Ancient8989 Ancient8989 is offline
Default Jb4 G5 Resetting Itself - 09-12-2017, 03:03 AM
My G5 keeps resetting itself whenever I get on the throttle, the signals blink and it goes from any selected map to map 1. Even when it's set to disabled on map 0 it will blink back to map 1.
Codes:
2ABC - Charging pressure sensor, electrical
2ABD - Intake pressure sensor, re-running
29F3 - Fuel pressure sensor, electrical
These codes cause a cel and engine malfunction, is this why the G5 keeps resetting?
Default 09-12-2017, 07:40 AM
Something else out on CANbus? JB4 log?
Default 09-12-2017, 09:02 AM
I can log later today, nothing but jb4 is connected. Single turbo setup MHD flashed
Default 09-12-2017, 09:46 AM
Single turbo going to map1 is a safety system... That is probably what is happening here, not a board reset.
Log will tell us why.
Default 09-12-2017, 01:40 PM
Log uploaded. Also the interface says the last safety was AFR Lean.
Default 09-12-2017, 02:02 PM
Is it! Something looks messed up here starting with the flash end. You loaded a normal BEF map?
Default 09-12-2017, 02:05 PM
I loaded the newest ST map using MHD. Write took 2 minutes. Is this correct or should I reflash?
Edit: Car also dies when the Jb4 is enabled on start up.
Default 09-12-2017, 10:22 PM
This is a mess!
You did a full write and were flashing for the first time or it was an update?
Your LPFP sensor is bad.
HPFP is very low.
AFR's are extremely lean.
Bank to bank AFR's have a pretty big delta.
Trims are maxing out.
You have some work to do.
2ABC and 2ABD can definitely be contributing to this as well.
Default 09-13-2017, 05:57 AM
This is a mess!
HPFP is very low.
It was an update to the flash. Also somehow I messed something up while flashing. Car cranks forever and starts, but throws every error under the sun. Specifically 2FA3 DME no coding. I've flashed it back to stock on a long write using MHD and everything. Same thing. Jb4 was completely removed during stock flash, and set to map 0 on the ST reflash. I don't know what to do about it.
Default 09-13-2017, 08:11 AM
Try contacting MHD. Sounds like you will need a full write and may need to interrupt an upload to start fresh.
Default 09-13-2017, 02:16 PM
Reflashed to stock and the crankshaft position sensor came unplugged so car starts just fine. Doing a full write ST flash at the moment. Do you think replacing sensors will help all the fuel related symptoms if a reflash doesn't?
Default 09-13-2017, 02:34 PM
What is the DME software version?
Default 09-13-2017, 07:18 PM
The DME was successfully flashed to stock and reflashed using the newest version of the ST map for my car. Performance seems improved by a mile. I will run a log tomorrow, it's been rainy today.
Default 09-13-2017, 07:27 PM
Ok fingers crossed.
Default 09-14-2017, 01:36 PM
Ok fingers crossed.
Here's a log from today map 2 pull, obvious boost leak, not sure what else.
FF set to 20, adapted to 42
DWP set to 20
Duty Bias set to 50
