dargorbr's Avatar
dargorbr dargorbr is offline
Car: wrx
Default n20 Map 6 Log - 10-11-2017, 04:48 AM
Hi there, can you guys take a look at my logs
I'm running jb4 stage 2 on a 320i using e100
what should I monitor on FP_H ?
usually it sticks at 18, but on the logs there is a dip to 16
are these values the same as for the N54 on the 'Logging Parameters and their meening' thread?
Default 10-11-2017, 06:15 PM
Wow...I'm guessing you are in Brazil?
I looked at a couple logs and they looked fine to me.
HPFP in the teens = good.
dargorbr's Avatar
Car: wrx
Default 10-12-2017, 07:17 AM
Yes sir, Brazil!
That's good to know, I was worried because it dipped below 18 hahahaha
Default 10-12-2017, 04:34 PM
No, you're good! Would be pretty cool if that DME flash could be located and made public.
dargorbr's Avatar
Car: wrx
Default 10-14-2017, 10:27 AM
How can I help with that?
Can I locate the file with coding?
Car: All of 'em
Default 10-14-2017, 11:42 AM
Drive up to Texas, I can read out your binary and get it to them :D
Default 10-15-2017, 03:22 PM
That would be one for the flash guys to sort out...maybe MHD can investigate and see if they can unlock/obtain that factory flash.
dargorbr's Avatar
Car: wrx
Default 10-16-2017, 04:39 AM
that would be a problem, I'm from brazil hahahaha
If we discover which flash from coding it is, wouldn't we be able to flash with esys as well?
Default 10-16-2017, 10:27 PM
I'm not familiar with esys.
dargorbr's Avatar
Car: wrx
Default 10-30-2017, 05:30 AM
hey guys, I've just figured that the brazil 100% ethanol car has different lpfp and hpfp
here are the part numbers for you guys
hpfp: http://www.realoem.com/bmw/enUS/part...&q=13518635048
lpfp: http://www.realoem.com/bmw/enUS/part...&q=16117344068
maybe this should help with running more E85 mix on the US cars
also, through realoem i saw that the brazil active flex car has the low compression piston as the 328i
so it has 10:1 and can probably withstand more boost that the US one
