woopig woopig is offline
Car: BMW 335i
Default Bad o2 sensors throwing misfire codes? - 01-20-2018, 12:38 PM
My 335i has violent shaking on idle today, any anywhere from 1000pm to 3000rpm but I did not push it much higher than that.
Car is currently throwing these codes:
29CC - misfire several cylinder
29CE - misfire cylinder 2
29CF - misfire cylinder 3
29D1 - misfire cylinder 5
29E0 - mixture control
2E9F - oil condition sensor
I took the tune off, but that didn't take away the misfires. I then reset codes and now it's only throwing a cylinder 5 misfire code. Plugs have about 10k on them, half the coils were replaced a year ago.
Could these all be from the bad o2 sensor? How would I know which sensor is bad? I also bought the d/p fix wires after getting my d/p installed, but I haven't installed it yet. Would that help since it would then ignore the rear o2 sensor, which could be throwing the codes?
Mods: ********* d/p, vrsf intercooler, stage 2 tune (currently off)
Thanks for the help.
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 01-20-2018, 01:11 PM
There was a tread were changing them out netted better fuel economy and a smoother running engine, they won't have any barring on a straight misfire. If your a/f ratio is way off, it may throw a code, look at a scammer and watch for inconsistency.
Car: BMW 335i
Default 01-20-2018, 01:13 PM
Should I do some MHD logs and post them here?
Car: BMW 335i
Default 01-20-2018, 01:32 PM
Here's a link to my log just driving around the block.
https://***********/u/chadpinter48/l...og=0&data=3-21
Edit: Just put data/zap/.me in the asterisk part. no /
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default 01-20-2018, 11:01 PM
Misfires can have any number of reasons, but definitively can be O2's. I had misfires around 90k miles that went away after I did new sensors (primary only). I think I had also a jb4 lean safety around that time out of the blue which never came up again.
2007 335xi -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC -- RB PCV
JB4 + BMS bef (E50)
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 01-21-2018, 09:55 AM
Agreed. You also must reset the adaptions when you change the O2's
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
Default 01-21-2018, 10:26 AM
Were you throwing 02 codes, or you changed them and it relieved it?
yellowfin's Avatar
Default 01-26-2018, 05:00 PM
I got a 2C3E once that was maybe related, but not together with the misfires.
JB4 + BMS bef (E50)
