(#11126)
#1rudebwoy #1rudebwoy is offline
Default Hexon 550 or rr600 - 12-07-2017, 07:51 AM
I know I know you guys are going to tell me about Hexon and I know they are out of business but I have my own project going and want some upgraded turbos for dirt cheap. If there is anyone selling a set please inbox me. Before you ask I can buy what I want and I have my own reasons for buying them ... thanks
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 12-07-2017, 03:35 PM
How about start by posting in the right forum section?
jacie6056 jacie6056 is offline
Default 12-09-2017, 04:52 PM
Hello,
Terry @ BMS
I am new on JB4 and BAF from Terry
1. Can I use the BC button or jb4 Bluetooth connect kit to change map while I am cursing or on the highway? Is this safe?
2. Another question, Last week I use MHD auto logging with JB4 installed , Suddenly my car shut down and throw over boost code. It seems like I can not use MHD logging anymore or something wrong with my car? I mean I came from MHD tune to JB4 because it's more safe as everyone recommend.
3. Finally, Do I need to completely uninstall MHD in order to use jb4 with BAF. Or I can flash with MHD stock map and run with JB4 with BAF. So far, I am running MHD stock map with JB4 BAF from Terry without any issues but I want to know the right way.
Many thanks,
jsprjs jsprjs is offline
Car: 08 E93 N54
Default 12-27-2017, 01:57 PM
I was wondering if the feature introduced in G5_ISO_32_5 that automatically switch map to 0 when an OBD flashing unit is detected can be turned off ? I was trying to use a Banks Power iDash 1.8 super gauge to monitor some parameters but JB4 thinks it's a flashing unit.
Link to Banks iDash 1.8" gauge
Thanks.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 12-27-2017, 02:01 PM
Thanks.
It's not about flash device or not flash device, as far as I know anything that connect to OBD and takes reading from the ECU will confuse the ECU and JB4 readings
09 E92 335i - GULF Version, Hot-Climate Version, Middle East package, M Sports suspension, 19" Rims, 6AT with Xhp stage 2 flash, JB4 - Map 3 - MHD BMS Race Flash with modified Duty Bais and PID - BMS Oil Cooler Valve - RB PCV - K&N drop in Filter - AFE Air Scoops - 98 Super Fuel - WAGNER FMIC - 3" **'s - BMS Water/Meth 40/60 VP Racing M1 with 70 adder
Default 12-27-2017, 02:37 PM
Thanks.
The JB4 needs exclusive data from the DME to work properly, so it turns off if anything in OBDII port requests data from the DME.
Car: 08 E93 N54
Default 12-27-2017, 03:11 PM
Thanks for the instant replies
RadarContact's Avatar
Car: 2006 E46 330cic ZHP
Question 01-10-2018, 07:43 AM
2 minor issues with JB4 on my E60:
1) gauge needles have never quite lined up the way Iím thinking they should, but they are close. Iíve tried all the resets, changing away from/back to 535, etc., nothing has fixed it. Pic provided of map 6.
2) canít seem to get the can flap(?) double-exhaust-tips-open (all the time) setting to ďstickĒ. I set it, it works, then soon after that itís back to single tip output.
Anyone else have these issues or is it just me?
Thanks.
// Radar //
2010 535i M-Sport w/Sport AT, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6) Custom Tune, Custom Meth Setup, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
Ken 335ia's Avatar
Ken 335ia Ken 335ia is online now
Car: bmw e91 335ia
Default 01-10-2018, 08:24 AM
I noticed that my Can flap stays open when in Jb4 menu
Ie. Orange dash board.
I Press minus on volumen
To go Down the menu to escape.
When at Map ie 0 still Sound from both exhausts
Then minus one more time to exit = no more Can flap
Sound from both
jwilusz's Avatar
jwilusz jwilusz is offline
Car: 2011 335is, JB4 w/dci
Default Best way to run on 335is with dci - 01-10-2018, 04:15 PM
What is the best map, and settings to have for a 335is M/T with dci and 93octane
DanL DanL is offline
Car: 2010 535i M Sport
Default 01-11-2018, 05:18 PM
Thanks.
// Radar //
You'll never get the tach needles to line up correctly in an E60. That's been an issue since I purchased my JB4 5+ years ago. The CANflap used to work, but maybe the recent "toggle" change wasn't tested with an E60 and broke the functionality. Regardless, opening the flap in an E60 is a 30 second job -- you just have to move one vacuum line in the trunk. See this thread: http://www.n54tech.com/forums/showthread.php?t=20709
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
Premium, Value, Cold Weather, Sport Auto, Navigation, Satellite, Logic 7, Comfort Access, Park Distance, Fold Down Rear Seats, Heated Rear Seats, Rear Side Airbags, JB4 G5 ISO, BMS DCIs, ER Charge Pipe, Proform Clear Bra, LUX H8 160 LED angel eyes
Default 01-12-2018, 12:29 AM
Thanks DanL, that sure saves me a lot of trial and error, error, error, error...lol.
I’ll check out that post right now...I can’t sleep anyways...
V/r
// Radar //
EDIT: Just read it...good stuff and well explained.
Default 01-12-2018, 09:24 PM
Normally map 2.
mp335 mp335 is offline
Car: 09 335i
Default 01-18-2018, 10:29 PM
Normally map 2.
Hi Terry, few newbie questions hope you can help.
a) for 93 would your recommend race bef or pump bef?
b) bef map 2 targets boost of 17psi, so adding 30% E85 would still get same boost that said does E85 help to make more power vs pump gas in this case?
thanks!
Ragin Cajun Ragin Cajun is offline
Default Dyno Results After Inlets/Outlets JB4- MHD BEF - Today, 09:04 AM
Hi Guys:
Installed the inlets and outlets and ran on the "heartbreak" Mustang Dynamometer. Map 7 with 100% meth, no water. HP was just about 400 to the wheel and torque was 482. Not too bad, but I think my boost is not hitting the target. Can you view my logs and let me know if I am getting the most out of the setup? I put the FF to 80, however it worked its way up to 134.
Please let me know your thoughts as I may have inputted a wrong value on user adjustment on the JB4. Thanks so much!
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Mrpink
