AshWebb AshWebb is offline
Car: M135i
Default M135i EWG - Boost not meeting target, fault codes, logs inside - 06-22-2018, 09:42 AM
Hi all,
Have had a jb4 fitted for a while now but have only recently started paying a bit more attention to it...
My car is EWG, i have the EWG and FF harness fitted and connected. JB4 has the latest firmware loaded.
Mods;
D e c a t
BMS intake
JB4
Forge charge pipe
Fuel;
Tesco momentum 99
Long story short, i have recently had a few fault codes, and my boost appears to be a few psi under target.
Fault codes i have had are;
'102001 Air mass, plausibility - Tuner code, ignore'
'119404 Rail pressure sensor, signal stuck'
'119001 Rail sensor short circuit +'
'13E201 Suspected VANOS fault'
Currently FF / Wastegate adaption has shot up to 114, and average ignition is 3.3. Trims seem to be around 25 is this low?
Have also noticed that FF is 0 on all logs at all times, does this point to an issue with my FF harness/connectors?
i have uploaded some logs here, if someone could take a look and provide some feedback and advice then that would be much appreciated;
https://www.dropbox.com/sh/i4boe6aim...I-MmHhlka?dl=0
Thanks in advance, Ash.
Car: M135i
Default 06-22-2018, 09:46 AM
Logs attached.
Map2 22-06-18 1618.csv
Map4 22-06-18 1612.csv
Map5 22-06-18 1622.csv
Map5 22-06-18 1626.csv
Map5 22-06-18 1635.csv
Default 06-22-2018, 06:01 PM
Adjust duty bias to 50 across the board and log again. Could be a short in the system too since you're having those faults and it seems like I don't get any value here for some things.
Car: M135i
Default 06-23-2018, 12:24 AM
Thanks for the response - will try settings duty bias to 50 and do some more map5 logs.
I also found it strange that i have no values for FF, and Fuel pressure low. Could this point to an issue with the FF wires?
I also expected WGDC to be higher being as the boost is constantly below target by 2-4psi?
How would i go about searching for a short in the system?
Thanks, Ash.
Default 06-23-2018, 09:45 AM
Lets get a log first and if I still see the values missing I'll start digging for you
Car: M135i
Default 06-23-2018, 10:58 AM
Thank for the help
I have changed all duty bias to 50 as you said, no more fault codes have appeared, WGDC seems more normal, I'm now actually getting FF values on the logs too.
Car feels like it pulls a harder than it did before and feels smoother as well.
Boost seems to hold much closer to target than it did before, but do you think the target seems a bit low considering my mods and settings?
Average ignition has gone up again, and also FF / Wastegate Adaption has shot back up to 125 after setting it back to default.
Also still getting no values for fuel pressure low.
Do you still think there could be issues with the FF wiring now that I'm actually getting FF values on the logs?
Logs attached, what do you think is the next step for further improvements?
Thanks, Ash.
Default 06-25-2018, 09:17 AM
Logs are looking much better to me. FF will learn because we changed the duty bias values, so let it do it's thing. Everything else looks to be perfect and all values are showing. N55 does not have a low pressure sensor, so no value there.
Car: M135i
Default 06-25-2018, 09:48 AM
Originally Posted by cnm135i
Good looking log! Try flat 15psi in map6. You should feel the car pulling much harder to redline.
Thanks for the advice, do you mean 15psi at all rpmís?
Ash
Car: M135i
Default 06-25-2018, 09:50 AM
Thanks, I tried map2 again this morning. All was well until I had a large jolt and loss of power on WOT in I think 5th gear at around 5k rpm. I then had a drivetrain malfunction but the car returned to normal after around 5 seconds or so. Have you experienced this before and what would be the cause?
Also based on the map5 logs do you now think there is no issue with my FF wiring?
Ash
Default 06-25-2018, 10:45 AM
Ash
Do you happen to have a log of that run? It would be hard to try and diagnose without actual data, very odd though.
I don't think there's an issue at all, your logs are normal.
Car: M135i
Default 06-25-2018, 12:31 PM
Unfortunately no log as I was on the way to work. Will go out for a drive one day on map2 and see if I can replicate the problem. But basically car seemed to suddenly and violently lose all power for a short period!
Good to know that the map5 logs look good, Iíll try running map5 over a longer period and see how I get on. Do you think there are any further improvements I could make in the short term?
Also so I can understand better, generally what values should I be looking for when it comes to WGDC and FF on the logs?
Default 06-25-2018, 01:17 PM
In general it looks okay, I don't think you need to mess with anything.
WGDC and FF should basically overlap each other. If FF is lower than WGDC you'll be under target for boost and need to raise FF to hit target and vice versa.
Here is a link you can look at for next time.
http://www.n54tech.com/forums/showthread.php?t=21269
Car: M135i
Default 06-25-2018, 01:21 PM
Thanks for the help.
As I said I will change back to map2 and see if I can catch the loss of power in a log and send you the log if I do.
Will take a look at the link. Would you recommend to just leave the jb4 on is current settings and let it learn on map5 rather than adjusting values?
Also I intend on loading the jb4 mhd BEF map, do you think Iíll see a benefit from this?
Default 06-25-2018, 02:51 PM
Map 5 is usually what I recommend for people who daily the car. Yes the BEF is a huge improvement and addition to the Jb4.
