dom1118 dom1118 is offline
Car: 2008 BMW 135i
Default jb4 jumps to map 4 - 01-17-2018, 05:19 PM
pulls hard in 2nd gear then shift to 3rd it falls on its face then jumps to map 4 i put the one prong ngk colder plugs in it (what are they suppose to be gaped to) here is a log
Car: 2008 BMW 135i
Default 01-17-2018, 05:24 PM
the car has tial bov 7" intercooler 3" ******* downs sec cats deleted to agency power muffler jb4 afe intakes
Default 01-17-2018, 05:30 PM
Fuel trims maxing out, FF seems really high too.
Log on map4?
Codes stored?
Car: 2008 BMW 135i
Default 01-17-2018, 07:23 PM
whats ff and what can cause that and give me a little bit ill get a log
Car: 2008 BMW 135i
Default 01-17-2018, 07:53 PM
heres a log in map 4 it seem to pull good in map 4
Car: 2008 BMW 135i
Default 01-17-2018, 07:58 PM
and here is the codes from the first log and last log
Steve @ BMS/Fuel-It! Steve @ BMS/Fuel-It! is online now
Default 01-18-2018, 11:16 AM
You're overboosting and trims are in open loop.
Try resetting adaptions by selecting 1/7 with the steering wheel controls with car on but not running. However my guess is that this is some sort of hardware issue. Car isn't running correctly with the Jb4 defeated.
Car: 2008 BMW 135i
Default 01-18-2018, 03:37 PM
what kind of hardware problem and what do you mean by the jb4 defeated? when i bought the car it had jb4 g4 board the old style so i took it out and bout the g5 board and put it in its only a few months old
Car: 2008 BMW 135i
Default 01-18-2018, 08:25 PM
i changed the plugs to one step colder one prong plugs and was told to gap them low what should they be gapped at
Dave @ Fuel-it!'s Avatar
Default 01-18-2018, 09:41 PM
.018- .022 seem to be the range most use
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
Car: 2008 BMW 135i
Default 01-20-2018, 11:37 PM
yeah thats what its set at
so i took the 2 step relay out and the car seems to do a little better i figured there might be to many things useing the same ground that it was messing things up but now its strong all of 1st 2nd and to the top of 3rd before it goes to map 4 it seems to be hitting almost 20 psi can anyone help me out there
Default 01-21-2018, 06:20 PM
Post a 3rd gear log now. WOT 2k to redline traction off
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
Car: 2008 BMW 135i
Default 01-21-2018, 09:15 PM
will do ill take one tomorrow
Smile 01-22-2018, 11:53 PM
Sounds like a plan
e92 AT 335xi 2.0
Pure Turbos
TFT Inlet System
Fueling by Fuel-It!
Car: 2008 BMW 135i
Default 01-26-2018, 11:31 AM
Sorry Iím about to take one now
Car: 2008 BMW 135i
Default 01-26-2018, 11:32 AM
Also I have a throttle booster think that could be doing it?
Car: 2008 BMW 135i
Default 01-26-2018, 01:27 PM
heres two logs
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 01-26-2018, 03:07 PM
Trims are pegged at 50.... And AFR's are pretty lean on those.
2015 BMW m235xi (F22/N55/EWG) | JB4 + BEF | Wagner Evo2 Performance IC | ER Chargepipe | K&N Dropin | Ground-Control v2 Camber Plates | Dinan Springs | HPA Adjustable Sway Bar Links
VMR V710's | Front 18x8.5 ET45 (235/40/18) | Rear 18x9.5 (265/35/18) | Hankook RS4
https://www.youtube.com/watch?v=dUvs...ature=youtu.be
Car: 2008 BMW 135i
Default 01-26-2018, 04:11 PM
people keep telling what it is but no one is telling me how to fix it im tired of it going in map 4 im ready to have some power
Default 01-26-2018, 05:32 PM
Best way forward, add in the free PUMP back end flash to extend your fueling range.
Car: 2008 BMW 135i
Default 01-26-2018, 05:41 PM
thank you will do
Car: 2008 BMW 135i
Default 01-26-2018, 05:42 PM
think doing a 30mix will help or make it worse
Default 01-26-2018, 05:43 PM
Worse, until fueling issues are addressed.
Car: 2008 BMW 135i
Default 01-26-2018, 05:48 PM
alright i figured
i need someone to do the back end flash for me haha i dont wanna wait for the cables to come in anyone near new bern nc that can do it for me? will pay haha
Default 01-26-2018, 06:32 PM
It's easy.. MHD is the easiest way to load it, their software walks you through everything.
