(#876)
Marlinman's Avatar
Car: 335i coupe 2010
Default 02-11-2018, 07:34 PM
Terry,
Would a new FW require this type of adjustment? I'm wondering why boost was relatively on target in v9 and then since v10 it got all wonky on me and overboosted. Could have something to do with the auto DB tuning and just needing a few runs? Thanks!
cnm135i cnm135i is offline
Car: m135i
Default 02-11-2018, 07:37 PM
Terry
I have now done A LOT of runs with the ISO 10 but still get a consistent dip in boost after tip in. DB does not seem to adjust this by itself. Can we use a FUD bit to turn the DB auto-tune on/off?
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
Default 02-11-2018, 09:47 PM
Originally Posted by cnm135i
Terry
Manually adjust 1500 and 2000 points down as needed to avoid the over boost.
FUD bits are not active currently but we'll add them next version. Also added a setting for metric dash.
Looks like your timing is set too high. And we might be able to disable the under boost fault now. Still using BM3 or did you switch to MHD to run our BEF? I can't remember.
Car: m135i
Default 02-11-2018, 11:55 PM
Let me emphasize that the over boost does not bother me (I have tried to comminicate this several times). It is the following under boost that annoy me. Running the BM3 BEF here but with 91AKI instead of my usual 93 - that probably makes the difference on the timing.
I'll try to adjust DB manually - hope the auto-adjust does not fight back.
Marlinman's Avatar
Default 02-12-2018, 09:36 AM
Originally Posted by Marlinman
ISO 10 latest log. I am over boosting like crazy. Haven't changed any user settings since last FW version.
Any input to help lower my overboost? Seems to feel alright but I want to be more on target. WOrk computer won't allow me to post log (it is located on previous page #874) Thanks!
Default 02-12-2018, 09:39 AM
I already told you to lower your FF.
Default 02-12-2018, 09:40 AM
I would be interested to know if it does. Given how the algorithm is setup now the learning is limited in the 1500-2000rpm range. It can't learn until you're fully spooled.
Marlinman's Avatar
Default 02-12-2018, 09:48 AM
Thought you were responding to someone else, my bad! Will do and re-log. Thanks.
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 02-12-2018, 11:58 AM
If learning is limited only in the 1500-2000rpm range, then why did my DB's change across the whole rpm range ?
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
Default 02-12-2018, 12:23 PM
You're reading my statement incorrectly.
Marlinman's Avatar
Default 02-12-2018, 12:44 PM
waqasrami: He does not mean the learning is limited to low RPMs, he means the learning is mainly happening outside of those low RPMs because your turbo is going to be spooled up in the higher rev range, hence learning will occur. It will not occur that much down low because the turbo hasn't yet spooled. Hope that clears it up.
Default 02-12-2018, 12:53 PM
Thanks, Got it now
oneilkelly78 oneilkelly78 is offline
Car: 2011 bmw 535i manual
Default 02-12-2018, 12:55 PM
has anybody tried the iso 10 on a f10 n55 manual?
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 02-12-2018, 01:24 PM
Originally Posted by Mike_L
Is MHD selling to the public now? Apparently my AT&T tablet isn't compatible for some reason, but Android tablets are so cheap I can give it a shot.
MHD emailed me on Feb 5 with timing:
"our f-series app is now in closed beta testing, the public release is expected in 2-3 weeks"
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 ISO_11 - Map 5/93 octane for winter/Custom tuned exhaust/stock turbo/Resonator Delete=Pops and Burbles!!
Stage 2 LPFP Walbro installed and strong, yeah I built it myself!
Coming Summer 2018: Speedtech BW 8374/PI/Dual Walbros/MHD BEF and Tune by Trebila = epic Summer!
Car: m135i
Default 02-12-2018, 06:24 PM
Can you shed some light as to what happened on the second pull here? First pull looked great until DME_BT dropped...
(Tested a map revision from Halim that might help with +20psi DME_BT drop - but that did not work)
Default 02-12-2018, 06:59 PM
I don't see why FF would change dramatically from one pull to the next at the same RPM. The tuning constants must have changed between the runs, but I can't see those in the log. Only thing I can think of is the internal EGT modeling. I'll disable that and shoot you a firmware.
Car: m135i
Default 02-12-2018, 07:20 PM
I am also rather confused as to what happened in that map6 log. I did these map3 and map6 logs minutes after and they look nothing alike. I dont usually run map6 with meth so will probably never encounter this problem again, but I guess you'd like me to for the trouble shooting with the new FW??
Car: m135i
Smile ISO 10_T4 - PS2 at full tilt - 02-13-2018, 05:03 AM
PS2 at full tilt...
Long time since I have done this in map6, but the was a very ****y S3 (he is not so ****y anymore)
6th gear DME_BT dropping - old news. Hopefully PTF/MHD will come up with a solution for this. However in the second pull it didn't /
Boost - also old news. But why is it that I get more boost in higher gears? 25psi in 4th and 5th would be pretty badass!
hardparker hardparker is offline
Car: F25
Default 02-13-2018, 09:51 AM
More boost in higher gears is typical. The loads are higher and the turbine has more time to spin up to higher boost levels. You're in first through third for such brief periods of time, the turbine just doesn't have the time duration and load needed to get to higher pressures.
I've been thinking that FF on a per gear basis would be nice and could help some in that regard.
Car: m135i
Default 02-14-2018, 08:33 PM
Finding it hard to believe that the time I spend in 4th/5th gear isn't enough for the turbo to spin?? FF is maxed out but I see that PID is set to 15. I'll try increasing that to default 25 and see if that changes anything.
Default 02-14-2018, 08:49 PM
PS2 at full tilt...
EGT increases in higher gears allowing you to hit target. WGDC > 90% means the wastegate is fully closed.
Car: m135i
Default 02-14-2018, 10:23 PM
OK, nice info. Thanks
peopleschoice1 peopleschoice1 is offline
Car: f30 335I
Default 02-16-2018, 12:39 PM
mod list
Bootmod3
vrsf intercooler
cts intake
vrsf charge pipe
vrsf ******* ********
3.5 gallons E85/93 octane
My car feels inconsistent during a pull. Anything in my settings I can do to help. I'm on the default ISo settings.
Default 02-16-2018, 12:42 PM
Originally Posted by peopleschoice1
mod list
Bootmod3
vrsf intercooler
cts intake
vrsf charge pipe
Bootmod3 BEF or Tune ??
Car: f30 335I
Default 02-16-2018, 01:12 PM
bootmod3 BEF
