hi rpm hi rpm is offline
Car: 2013 335i Xdrive Coupe
Default 1/4 mile: Kickdown vs. Manual w/AT, PS2 - 05-19-2018, 01:16 PM
Want to see what kind of time I can manage at the drag strip, but I don't really want to spend on a helmet right now. (Headroom's an issue, Stilo's are reportedly the lowest, and they're $915.) So I may only get one run.
Since I have PS2 and power is fine to 6500, I thought maybe just flooring it to kickdown might be best, but otoh my DME is stock, and logs show throttle starts to ease off right at 6500. Therefore that's where I try to shift. Iirc kickdown waits until 7000.
I'm guessing manual is faster if I get it right at 6500, but maybe not if I'm sloppy. Has someone with an upgraded turbo tried both methods?
xdrive btw, so I'm not worried about traction. I always leave DSC on and it's come on twice in 10 months. I don't seem to have launch control.
AZ-MCRacer AZ-MCRacer is offline
Car: 2013 535i (N55 F10)
Default 05-19-2018, 03:30 PM
I always manual shift around 6K, it does a better job of keeping the car where it has power. On average, the gearshift drops around 1k RPM, so the engine stays between 5-6k.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1999 e36 M3 - Future Track Car
Default 05-20-2018, 05:24 PM
Thanks. I guess that's the plan for now.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 05-21-2018, 02:38 PM
I always run manual and I shift at 6,800 in all gears. I launch the car in 2nd gear. The power you make with the gearing advantage in a lower gear should be greater than being at peak power in a higher gear. The exception to this would be the stock turbo as is falls off really hard.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Custom MHD Tune | VRSF 7in Intercooler | Performance Line D-P | Pure Inlet | Pure Stage 2 | Go Fast Bits DV+ |
2014 E84 X1 35i 13.9 @ 99MPH 293 AWHP 305 AWTQ
ER Chargepipe | BMS Intake |
Default 05-21-2018, 02:50 PM
Sounds like the Dragy is going to be something you might want then. You don't need to worry about the tech or helmet etc. Very accurate and used by many worldwide.
http://www.burgertuning.com/dragy_gp...nce_meter.html
Default 05-21-2018, 03:31 PM
Does it come with a cop radio jammer? At least a bluetooth oil slick sprayer...
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 05-21-2018, 03:33 PM
Unfortunately, no. Don't ask how I know.
Mike Levy
2017 X3 xDrive35i
Default 05-21-2018, 04:10 PM
Ahh, lol. Gotta be on a closed course next time . How are you liking it though, neat toy right?
Mike_L's Avatar
Anti-Social
Default 05-21-2018, 05:25 PM
Its fun to play with. Wish my times were better, but the dang X3 won't launch.. the throttle is dead off the line, even brake torquing.
Mike Levy
2017 X3 xDrive35i
Default 05-21-2018, 08:59 PM
Interesting, have you tried 1ft rolling to see if it's a difference?
Mike_L's Avatar
Anti-Social
Default 05-22-2018, 09:08 AM
I'm thinking its the wheels. Not easy to get 20's going. That's the one difference I would have made if I had special ordered the car, smaller wheels.
Mike Levy
2017 X3 xDrive35i
