tylerd tylerd is offline
Default N55 ******* ** with N54 secondary cats - 05-04-2018, 07:22 AM
I asked this in another forum, but no one had any thoughts about it, so it seems.
I was thinking about getting a catted down/pipe from wagner, but read that the gains are less over a catt/ed down/pipe.
Problem is, I would still like to have a ca/t to prevent fuel smell etc.
So I thought why not take a ***/less down/pipe for better airflow directly after the turbo and then have the secondary underfloor cats of the N54?
Wouldnt that be the best of both worlds?
Does anyone know the how many cells the original underfloor cats have?
Thanks alot!
Edit: Whats wrong with the *** all the time?
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-04-2018, 07:42 AM
I have heard of people doing that, but the mids can take some extra abuse in that setup since there is nothing upstream to help them out. If you aren't doing anything crazy it should be fine, but if you plan to run heavy meth/e85 or NLS type stuff, or track the car, you might want to check them from time to time. Honestly the N55 single downp's are pretty fat so it flows pretty well even with cats in most stock turbo situations I would think.
As far as the ***'s, BMS is based in California so there are some restrictions on certain emissions related keywords...
prime300's Avatar
prime300 prime300 is offline
Car: E90 335i xDrive N55
Default 05-07-2018, 03:53 PM
Dunno what car ure driving but the xDrive e9x chassis with N55 got second cats... i personally have no ***s only the 2nd & the smell is not that bad(i have e90 335 xDrive 2011)
Paul C.
Stoolz Stoolz is offline
Car: 11 135i
Default 05-07-2018, 07:49 PM
I did this but with custom ones welded onto the BMW PE Y piece. (Or thereabouts).
Sounds WAY better and smells heaps better. No performanceloss to speak of.
