Snowman Snowman is offline
Car: BMW M135I
Default XDF file for map reviewing in Tuner pro? - 04-19-2018, 09:08 AM
Im looking at reviewing some of the different maps for a M135 EWG and a M2.
Ive downloaded the Tunerpro software and installed it, but i have been unable to obtain the XDF-files for the software..
Could someone point me in the direction to where i can get a hold of the XDF?
Default 04-19-2018, 09:15 AM
MHD has not published those yet for F series, but will shortly.
Car: BMW M135I
Default 04-19-2018, 09:17 AM
Ok thanks for the swift reply!
Have no intention of actually changing anything, just want to learn the software and be able to review and understand basemaps.
Car: BMW M135I
Default 04-20-2018, 04:36 PM
Okay i just got access to the XDF-files from MHD but are trying to understand the X-axis in Tunerpro.
What is the X-axis used for?
I first thought it was something like throttle input or perhaps temperature?
But can really understand what is it for..
Y-Axis is for RPM, but what are X-axis being used for?
Im currently looking at the timing table.
I just recalculated the X-axis values from F to C and realized that they might be temperature in F.
Is that the case?
Ariano Ariano is offline
Car: 09 E92 335i
Default 05-04-2018, 03:55 PM
I am looking to get the TunerPro for my Jb4 with MHD BEF. Can you please advise on where I would be able to purchase or download this??
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 05-05-2018, 12:23 AM
Is that the case?
I don't have MHD xdf, but probably its LOAD. you know our cars use a load based maps.
N55 - Doc race 6266.
keyap keyap is offline
Car: N55 135i
Default 05-05-2018, 12:44 AM
The ones which are released can be found here:
https://github.com/dmacpro91/BMW-XDFs
Car: 09 E92 335i
Default 05-05-2018, 01:44 AM
Ok, thank you Keyap. I downloaded the TunerPro, now I just need to find the XDF and ADX files. I went to GitHub and noticed 8 files. would you happen to know what file I should down load?
Car: N55 135i
Default 05-05-2018, 02:10 AM
I an early N55 so definitely know that:
98GOB is for early E N55s - usually from launch until somewhere between ~01/12 and 03/12
I think the others are:
9E6OB is for late E N55s - usually from somewhere between ~01/12 and 03/12 to production finish
Other XDFs are for the E N54s - there's 4 so my guess would be it depends on what ROM/DME is installed? Perhaps others can confirm?
Car: 09 E92 335i
Default 05-05-2018, 08:46 AM
Ok Keyap, again thank you. I am an 09 N54, not sure what my codes are.
Car: N55 135i
Default 05-06-2018, 01:05 AM
You may want to take a look at the N54 Back End Flash Maps thread:-
http://www.n54tech.com/forums/showthread.php?t=29236
This was lifted from it:-
Software Version: IJE0S for MSD81 (most 2008 and newer cars), I8A0S for MSD80 (most 2007 and early 2008), INA0S for 335is models, and IKM0S for 1M models.
Car: 09 E92 335i
Default 05-06-2018, 06:13 PM
Thank, I'll take a look.
