(#26)
Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default 07-12-2018, 04:20 AM
It's cause map 3 is using meth for your boost target so it will boost higher when meth flowing. Everything does look normal though, I'll see what Terry might have to say for that. Otherwise these logs looking healthy!
Same logic with meth safety 2?
I read this in JB4 ISO 27.8 meth safety changes thread:
Option 2: ... Note that while we don't suggest option 2 due to its non-integrated nature the benefit here is going to be quicker boost response. When you decide not to worry about spool up knock and whether or not your methanol flow is sufficient for the tuning the car can feel more responsive. It's a bit like burring your head in the sand but for those running E85 + meth its less of a risk than those running pump + meth.
I could try 93+meth for less risk.
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI w/ scoops - Phoenix Racing CP - TIAL BOV - NGK Iridium plugs - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear anti sway bar - xHP stage 3
Default 07-12-2018, 03:39 PM
Log is looking good to me man! The little throttle closure is because your boost went over target at that moment. So throttle closed a bit to regulate boost.
Ripley's Avatar
Car: 335i N54
Default Yesterday, 04:07 AM
Ok, now it's clear
I did another log with 75 additive. Boost is near to 25 psi and timings seem good. I am not sure about fuel pressure high. Do you think I have margin to raise more boost?
File Type: csv map 3 91+meth 7 psi start 75 additive 2018-07-16 00_25_40.csv (10.3 KB, 1 views)
