m5james's Avatar
m5james m5james is offline
Default Odd oil filter housing noise and RPM based rattle - 09-13-2017, 02:23 PM
GF's 535xiT broke down, ends up I've got P0012 and P3100 code. I've cleared the codes, drives OK but filter housing area doesn't sound right.
https://youtu.be/72OOBAYGNlA
Blipping throttle sounds faintly like marbles when it's decelerating around the 3k-2k rev range, almost like this. This isn't my video, btw.
https://youtu.be/yrH_Vzk_UUY
I've pulled the filter, it's not collapsed. VANOS intake solenoid and cam ledge replaced a year ago, both turbos about two years ago - all done by BMW of Bellevue prior to purchase/delivery. Any ideas?
'08 BMW 535xiT - BMS DCI, RB/Mishimoto
Reiss91 Reiss91 is offline
Default 09-13-2017, 08:13 PM
Take the belt off and run it. Might be an accessory causing the noise.
m5james's Avatar
Default 09-13-2017, 08:34 PM
The filter housing noise is very distinct and seems it could only be coming from there. I've watched like 20 YouTube videos on anything from wastegate rattle (nothing changed when I pulled the vacuum lines) to accessories like the power steering pump (fingers crossed you're right) to rod bearings :-/ I'm off work at 11:18pm tonight and I'll go look at accessories wobbling as the GF turns the wheel lock to lock with my fingers crossed!!
