WaqasRiyami's Avatar
WaqasRiyami WaqasRiyami is offline
Car: Bmw 535i - 2011
Default 12-21-2017, 01:18 PM
Originally Posted by Mike_L
Bah, less power for PWG.
May as well just punch the firewall grommet and run the JB4.
Why is that ? Less power for PWG ?? Did MHD mention that PWG will make less power ?
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/XEO6ZpR.jpg |
Coming Soon: | Pure Stage 2 Turbo | Custom High Flow Inlet | GFB DV+ | Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 12-21-2017, 02:13 PM
Yeah, in the long post above, it shows less power for PWG.
Mike Levy
2017 X3 xDrive35i
Default 12-21-2017, 02:22 PM
Going to want both anyway!
Peter @ Pure's Avatar
Car: F20 M135i
Default 12-21-2017, 02:43 PM
pwg has less power because the compressor wheel of the stock turbo is smaller. It's a hardware limit.
F20 M135i (sold) - 100-200: 6.26
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
AZ-MCRacer AZ-MCRacer is offline
Car: 2013 535i (N55 F10)
Default 12-21-2017, 02:51 PM
Is the Compressor wheel on a PWG Pure Stage 2 = to an EWG Pure Stage 2, or is the EWG also larger on the upgraded turbo?
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1995 e36 M3 - Future Track Car
135idct 135idct is offline
Default 12-21-2017, 02:55 PM
finally
so now it's possible to hit high boost safe for big single n55 like the n54?
the maps for big single n55 will be same as the n54 ?
im ready for testing
Marlinman's Avatar
Car: 335i coupe 2010
Default 12-21-2017, 06:36 PM
and we still have BM3 to think about too, they hopefully will be making an announcement soon.
kevinjt kevinjt is offline
Car: F30 335i - 2014
Default 12-21-2017, 07:01 PM
Can i get more info on what are the options for us JB4 users? Will we be using both?? Flash + jb4??
What about the free maps? More info pleasee, sounds too good!
Default 12-21-2017, 07:13 PM
Similar to what we do for the E series: http://www.n54tech.com/forums/showthread.php?t=29236
Car: F20 M135i
Default 12-22-2017, 12:49 AM
EWG PS2 and PWG PS2 N55 are similar. The only difference is the turbo housing meaning the turbine side flange on EWG cars is 4'' compared to the 3'' PWG outlet. But the internal wheel combo is same and power gains are similar as well.
peter@pureturbos.eu
pureturbos.eu
Default 12-22-2017, 01:02 AM
Terry if i flashed an OTS will it not work with the JB4 ? I will be using either map 2 or map 5
akgambino akgambino is offline
Car: 2013 F30 335i xDrive
Default 12-23-2017, 08:39 AM
Wow this is all great news here! So excited that bms is offering free back end flash to guys who already have jb4, I was always wondering how this new obd dme unlocking would effect/benefit someone who already has jb4.
Anyways, a couple questions would be whether or not the Evolve-R cable from evolve automotive will end up working for this upcoming back end flashing (I have mine from my e46 m3 tune
Also, will the big time burble tuningg be avialable similar to the bm3 option for gunshot burbles with PWG?
Thanks a lot hope to hear more on this soon!
Default 12-23-2017, 08:44 AM
Will MHD option's as
1)burble 2) cold start cancel - be in the backend flash ??
Default 12-23-2017, 09:32 AM
Any chance somebody can elaborate on this comment? Are u trying to say that the flash tune for pwg from mhd makes less power than jb4 map 1 or 2 on pwg?
I am here for some understanding of what benefit the back end flashing will provide to me on my pwg n55 running the jb4 already. Will power delivery be smoother and more consistent? Will the back end flash in combination with jb4 make more power than just the jb4?
Terry or anyone can you explain the benefits we can expect on the f30 n55 pwg with jb4 and a back end flash?
Also what are you guys talking about punching firewall grommet? Lol
Default 12-23-2017, 09:34 AM
For a stock turbo PWG N55 I don't expect major benefits with the back end flash, but if your car has specific issues we'll have more tools to address those. For larger turbo PWG vehicles they really need a good BEF to be properly tuned.
Default 12-23-2017, 09:35 AM
Mike_L's Avatar
Anti-Social
Default 12-23-2017, 11:07 AM
I have an X3. I donít have the same extra grommet to run the OBD cable through as the F3x does. So to run the cable, I need to punch or drill a hole through the main harness grommet for it. Pretty sure it only applies to the F25/26.
Mike Levy
2017 X3 xDrive35i
Default 12-23-2017, 11:10 AM
I just poke a screwdriver through it, takes 3 seconds. And when you pull the OBDII cable back out the rubber snaps back in place so its not like anyone would ever notice or care if they did. You're worrying about nothing with that.
705's Avatar
705 705 is offline
Car: E90
Default 12-23-2017, 11:14 AM
X3 here too PWG, itís basically a circular cover that can be sealed back up if you wanted to uninstall the jb4 obdII wire. Just donít lose it.
Mike_L's Avatar
Anti-Social
Default 12-23-2017, 04:22 PM
I donít have that. I just have the one grommet that the main harness runs through. ☹️
Iíve seen people use the one behind the booster, but for some reason, mine is sealed. The hole is there under the hood, but itís not there under the dash.
Mike Levy
2017 X3 xDrive35i
705's Avatar
705 705 is offline
Car: E90
Default 12-23-2017, 07:41 PM
Thereís my punched grommet 😅
Saved the grommet Incase it gets too cold, havenít needed it yet.
The hole is a bit big for that one obdII cable.
trebila's Avatar
trebila trebila is offline
Default 12-24-2017, 06:19 AM
Once released by MHD, I'll provide full tuning support on F series, as I already do for N54-N55 E series, as long as it's stacked with a jb4.
Can't wait to tune thoses babies.
Default 12-24-2017, 06:25 AM
So your tunes will be like backend flashes's ? Not like OTS maps ? I really want to get my car tuned by you
, so if yes you make tunes that work with JB4 , i will be your first customer..
trebila's Avatar
Default 12-24-2017, 09:05 AM
Absolutely.
Default 12-24-2017, 09:07 AM
Absolutely.
Great, Sign Me in
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
katsooba
