5Dirty5's Avatar
5Dirty5 5Dirty5 is offline
Car: 2008 BMW 535I
Default Car feels unsafe on freeway excessive sway - 01-31-2018, 03:53 PM
2008 BMW 535 with sport package, a few weeks ago had a warning light on the dash about dynamic stability control, pulled up at the house check the power steering fluid noticed it was low so I topped it off, ever since then the car feels unsafe on the freeway At speeds above 65 miles an hour excessive swaying back-and-forth the car literally feels like the sway bars are disconnected.has anybody dealt with this issue? Literally have the same sensation as being blown around in the wind, and forget sudden lane changes, as they’ll make your butt hole pucker
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 02-02-2018, 04:29 PM
Your car is getting old.. 10 years.. Have you ever serviced the struts? Checked the control arm/tie rod ball joints? Struts don't last forever. Best to check everything, or have someone familiar do a full inspection. There is no wizbang answer most of it involves some physical work to get in there and check out your car
2015 BMW m235xi (F22/N55/EWG) | JB4 + BEF | Wagner Evo2 Performance IC | ER Chargepipe | K&N Dropin | Ground-Control v2 Camber Plates | Dinan Springs | HPA Adjustable Sway Bar Links
VMR V710's | Front 18x8.5 ET45 (235/40/18) | Rear 18x9.5 (265/35/18) | Hankook RS4
https://www.youtube.com/watch?v=dUvs...ature=youtu.be
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-03-2018, 08:57 AM
This is something that happened instantly. My car has dynamic drive, and active steering so I’m guessing one or both of these are offline at the moment
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 02-05-2018, 09:42 AM
Is anything leaking from the dynamic drive / active sways? Common problem unfortunately on 5'er.
Sure the fluid reservoir is fully sealed after you opened it? Has it dropped again since you filled it?
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 02-08-2018, 09:53 AM
Did your warning light go away or still on? Any codes stored?
It might require a module reset or ISTA diagnosis. A BMW indy shop should be able to do it easily.
Physically, look for leaks from ARS lines, and at the ARS elec motor. And keep a close eye on fluid.
2009 535i Sport
Software: JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: GC Lites | Inlets | Outlet | 3" D-P's | 7" FMIC | S2 LPFP | TBI | DCI | ER CP | Forge DV's | 3.5 TMAP | RB PCV | Koni FSD
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-08-2018, 11:50 AM
No the warning light only came on briefly as I was making a right hand turn, as far as leaks it’s hard to tell because currently I’m attacking all of the OIL leaks that this car is plagued with. So engine is pulled apart doing front crank seal, both oil cooler gaskets, valve cover gasket, and I’m going to do a walnut shelling on the intake valves while I have it all opened up
LessIsMore's Avatar
Inner Circle Member
Default 02-08-2018, 06:14 PM
should be even easier then!
if no leaks and/or fluid level is not dropping, hook ISTA up to it and run a diag on the ARS/PS system and modules.
2009 535i Sport
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-08-2018, 06:22 PM
Sorry but I don’t have ISTA I’ve heard of it but I haven’t downloaded it or used it yet
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-18-2018, 06:10 PM
I finally got ISTA installed and running. How can I run a diag on the ARS/PS?
5Dirty5's Avatar
Car: 2008 BMW 535I
Default 02-18-2018, 06:21 PM
Anyone know how to use ISTA-D??
