Default Just another 1000whp M5 - 01-26-2018, 06:28 PM
For those that missed it, Ram managed to break the 1000whp barrier with his M5 this morning. Setup is custom Pure turbo kit, built motor, WMI, BMS intake, and various other mods. Tuning done using our new JB4 S63TU V2 system (with twin bank boost control), back end flash mapping (Ram can fill in who the tuner was there I can't recall), and various other minor modifications.
Ran in to DCT clutch spin as the turbos have a lot more in them. But power band is amazing. Definitely 180mph+ traps coming to a runway near you soon.
Log below was from a 980whp run, IIRC. I believe he had to lower the boost to reduce slippage and get power over 1000whp.
Default 01-26-2018, 07:28 PM
Congrats Ram!! Holy moly, is that 17*?
Default 01-26-2018, 08:35 PM
He's running more timing than I'd suggest but then again I don't know the final CR... Once the clutches are beefed up he'll need to do some MBT dyno testing with it.
135idct 135idct is offline
Default 01-26-2018, 09:01 PM
from the log, too much lag.
pump gas 93 dyno sheet?
Default 01-26-2018, 09:03 PM
Spool is good for large turbos. Feels responsive on the road as it moves even at 10psi. This car will probably never see 93 octane, lol.
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 01-26-2018, 09:44 PM
I have various timing maps - this was +2 degrees over stock (which is 15* assuming no knock/retard). Compression is lowered 0.5 so should be fine with the appropriate octane.
Backend flash was from DMETUNING and Kevin @ Precision. So far all the extra mods arnt in yet. Still have exhaust, ice tank etc. to install.
The dual bank WG control works amazing - thx Terry and BMS
Default 01-26-2018, 10:15 PM
https://youtu.be/lpCHB4qvKSY
steeve13m steeve13m is online now
Car: 13 M5 DCT
Default 01-29-2018, 01:44 PM
they are cropping up....I think there's 3 M5's now with 1000whp+ ?
2013 F10 M5 -DCT- Montecarlo Pearl Blue- BBMR 800 Stage 1 Twin Turbo system 700whp+ on 93 octane, BBMR D.P./Exhaust, Intake, HRE FF01, AC Schnitzer springs,Lucas Octane Booster, 5% 3M Window tints,Clear protection film,LED interior bulbs,Blinder M27,Escort Passport MAX,12" Sub+Amp,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Default 01-29-2018, 03:14 PM
There are two... since requirements for this power level are:
1. Built motor
2. Custom Turbos (stock housings will not cut it..)
Default 01-29-2018, 03:27 PM
1. Built motor
Will this void my warranty?
Default 01-29-2018, 04:05 PM
Dealer did my oil change and fixed my sunroof... ��
Default 01-29-2018, 04:44 PM
Not if you clear the codes and pull the Jb4 off right?? Hahaha
Nanometer Nanometer is online now
Car: 335i, 2009
Default 01-29-2018, 05:02 PM
30 psi boost and 15 degrees of timing... wow..
335i E90 2009 ///M Sport Auto
X5 50i 2013 ///M Sport
Stock
Default 01-29-2018, 05:58 PM
Beauty of octane and direct injection... doesn't appear to knock, but may dial it back for some safety margin
Ando @ BMS's Avatar
Ando @ BMS Ando @ BMS is online now
BMS Customer Service
Car: bmw 335i
Default 01-30-2018, 01:07 PM
:Can't wait to see this car at 1/4 and 1/2 mile.
Mostly so I see other people reaction
Car: 13 M5 DCT
Default 01-30-2018, 01:23 PM
Mostly so I see other people reaction :eek
9.5 1/4 mile guestimate ?
Ando @ BMS's Avatar
Car: bmw 335i
Default 01-30-2018, 02:00 PM
Maybe lower
Default 01-30-2018, 02:57 PM
If it hooks 9.2 @ 153
else... somewhere in the 9's
else... something breaks!
135hoser 135hoser is offline
Default 02-13-2018, 07:11 PM
Best flow chart ever. I am super excited with this build. I get to live through allmotor_2000 while they build my dream f10 m5.
I can't wait to see some in car footage of you at the strip! :D
