(#51)
keyap keyap is offline
Car: N55 135i
Default 07-22-2017, 10:10 AM
I'll post up my findings.
Great
Would you mind also checking/posting if there's anything else we need to be aware of from a fitment perspective Vs fitting the OEM unit?
houtan houtan is offline
Default 07-22-2017, 10:26 AM
Originally Posted by Stoolz
Yeah,
It goes in on Tuesday.
I have reflashed the latest MHD bef with the fixed torque settings and my car hasnt been misfiring anyway. Haven't really pushed it with high boost though.
Nice. You buy it used or new?
Stoolz Stoolz is offline
Car: 11 135i
Default 07-22-2017, 02:05 PM
I got a new one. I found a used one on ebay but it was ex usa so import tax etc, wasnt worth it.
Granite66 Granite66 is offline
Car: Bmw 135
Default 07-28-2017, 11:35 AM
Any updates?
Car: 11 135i
Default 07-28-2017, 06:36 PM
Originally Posted by Granite66
Any updates?
Had my car booked into a local shop, it sat there for 2 days but they freaked out and didn't do the swap. Were worried they didn't have the right tool or something.
Now the car is at my regular guy across town. (Good guy but always crazy busy)
I'll update in a week or so.
Those guys did swap my boost pressure converter which i swapped because ive had inconsistent boost and I can tell you it was the problem!
Pwm much lower and boost on target now.
Down side is my previous duty bias tuning is all wrong so I'll need to redo that.
Newguy123's Avatar
Car: 12' 135i
Default 07-28-2017, 07:23 PM
Ah lame. Boost solenoid is becoming a common thing now with the upgrade turbo n55's
12' DCT 135i
#PURETURBOS
#FUELIT
Car: 11 135i
Default 07-28-2017, 09:28 PM
How's your car going bud?
Lighting some dudes up?
Newguy123's Avatar
Car: 12' 135i
Default 07-28-2017, 11:51 PM
Car is running great no complaints! We have a couple events coming up, I'll make sure to take some video!
12' DCT 135i
#PURETURBOS
#FUELIT
Car: N55 135i
Default 07-28-2017, 11:54 PM
Hey stoolz, thanks for the update.
Am considering the flywheel too and have a couple of garage options. Both non BMW but one has all ex BMW employees whereas the other doesn't.
The ex BMW did my PS2 and the other my Diff. No problems with either however, for the flywheel swop the ex BMW is nearly double the cost of what the other was quoting.
If I do this, I was going with the cheapest but am now not so sure?
Car: 11 135i
Default 07-29-2017, 12:40 AM
I went to a local Facebook Bimmer club mechanic but
he has had no experience on our dct. I called the guys who did my clutches and they said there is nothing to it but he was still pretty spooked. Told my regular dyno guy the story and he's happy to do it . I can let you know any tricks involved ( if any ) but seems a straight forward job.
Car: Bmw 135
Default 07-29-2017, 01:14 AM
Thanks for the update. Is it a direct bolt on? Was hearing something regarding 6 and 8 bolt flywheels. How do you know which one is for your car?
Car: 11 135i
Default 07-29-2017, 02:34 AM
I'm told it's direct bolt on. My original shop we're worried about aligning clutches but that's not right.
Pretty sure all us N55 guys are 6 bolt.
Car: N55 135i
Default 07-29-2017, 07:57 AM
Thanks stoolz
Granite66 - Early N54s are 8, late are 6 and all N55s should be 6. Check on RealOEM if you want to be 100% sure
Car: Bmw 135
Default 07-29-2017, 11:04 PM
Yup my 2011 135i dct shows 6bolt flywheel on realOEM. Thanks guys
Default 07-31-2017, 10:33 AM
so who is doing this install at home? Wondering if it is doable and how much harder/easier it is than installing the turbo.
Car: 11 135i
Default 08-03-2017, 12:19 AM
Flywheel in!
Unfortunately my coolant lines to my turbo we're dead and ready to break from heat so now we are redoing those.
Installed the flywheel no dramas tho.
Default 08-03-2017, 06:57 AM
Flywheel in!
Awesome.
You install at home or shop? How long did it take?
Car: 11 135i
Default 08-03-2017, 12:43 PM
Awesome.
Was done in the shop.
It takes a day to do.
Car: Bmw 135
Default 08-03-2017, 03:18 PM
Awesome
Hope you come right with the coolant lines asap and let us know how the new flywheel holds up
Car: N55 135i
Default 08-11-2017, 11:10 AM
Hey Stoolz, how is it going with the coolant line?
Car: 11 135i
Default 08-13-2017, 02:42 AM
Coolant lines all completely replaced with better ones and better connectors.
I've been busy with my work and the shops always busy,
I'm booked in for dyno and pickup on Friday.
I'll post up any hp gains and hopefully get some good misfire curing results.
Default 08-13-2017, 11:04 AM
Couch you please elaborate which coolant lines and where you got the better lines?
Car: 11 135i
Default 08-13-2017, 12:51 PM
I'll get all the specifics on Friday.
I think they said a hose specialist visited and gave them some direction.
Welded on some new threaded connectors or something?
Car: 11 135i
Default 08-17-2017, 08:08 PM
Good and bad news.
Ran half dozen runs in map 7 for 20hp gain over old flywheel.
Logs looked absolutely fantastic.
Pushed up to 24psi for a map 6 run and hit misfires.
Pretty sure its hardware and most likely the boost pipe connection between the turbo and intercooler.
Dropped back to map 7 and misfires continued.
Car going back up on the hoist next week to check it out.
Coolant lines were replaced from the water pipe and to the head. The boys welded on threaded fittings and got rid of the push on oem ones.
Dyno dynamics map 7 read 430hp which I believe is roughly 495hp on dynojet.
Car: Bmw 135
Default 08-18-2017, 03:29 AM
Were the misfires at 24psi random misfires or pin pointed at an issue? And at what boost did you misfire before new flywheel?
