lalillo89 lalillo89 is offline
Car: 220i
Default B48 jb4 unkown error codes - 01-19-2018, 11:47 AM
Hi, Does anyone know what do these codes mean? I'm using the BMS cable to read logs or codes.
11B030
11B033
11A031
This is on a 220i 2017 with BMS air filter and JB4.
Default 01-20-2018, 07:16 PM
We would need the code descriptions. You may need to read them with an OBDII reader.
Car: 220i
Default 01-20-2018, 09:54 PM
Thanks! I will scan for it.
Also here I have some logs (Map 5 and 3) of my B48 220i, it only has BMS air filter, 92 Oct + MMT octane booster.
What I'm seeing is that Ign 1 sometime is = 0, is that normal when I WOT?
Also I don't know if I'm having timing drops.
I was thinking to switch to Map 6 with something like this:
1500 - +4.0
2000 - +4.5
2500 - +5.0
3000 - +6.0
3500 - +6.5
4000 - +7.0
4500 - +7.5
5000 - +7.5
5500 - +7.0
6000 - +6.5
6500 - +6.0
7000 - +5.5
Default 01-22-2018, 11:58 AM
Your 1st gear boost limiter is set to 1.1psi.
I'd suggest adding the EWG wires.
Timing is low, it may be due to fuel quality.
Car: 220i
Default 01-22-2018, 12:09 PM
Thanks Steve, I will buy it.
I have been searching here but when you say that timing is low is because the ign1 is equal to 0?
Car: 220i
Default 01-22-2018, 02:44 PM
Hi, I was looking for the EWG connector, do I need to also buy the FF cable to enable the EWG feature?
Default 01-23-2018, 10:05 AM
No, FF wires are not required.
Car: 220i
Default 03-15-2018, 02:00 PM
Hi Steve,
I just received my EWG cable. Just to double check, do I need to follow the installation guide for N55? It says:
1)The purple wire (going to the male pin on the wastegate harness) connects to position #9 on the DB25 connector.
2) The blue wire (going to the female pin on the wastegate harness) connects to position #16 on the DB25 connector.
Also It says that I need a specific EWS but for B48 there's only one firmware. Then with this cable which changes do I need to apply?
Thanks,
EBE
Default 03-16-2018, 09:03 AM
Yes, install the cable as instructed and then set all your user adjustment values back to default and do a few adaption runs. All B48's are EWG so there is no specific firmware.
