Default JB4 B48/B58 Firmware, Settings, and Notes - 06-18-2015, 10:32 AM
This thread will be the single source of information for everything BMW B48/B58 JB4 related! Note both engines use the same hardware. The JB4 will detect the different during installation and map accordingly.
B48/B58 JB4 Install Guide: Latest Install Guide
JB4 Windows Interface: Latest Interface Download. When updating your interface you may need to first go to "add remove programs" and "remove" your previous JB4 interface. The B58 JB4 is fully compatible with JB4 Mobile and the REV2 & REV3 blue tooth adapters!
If you need directions on how to connect a laptop to your JB4 to update firmware or how to datalog Click here.
Map Guide as of v8 firmware:
Map0: Stock tuning, fully disable JB4
Map1: Additive map with peak of 3psi over stock added (91 octane)
Map2: Additive map with peak of 4psi over stock added (91-93 octane)
Map3: Additive map with peak of 6psi over stock added (93+ octane)
Map4: Stock tuning with CANbus features active
Map5: Additive map with peak of 6psi over stock added & more aggressive timing profile for higher octane fuel (experimental, 93+ octane, bolt on modifications)
Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting
Map7: WMI map (boost varies based on WMI additive and map settings)
Firmware:
BMW_B48_B58_OBDII_9:
1) Redesigned CANbus logging engine for faster sample speed and all available parameters including cyl1-6 timing, water, oil, and trans temp, full time.
2) Corrected speedo calibration issue when using in dash menu.
3) Added FutureUseD Bit4 option to disable startup sweep.
4) Added in dash timing and AFR gauges under menu 2/3 and 2/4 respectively.
5) T2 - Fixed bug with fault code reading.
6) T4 - Fixed possible bug with alarm engaging.
BMW_B48_B58_OBDII_8:
1) Adjusted map numbering per above!
2) Removed intake temperature signal adjustment from map1. Option is now available for map6 or map7 using the 6cyl timing field. 0 disables it, value of 10 increases IAT sensor readings lowering timing, value of 70 decreases IAT sensor readings increasing timing. Adjustment active on maps 6 and 7 only. Experimental feature.
3) Adjusted additive maps so they can be used without OBDII cable
BMW_B48_B58_OBDII_7:
1) Added CANflap operation to allow control of the factory exhaust flapper from the drivers seat. Press the BC button for a second to change modes. Left arrow is flapper open full time, right arrow flapper in OEM operation which is generally closed unless at full throttle.
2) Internal CANbus changes to improve speed and operation.
3) Groundwork for virtual flex fuel sensor added. See E85 FAQ below.
4) Wastegate dutycycle offset for cars with modified exhaust that experience excessive throttle closure. When equipped with an EWG connector on the JB4 harness FutureUseA can be used to apply a static negative offset. Generally a value of 30 is a good starting point.
Default Settings:
'OBDII In Dash Menu
'0 map menu, map shown on tach (tach shows Map)
'1 Active Sound MUTE. (tach = 0 OFF, tach = 1000 ON)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 60% or more and turns itself off when you resume low throttle use. (tach = 0 OFF; tach = 1 Boost Only; tach = 2000 Boost on fuel, Meth on speedo ring; tach = 3000 Boost on fuel, Timing on speedo ring; tach = 4000 Boost on fuel, AFR on speedo ring)
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (tach = 0 OFF, tach = 1000 ON)
'4 Delete Fault Codes.
'5 Dash Mode. tach = 1000, SAE; tach = 2000 Metric
'6 1st gear boost limiter. (Tach = boost cap / 3)
'7 2nd gear boost limiter. (Tach = boost cap / 3)
'8 3rd gear boost limiter. (Tach = boost cap / 3)
Copyright Notice:
JB4 Software is Copyright © 2006-2016 by Burger Motorsports Incorporated. All rights are reserved. De-compilation, disassembly, reverse-engineering, alteration, and redistribution in any form without the prior written consent of Burger Motorsports Inc. is prohibited.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 06-18-2015, 10:35 AM
Originally Posted by B48/B58 FUD settings as of v9+
*B48/B58 JB4
FUD:
bit0 - Disable in dash BC button controls
bit2 - Full time IAT spoof (for testing)
bit3 - Raise "boost over stock" cap from 10psi to 20psi.
bit4 - Disable startup sweep
bit5 - Disable CANbus when boost is less than 1.5psi
bit6 - Unused
bit7 - Force actual boost value out MAP sensor (for testing)
FutureUseA: Negative offset to dutycycle via EWG connector to correct for over boost conditions when PWM is low
FAQ
Can I run E85 with this platform?
E85 can be mixed in but with trade offs. The BMW B48/B58 platform has an internal fuel cap that causes the DME to reduce it's internal boost target as fuel volume increases above expected levels. Since E85 requires a higher fuel volume the net result is a lower boost target. While small mixtures of 10-20% can be used to increase lower octane fuels expect a little less boost when running it. If equipped with the factory PPK tuning the internal fuel limit is higher and you can effectively get away with a little heavier ethanol mixture.
What is the optional EWG harness for?
This plugs in to the JB4 connector using the same directions as the N55 EWG plug (purple in #9, blue in #16) and allows the JB4 to increase or decrease the wastegate dutycycle directly. Cars running a WMI kit may benefit with the JB4 being able to more effectively add boost. While those with certain exhaust modifications may benefit from having the JB4 reduce wastegate dutycycle to prevent boost creep and throttle closure. In most cases there is no benefit to adding in this optional connector. After attaching pins to JB4 harness plug the EWG connector itself to the factory plug on the wastegate by removing the airbox and unsnaping the heat blanket covering the EWG assembly.
What is the optional fuel pressure harness for?
This plugs in to the JB4 connector (green wire goes in #21, black wire goes in #4, fuel pressure plug attaches to fuel pressure sensor under engine cover) and allows the JB4 to both datalog high fuel pressure and also offset the fuel pressure signal back to the DME adjusting fuel trims. This sensor DOES NOT increase the DME's internal fuel limit or its tendency to reduce it's boost target as fuel volume increases. It is suggested for correcting fuel trim issues in unique situations like for a larger turbo, heavy E85 mixture experimentation, etc. In most cases there is no benefit to this optional connector.
Is WMI (water methanol injection) compatible with the B48/B58?
Yes! In addition to increasing octane WMI also supplements the fuel system allowing more boost and a richer air/fuel ratio under the DME fuel cap. Installation is the same as the F series N55. FSB blue goes to #14, FSB orange goes to #3.
Random Development Timeline:
6/18/15: Just placed an order for a Mediterranean Blue metallic BMW 340i automatic. It will have the new B58 engine which I suspect will be very similar to the N55. But we'll find out in 2-3 months! Car is being made in the South Africa factory. Hope they do a good job of it.
11/27/15: Finally showed up! Only took six months lol. Will get going on some baseline numbers and tuning next week!
11/28/15: Got a JB4 B58 Prototype up and running including full CANbus control!
12/1/15: Initial Dyno Testing: http://www.n54tech.com/forums/showthread.php?t=35355
12/15/15: Early B58 JB4 E85 Dyno Testing. Platform is not really E85 friendly at least for now: http://www.n54tech.com/forums/showthread.php?p=430180
1/8/16: Early adopter systems are available on our website: http://www.burgertuning.com/B58_JB4_...nce_tuner.html
3/3/16: BMS B58 Methanol Testing: http://www.n54tech.com/forums/showthread.php?t=37518
Peter @ Pure's Avatar
Car: F20 M135i
Default 06-18-2015, 10:39 AM
Haha always on top!
F21 M140i - currently stock
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Newguy123's Avatar
Car: 12' 135i
Default 06-18-2015, 11:52 AM
thats awesome hopefully it has some potential
12' DCT 135i
#PURETURBOS
#FUELIT
BostonShant's Avatar
BostonShant BostonShant is offline
Default 06-18-2015, 01:12 PM
That's awesome dude CONGRATS!!
I have a feeling these things are going to be pretty quick. Looked like a tubular manifold with a twin scroll. looks promising but time will tell.
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 06-18-2015, 01:22 PM
would be fun to see the tuning difference in the B58 vs N55
a fun read
http://blogs.youwheel.com/2015/06/12...linder-engine/
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: JB4 G5 w/BMS E85 Flash, quaife LSD, RB Inlets, BMS Meth, AA 6Ē IC, BMS Charge Pipe: 11.9@118mph 421hp/466tq (stock intake, stock exhaust)
Company Car: 991 GT3 RSR
Newguy123's Avatar
Car: 12' 135i
Default 06-18-2015, 03:15 PM
a fun read
That is a great read. Short and informative my favorite!
12' DCT 135i
#PURETURBOS
#FUELIT
1slowN55 1slowN55 is offline
Default 06-18-2015, 06:44 PM
If that thing makes more power than our n55 easier I'm lighting my car on fire
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 09-26-2015, 03:15 PM
+1
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
Default 06-18-2015, 08:42 PM
a fun read
Nice fine! I didn't know it was closed deck.
Seven11 Seven11 is offline
Car: 535i
Default 06-18-2015, 02:30 PM
BMS always on top of things!!!
What other options did you get?
- BMW 535i - Sport - Sport Auto - JB4 G5 ISO - DCI - BMS E85 BackEnd via MHD - 19in M6 Wheels -
- Suzuki GSX-R750 - Akrapovic Titanium Exhaust - Mirror Block-Offs - WoodCraft RearSets - Yoshimura Frame Sliders -
Default 06-18-2015, 08:40 PM
Backup camera only. I rarely get any options on the development cars.
Mike_L's Avatar
Mike_L Mike_L is online now
Anti-Social
Car: 2017 X3 xDrive35i
Default 06-18-2015, 09:00 PM
Backup camera only in case my wife needs to move it out of the driveway. I rarely get any options on the development cars.
No M-Sport to get rid of the 130mph limiter?
Mike Levy
2017 X3 xDrive35i
Default 06-19-2015, 01:10 AM
Didn't you learn your lesson with the N55 135i?
Can't wait to see it but where the heck are you going to put it?
Default 06-19-2015, 09:02 AM
lol I know. The N18 MINI and 2011 white 335i are both scheduled to be decommissioned soon. Should free up some spots.
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 06-19-2015, 06:24 AM
Just placed an order for a Mediterranean Blue metallic 340i, automatic. It will have the new B58 engine which I suspect will be very similar to the N55. But we'll find out in 2-3 months! Car is being made in the South Africa factory. Hope they do a good job of it.
*Like* on the color!
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, Wheel Lock Set, Ethanol Content Sensor - No problems up to E70 fuel mix
tke344 tke344 is offline
Car: E90 LCI N55
Default 06-19-2015, 07:39 AM
Interesting article, air to liquid intercooler and a mechanical water pump..
Venoml2k Venoml2k is offline
Car: 135i 2012
Default 08-20-2015, 07:19 PM
This caught my attention also. I'm indifferent to the intercooler, but the mechanical water pump should live longer than these electric ones.
The rear timing chain sounds like the pita.
2012 135i dct, jb4,bms cai, cp.
Z-8 Z-8 is offline
Car: 135
Default 08-30-2015, 12:52 PM
Just put a $1000 water pump in my 135i convertible at 70,000 miles. My mechanic was mildly impressed it lasted so long.
Two months ago I put a $70 water pump in my 10 year old Nissan truck at 175,000 miles - my first repair outside of three batteries, oil, and brake pads.
My 135i is pushing $30,000 in repairs in the first $70,000 miles. Worst car I've ever owned by 10x, but thanks to Terry at least it's fun!
Car: 135i 2012
Default 08-31-2015, 01:16 PM
I've only had mine for a short time. I've encountered a few issues, but so far (knocking on wood) nothing I couldn't take care of myself.
° enjoy driving it, and am looking forward to a few more upgrades. Jb4, and filter were my first, now contemplating a ********. (Noise vs power)
wgknestrick wgknestrick is offline
Car: 2011: 335Xi
Default 11-30-2015, 11:37 AM
I would be concerned about that "lack of cylinder liners" detail. I can't ever see a coating holding up over time as a cylinder liner.
Water to air IC does not make it easier to modify either. You can cold box it though for drag racing.
Like all things BMW these days, it's probably give/take.
WHITE340 WHITE340 is offline
Car: 340I
Default 01-23-2017, 08:20 PM
okay guys and girls I need help it states that 5c is out but on the first page it has 4 and 5d updates only where can I find 5c
Repo335i Repo335i is offline
Default 07-07-2017, 12:45 AM
Hi have seen the n54 problems with Jb4 and data display, is it with the B58 also the problem that there are problems? And have the problems with Jb4 +?
ridgepug ridgepug is offline
Car: 435xi
Default 11-25-2015, 12:09 AM
30k in repairs? Holy **** x 1000. How does that even happen. That's definitely the worst I've ever heard of in Bmw world. You're better off buying new and selling at 40k if that's the case
Daily Driver: F32 435xi N55: JB4, MPE, Resonator Delete
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 06-19-2015, 07:51 AM
I really like the design of the turbo manifold, almost looks like an equal length,
does it look like the exhaust side will be a 4" down-pipe?
