Tyson413 Tyson413 is offline
Car: 2012 BMW 135i
Default Rail pressure psi at WOT - 05-19-2018, 08:38 AM
Hi everyone! Does anyone know what is acceptable numbers for rail pressure psi at WOT? Mine is dipping down to 1600 at WOT and I donít know if itís ok or itís bad. Thanks.
Default 05-21-2018, 06:58 AM
It should be 12 or higher in the JB4 logs or it can lead to misfires.
keyap keyap is offline
Car: N55 135i
Default 05-21-2018, 07:36 AM
On my E82, I can get away with 11 but, as Steve put, 12 is ideally what you want
