (AKI 91)
Please advise on any changes I can do with the settings. Peak boost was about 14-15psi.
Default 06-23-2018, 01:56 PM
With the PWG N20 you need to set 3.5bar to 0. And then relog map5.
Default 06-24-2018, 11:12 AM
Changed TMAP = 0, Map 5
1st and 2nd runs logged as attached. Not sure why only captured to 4000+ rpm when exporting.
On 3rd run, Drivetrain fault came on
121001 TMAP sensor, short circuit to B+
120408 Reduced power mode
104401 MAP sensor, intake pipe, electrical: Short circuit to B+
104402 MAP sensor short circuit -
121002 MAP sensor, short to ground
Spoken to a Burger agent here before, he suspected it was harness fault. Car runs ok stock
Default 06-25-2018, 08:37 AM
Looks like somethings up for sure since your logs keep cutting off at some RPM. I'd speak with Ando@burgertuning.com to setup a repair.
Default 06-25-2018, 10:54 AM
Thank you. Do update me. The JB4 was purchased from local distributor.
Default 06-25-2018, 12:54 PM
Anything can happen to be honest.
Default 06-30-2018, 10:30 AM
Hi Payam and Ando, any updates on the repair? It’s still throwing limp mode n MAP short circuit faults on TMAP 0 n Map 5. Should I bring it back to the Singapore agent Speedhaus or send the JB4 to BMS? It was purchased in Jan 18.
Default 07-04-2018, 09:25 AM
Hi I have updated the latest firmware N20_OBDII_PWG_5_T3.hex and tried to do a log, but still didn't capture much info I guess. Not sure if it is a harness problem.
Also noticed boost safety is now defaulted 16.9 and TMAP 0.
Should I go back to local distributor whom I purchased the JB4 in Jan 18, or seek advice with you directly?
Default 07-05-2018, 09:37 AM
For repairs and warranty I would email Ando@burgertuning.com so he can help you.
