Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default Msd81 vs msd81.1 vs msd81.2 - 10-22-2016, 06:55 PM
Hi
Going to swap my msd80 to 81 but found that they are different versions of it
Msd81, 81.1 and 81.2
Does anyone know what is difference between them?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-25-2016, 01:34 PM
stick to 81, 81.2 is for 4 bangers I think.
Why swap DMEs?
the imitator the imitator is offline
Car: e30
Default 10-25-2016, 01:51 PM
Making an assumption here, but I want to make the move because I'd rather replace the dme before the MOSFETs go boom. I think he may have the same reasoning.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-25-2016, 01:59 PM
Get new, quality coils I think that's most of the time the issue that causes mosfets to go south.
Car: e30
Default 10-25-2016, 02:21 PM
I definitely agree with the concept of "replace before anything goes wrong", however perhaps to educate me further here.. isn't it a mixed result? I thought it also had to do with folks slowly going FBO and the demands as such. I only ask because why replace if it's truly just preventative maintenance killing the MOSFETs. Surely save me a little change.
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 11-05-2016, 08:47 AM
Originally Posted by Taron
Hi
Those MSD81 variants are for different engines, besides, it's not as simple as just swapping DMEs...the CAS module and the DME exchange a rolling code referred to as the ISN. The DME will not enable ignition or fuel injection until a valid ISN is received. You realistically have three options:
  • Purchase a new DME and BMW will ensure that the ISN matches your CAS.
  • Purchase a used matched set (keys/DME/CAS) from a donor vehicle.
  • Purchase a used DME and find an indy with the proper tools to read the ISN and write it to your existing CAS module.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
duracell8 duracell8 is offline
Car: 2008 535i
Default 11-07-2016, 08:29 PM
Cheaper to get a dme from the power performance package than a replace to stock dme from bmw. Save around $500 retail. They change to the msd 81.
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Jo335i Jo335i is offline
Car: Bmw 335i e92 2007
Default 01-19-2018, 05:25 PM
I have bmw 335i 2007 and I put mhd stage1 atock map and my dme mosfets fried together with injectors and this happened on the very first test drive after the installation of mhd tune. . The injectors were index 1.i boight used dme and replaced all 6 mosfets and I got all 6 new injectors index 12. Changed also spark plugs and new coils. But NOW i am afraid to try the mhd map again.
I was carless fpr over a month.
Default 01-19-2018, 05:26 PM
What do you think? Should I try again the mhd map?
Haynpunch's Avatar
Car: 07 E90 335i
Default 01-20-2018, 05:38 PM
Mosfets going bad are a 50/50 deal. replacing them works sometimes but they tend to go bad again. swap to MSD81 never worry about it again. there are a few places that will do the swap in a timely manner. I had mine done locally (Norcal) so I didn't have to deal with sending my CAS and Key to program the new DME.
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Default 01-20-2018, 05:47 PM
In my country is difficult to find someone to do the swap (🇭🇷 croatia). Only thing would be to send the ecu overseas for somebody to do it.
aus135i aus135i is offline
Default 01-21-2018, 01:07 AM
Just replace the mosfets in your current ECU. Save heaps of time a money. Once the new components are installed the ECU will not fail again. Apparently the Mosfet's used at the factory were flaky components. There is a DIY on youtube. If you are worried about DIY, any competent TV repairer or electronics tech will be able to perform the work.
Haynpunch's Avatar
Car: 07 E90 335i
Default 01-21-2018, 06:42 AM
Originally Posted by Jo335i
In my country is difficult to find someone to do the swap (���� croatia). Only thing would be to send the ecu overseas for somebody to do it.
Didn't realize you were out of country.
things we take for granted
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
