Default M5 JB4 Pump Gas Dyno Runs - 10-05-2015, 05:31 PM
Was able to get our 2015 M5 out to the dyno today for some JB4+BCM pump gas dyno runs. Fuel is 91 octane with a can of NOS octane booster added. So around 92.7 octane. Similar to 93 octane most out there run. The car is otherwise stock except for our prototype intake.
Limited on time today so I'll just share some of the data. Did a few runs on map 4 (stock), map 1 set to 19psi, and map 2 set to 23psi. We runs in both 4th and 5th gear in each configuration and then posted the best of each. As most know 5th is the 1:1 gear and results in higher HP on the dyno. But with the 155mph speed limiter doesn't let you rev past ~6200rpm.
Overall results were as expected. Fueling and octane started to become an issue on map 2 as tested so I think we'll keep that around 22psi moving forward. Map 1 is a nice conservative setup suitable for even 91 octane fuel in warm weather. We appreciate that most people running the JB4+BCM will be shooting for the 700whp+ figures on meth and/or race gas but its nice to know even on pump gas the potential is there for more power under the curve than Stage1 alone is able to provide.
We also did a few runs without the intake for kicks. The intake added a handful of HP up top and improved spool. Nothing major. But it does sound great. We'll post more on that in the coming weeks. For now here is a video we took of it during a map 1 run.
PLF's Avatar
PLF PLF is offline
Default 10-05-2015, 05:35 PM
What is the ''stock'' map 4 target ?
BRBOOST's Avatar
BRBOOST BRBOOST is offline
Car: 2015 M235i
Default 10-05-2015, 06:26 PM
Nice numbers!
Any guess what 95 octane fuel *US RATING* with around E20/25 would put down for map 2?
Any clutch slippage at all for map 2? Would a DCT reflash be recommended for Map 2 or not needed?
Default 10-05-2015, 07:39 PM
The stock tuning peaked around 15psi in these conditions.
Originally Posted by BRBOOST
Nice numbers!
23psi slips on the road. 22psi is right on the cusp of being OK. Might be a problem for older cars. A DCT reflash would be pointless. The only way to improve the holding capacity is with aftermarket DCT clutch packs.
BRBOOST's Avatar
Car: 2015 M235i
Default 10-05-2015, 07:46 PM
Would clutch slippage depend on how the car is driven (if it was/is launched all the time) or just simply slips no matter how much you take care of it? Last question, with the new DCT clutch packs, a DCT reflash wouldn't be needed? Thanks again!
Default 10-05-2015, 07:48 PM
On slippage there is a large amount of randomness too it. But most M5s experience it in the 650wtq range. Some get it sooner than others based on driving style, weather, etc.
The clutch packs are plug and play. Just drop in and go.
BRBOOST's Avatar
Car: 2015 M235i
Default 10-05-2015, 08:07 PM
Makes sense. Thanks for clarifying. Nice to know they're plug and play. Hopefully not a fortune or too hard to replace. Who sells them in the US? I have also heard about a wheel sensor that could relate to DCT problems... Local tech told me. Will talk to him more about it.
sA x sKy sA x sKy is offline
Car: 2011 E92 335xi
Default 10-06-2015, 01:43 AM
Don't forget about the DCT reset via Autologic or Rheingold.
lfelunden's Avatar
lfelunden lfelunden is offline
Car: 335i e92
Default 10-06-2015, 05:01 AM
Seems like timing is dropping a lot, this was what I saw with my car too.
With a flash it is simply a different car, but, without the JB4 to log, it wouldn't perform any good
Default 10-06-2015, 09:05 AM
Timing is pretty good here. Sloping up towards redline, at least in the 2 cylinders we're monitoring. Where the flash would come in handy is on the fueling side at > 22psi on pump gas. But then you have the DCT limit at that point anyway. Also the flash has to be done properly otherwise you'll just run too rich and misfire.
lfelunden's Avatar
Car: 335i e92
Default 10-06-2015, 09:06 AM
Yup! I haven't seen slippage yet.
Default 10-06-2015, 09:10 AM
+1. I'll have to add this command to the JB4 as well in the future.
mike@x-ph.com mike@x-ph.com is offline
Car: 2007 e92 335
Default 10-06-2015, 10:01 AM
Nice numbers !!
Default 10-06-2015, 10:05 AM
Just noticed I forgot to add torque to the map 1 run. See attached.
Irishace's Avatar
Irishace Irishace is offline
ElevenPointFive
Car: 2009 135i
Default 10-06-2015, 07:00 PM
These M5/6 are nutz.
2007 Porsche 997 Turbo - 6MT - Midnight Blue
Cobb Stage 1
2008 E90 335xi - AT - TSM
MHD Stage 2+ ~ BMS Intake ~ AMS FMIC ~ CPE
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 10-06-2015, 08:31 PM
Nice to see real world usable numbers - what were you seeing at 23psi that made you choose 22psj as the 'max' for standard 91-93 octane conditions?
TTM5 TTM5 is offline
Car: M5
Exclamation 10-06-2015, 08:55 PM
Why do both map 1 and 2 dive to 540whp @7000rpm ?
Default 10-07-2015, 01:05 PM
Probably a flow limitation of the factory turbos, exhaust, etc.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 10-07-2015, 08:14 PM
I may be missing the obvious but what is BCM? Also, is the stock clutch in 6MT able to hold more power than the DCT at high torque?
Car: M5
Default 10-07-2015, 09:16 PM
Why would the turbos be able to flow 600+whp at 6000rpm but only 540whp at 7000rpm, does not seem to be a turbo flow problem....
Default 10-08-2015, 08:24 AM
The BCM is a module that adds on to the JB4 to give it direct wastegate control. There is some addl info on it in the S63tu JB4 thread. I've never actually seen or driven a manual M5 no less pushed one to high power levels so I couldn't tell you on that.
Newguy123's Avatar
Car: 12' 135i
Default 11-12-2015, 08:58 AM
hey T ill be helping a friend tonight finish the S2 install on his s63, do you have any custom map 6 settings anywhere for c@tless/pump gas? he has no meth so i know 21psi is probably tops. we just want to play around later and would like to hear you thoughts on boost targets if everything looks good in map 1
12' DCT 135i
#PURETURBOS
#FUELIT
Default 11-12-2015, 09:20 AM
JB4 you mean? I'd evaluate map1 and map2 (if equipped with BCM).
Newguy123's Avatar
Car: 12' 135i
Default 11-12-2015, 09:22 AM
yes, he has the full bcm etc etc...ok thanks sir!
12' DCT 135i
#PURETURBOS
#FUELIT
