Stoolz Stoolz is offline
Car: 11 135i
Default Menu 4/4 - 05-26-2018, 07:18 PM
Menu 4/4
Sorry if this has already been covered elsewhere.
My tuner wants me to ditch jb4 and go standalone mhd.
I'd prefer to keep it.
Is menu 4/4 an option as a pass through for a custom flash and if so will the jb4 still run my pi and meth?
Thanks!!
Fstcars's Avatar
Fstcars Fstcars is offline
Car: M235i
Default 05-27-2018, 12:19 PM
Originally Posted by Stoolz
Menu 4/4
Thanks!!
You want to run meth trigger 4.This will make the jb4 act as methanol controller in all maps. I'm running full custom flash map 0 meth trigger 4. You might have to reach out to Terry and have him make you a custom firmware. meth trigger 4 wasn't working until he enabled it in a new firmware revision.
Default 05-27-2018, 01:53 PM
What tuner? Wedge can make you a custom JB4 BEF map, as can Trebela and other reputable tuners.
Car: 11 135i
Default 05-27-2018, 08:34 PM
Tuner is out here in Australia Bud.
I would prefer to stay jb4 mhd bef.
Locally I don't think even the PS2 cars have matched my ET or MPH at the strip so I'm pretty happy.
There seems to be a trend of guys moving to MHD standalone, I also get quite a few contact me regarding misfires which I don't want to go back to.
I was 25psi misfire free back a while.
My car is still plagued by a crazy shutdown but we think we're getting closer to solving it, hopefully its some intermittently failing 02 sensors.
All mods are removed at the moment for fault finding.
Once repaired we are going to dial her in.
Thanks for the response!!
Default 05-27-2018, 09:26 PM
Throw some logs in this thread if you need some tuning advice. You're not going to "fix" any thing by going to a more limiting tuning environment.
