Default BMS E Series N55 Intake Coupler - 05-25-2018, 11:04 AM
By popular demand we've released a new molded silicon intake coupler to replace the factory accordion pipe used with both factory and BMS intakes. The replacement is 5 layers, thicker and more rigid than stock, and most importantly longer to allow better clamping. Especially in situations where a PI spacer has been added spacing the intake over. This couple will eliminate the factory coupler collapsing under boost, popping out ruining a run, etc.
It's at the bottom of our N55 intake page.
http://www.burgertuning.com/N55_BMW_...ce_intake.html
Default 05-29-2018, 01:09 PM
Got about ten out today, lets see some feedback once you guys install it.
keyap keyap is offline
Car: N55 135i
Default 05-29-2018, 01:31 PM
Sub'd for feedback. I have issues with the OEM coupler which I'm hoping this will address
Default 05-29-2018, 03:56 PM
Big difference on our own development car! For $24 can't really complain lol
N55x1 N55x1 is offline
Car: N55 X1
Default 05-29-2018, 07:09 PM
Will this come with an E series N55 new intake purchase? How about new hose clamps?
Was thinking of just buying a new intake as my filter is looking beat even after cleaning and new oil and the maf threads have stripped out of the intake pipe.
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom kittenless exhaust, KW V1, Volk's and everything else...!
Default 05-29-2018, 08:09 PM
They are separate parts and will need to be purchase individually. You will reuse the stock hose clamps with this piece.
