(#451)
NyVetteMiniGuy's Avatar
NyVetteMiniGuy NyVetteMiniGuy is offline
Car: 2017 Mini Countryman All4 S
Default 01-29-2018, 11:50 AM
So I went for my first oil change to the dealership and disconnected the JB4 prior to going to the dealer...reconnected it when I came back home...Overkill or necessary step? I don’t want my warranty voided...
Default 01-29-2018, 12:33 PM
Originally Posted by Jay1312
I see there a hex 12 file for b48/b58; is there a similar update on the b38/b48 or can the same file be used?
We have not posted an update for the MINI B38/B48, only BMW side, for now.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 01-29-2018, 01:58 PM
Hi Terry,
Thank you for your reply. Not sure if you are aware but this same b38/b48 engine is used by bmw 2 series active tourer and grand tourer. Knowing your work on the main b48 3 series your input to this section could potentially increase the community interests across both the 2 series and the mini product lines.
I see the difference in performance between this variant and the main b48; hoping you can show some of your magic here too.
Keep up the great work and keen to test your S4 development as per your email.
gbsbond gbsbond is offline
Car: Mini F56 S
Default 02-07-2018, 12:12 AM
My local tuner ask me to get an WMI kit for the F56S B48 before custom tune the Mini, so Im looking to buy a WMI kit from BMS, anyone can guide what nozzle is the right one to buy from their store, is the lastest jb4 firmware capable to handle WMI? Any other important tips to consider?
Thanks for your help!
Robmaster's Avatar
Robmaster Robmaster is offline
on JB3 2.0 Map5 now!
Car: E92 335i M-Sport, Porsche 944
Default 02-13-2018, 11:42 PM
I had a lot of CEL's the last two weeks. No power loss, also no fault in the BC. Just the yellow CEL.
If I scan it I got the code 1212 (No description found)
also if it's cold outside, the engine doesn't work smooth in the 2nd & 3th gear for some seconds when I start driving.
If I deactivate the JB4 (Map0) everything is fine....
So for me the JB4 is crap and I will sell it and go with a real tune (Software).
Also the service from Burger is really bad here at the Mini section.
Oh and also the JB4 App doesn't work correct, it doesen't show the oil and water temp.
Car: Mini F54 Clubman JCW (6MT) and drive Map1
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 02-14-2018, 09:13 AM
Sorry you are having issues with the tune on the car, but we can't do much unless we get
install photos for the JB4, bluetooth kit and data log.
Robmaster's Avatar
Default 02-15-2018, 04:02 AM
Why you need install photos?? The JB4 runs good for about 3-4 months, and now I have the CEL all day!
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-15-2018, 09:14 AM
Ok send us data log and fault coded through JB4 code reader.
Robmaster's Avatar
Default 02-16-2018, 12:38 AM
Fault Code: 1212 No Description Found
Is there a DIY for th loggin?
Also the CEL come every time if i start the car, drive some miles (1-5miles) and the shut it off and the when I start it again, the CEL is there.
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-16-2018, 10:21 AM
Here is a video on how to do logs.
Robmaster's Avatar
Default 02-18-2018, 11:46 PM
Got an ass full of codes this morning incl. power loss and error in the BC.
Here the codes:
0112 No Description Found
1532 No Description Found
1204 No Description Found
I'm done with this Piece of ****, I will deinstall it an sell it!
Jay1312
Default Yesterday, 12:19 PM
Any chance gauge sweep can be added to the b38/b48 minis. Good to have this as standard right across if possible.
