knissel's Avatar
knissel knissel is offline
Car: 08 335xi
Default New E85 Calculator for iOS - 05-16-2014, 12:41 PM
iTunes Link
I am pleased to annouced the release of my E85 Calculator for iOS!
It has all the same features of android but just to recap it can:
-Tell you how many gallons of each fuel to add to obtain desired E%
-Can take into account how much fuel and E% currently in your tank
-Clears fields on selection (so you don't have to delete numbers before entering new ones)
-Saves your calculators for next time you use the app
Link to Download
E85 Calculator for Mobile Android iPhone
11.762 @ 118.40 (335xi Stock Turbo WR)(Totalled)
09 335i xDrive Stock (Sold)
12 GT-R BE 800 awhp 9.8 @ 139
F335 F335 is offline
Car: F30 335i
Default 05-19-2014, 08:13 AM
Please can you add liters to the units
knissel's Avatar
Car: 08 335xi
Default 05-19-2014, 08:15 AM
I appolgize for the confusion. The app works with any units of messure right now. I submitted the change for text fields but if you use the app it works the same with liters or any other unit of messure.
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 05-19-2014, 08:18 AM
Only works on 7.1???
knissel's Avatar
Car: 08 335xi
Default 05-19-2014, 08:21 AM
Are most people using older versions of iOS? Is there something about 7.1 that is bad? I will look into making it compatiable with other versions.
alexim's Avatar
Car: 1M
Default 05-19-2014, 08:24 AM
I'm on 7.0.4 due to jailbreak!!! I think if it works on iOS 7+ you should be ok!!
knissel's Avatar
Car: 08 335xi
Default 05-19-2014, 08:26 AM
k cool I will put this change in tonight along with the unit text change.
alexim's Avatar
Car: 1M
Default 05-19-2014, 08:27 AM
Great!! Thanks!
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 05-19-2014, 09:01 AM
Interesting, just got it
alexim's Avatar
Car: 1M
Default 05-20-2014, 11:20 AM
If I have e100 available I just set e% on e85 pump to 100???
knissel's Avatar
Car: 08 335xi
Default 05-20-2014, 11:47 AM
Yes sir
alexim's Avatar
Car: 1M
Default 05-20-2014, 12:02 PM
Great.. Please let us know if you get it working on 7.0.4!! Thanks...
knissel's Avatar
Car: 08 335xi
Default 05-20-2014, 12:10 PM
Yeah I uploaded the new version that has a min version of ios 6 so it should be good for everyone to use. Just need to wait on Apple as usual...
Hetzle Hetzle is offline
Car: 2011 E90 335i
Default 05-20-2014, 12:31 PM
Are our tanks really only 15.5 gallons? I was under the impression they were 16 flat
2011 335i sedan 6MT, JB4 w/FlexFuel wires, AA 4" **, VRSF 7" FMIC, AA turbo-back exhaust, UUC DSSR+SSK, BMS CDV, ER CP, BMS OCC, Arkym CF trunk
fnne99 fnne99 is offline
Car: 2008 335xi
Default 05-20-2014, 12:44 PM
I think the total amount of fuel is more than that. I was one notch below half and put 8.4 gallons in.
Usable fuel is probably ~16 gallons. Total fuel capacity (including unusable fuel) ,I would guess, is closer to 17gal. I use 17gal when calculating e85 mix which gets it close enough.
Nugs Nugs is offline
Car: 2011 135i
Default 05-21-2014, 10:34 PM
I think the 135i tank is 53 litres.
knissel's Avatar
Car: 08 335xi
Default 05-23-2014, 11:40 AM
New version is released now:
https://itunes.apple.com/us/app/e85-...1777?ls=1&mt=8
-Has the new OS target and the gallons info removed (screenshots need updated)
*I will try to get a new version of the app build this weekend that includes some more detailed info on mixes(octane SG etc)
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 05-23-2014, 09:26 PM
This is what the E85 calculator I use looks like. Maybe you can get some ideas from it. Here's an example (this is what mixture I run daily)
Amgturbo2012's Avatar
Amgturbo2012 Amgturbo2012 is offline
Car: 2010 135i
Default 05-23-2014, 10:06 PM
Bought. Review left.
10'135i Alpine White M-Sport M/T 827HP 707TQ@32lbs
Motiv 900 - Tial BOV/Wastegate - Big Tom Intercooler - FuelIt! Stage 3+ - MHD Custom Flash - Haltech PS1000 - Motiv Port Injection/Twin Disc - BMS OCC - Kosei - 275/40/17 NT05R's
10'135i Black A/T - 580WHP 540WTQ (11.51@134MPH 2.1 60')
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 05-26-2014, 12:18 AM
What's the 335i tank size??
Need4Speed
Default 05-26-2014, 12:26 AM
16.1. Maybe 16.2
335i-boy 335i-boy is offline
Car: E92 335i M-Sport
Default 05-29-2014, 08:06 AM
Just bought the App. Has everything you need. Simple to use. Works great.
I have one suggestion. It might be an idea to change "Ethanol Needed" to "E85 Needed".
When I read it the first time I thought "Ethanol Needed" referred to actual ethanol required and not how much E85 to put in.
2008 E92 335i M-Sport | Sapphire Black | Sunroof | Creme Beige | Poplar Grey | Logic 7 | 6AT | 19" AG M359's | Michelin PSS | LUX V3 | JB4 G5 ISO | Wedge E85 flash | DCI | AR ********* **'s | Helix IC | BMS CP | Forge DV's | (Stock exhaust - **'s back) |
Car: 2008 335xi
Default 05-29-2014, 08:16 AM
Remember, there is always unusable fuel in a tank when it it supposedly empty. Not a huge deal but depending on how accurate you want to be, I would figure in that fuel also.
knissel's Avatar
Car: 08 335xi
Default 05-29-2014, 09:05 AM
Thank you for your feedback. I have considered both options and I am still unsure on the correct wording. I agree that E85 makes the wording more consistant. I also was thinking that if someone wanted to use say E98 then the word Ethanol is more accurate than E85. IDK. I will be working on adding more features to the app this weekend hopefully.
dannyd79 dannyd79 is offline
Car: 2008 E92 335i
Default 09-13-2017, 10:34 PM
Is this app no longer available? My app store says its unavailable.
