(#51)
Car: 2011 N55 135DCT
Default 09-30-2017, 03:00 PM
Just finishing off intake and exhaust in the week and then fitting HKS cooler. Then tunning. Will start off with low boost
2011 135 n55 DCT RHD, MAMBA GTX3576R (5962) single turbo kit by CCD South-Africa
Kurler Kurler is offline
Car: 2011 BMW E93 335i LCI
Default 10-24-2017, 02:53 AM
This is exciting for N55's in SA. Any updates?
Default 10-24-2017, 12:34 PM
Hi yes. Nearly done. Just small things.
Default More pics - 10-26-2017, 09:46 PM
Here are pics of the Turbo on the manifold.
Default 10-26-2017, 10:56 PM
It will be done soon
Default 10-27-2017, 12:06 AM
Is that the Jpworks bottom mount?
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 10-27-2017, 12:50 AM
I thought he got this custom built by his shop.
Mods: Stock for now
Default 10-27-2017, 04:15 AM
No its custom built by my tuning shop. Its not JP worx
JETmn JETmn is offline
Car: 2011 335xi
Default 10-27-2017, 06:35 AM
Sorry man, I don't like being "that guy" but they didn't do a very a good job on the manifold. Look how uneven it is sitting on the table and those welds are not good. Are they MIG? The flanges should have been bolted down while welding to help prevent the warping. You can see the left of the front set is up about 3/16" and the back right of the front one is up about the same, so there is almost 1/2" of twist in there.
Toome's Avatar
Toome Toome is offline
Car: 2012 BMW E92 335i M-Sport
Default 10-27-2017, 08:18 AM
Im glad Im not the only one who sees that. Maybe it will straighten out a little when bolted down? Camera angle/uneven surface could also be throwing it off.
12 E92 335i 6AT - Alpine White M-Sports Package
Mods - | JB4 ISO | BMS Pump BEF | BMS Intake | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7 FMIC | Alpina Flash | Euro Headlight Switch | Avant Garde M359 | Michelin PSS
Default 10-27-2017, 09:10 AM
Its just the angle. Another m135 has same manifold. No issues. This manifold is a masterpiece.
Default 10-27-2017, 09:11 AM
The manifold is sitting on tiles on floor. Thats not even.
Toome's Avatar
Default 10-27-2017, 09:17 AM
Ah that makes sense. I knew something was off. Cant wait to see it on the car. That turbo is gonna make some serious power.
Default 10-27-2017, 09:21 AM
Gana run 27 psi and see. But ya. I only have stage2 lpfp and meth and TBI
Stoolz Stoolz is offline
Car: 11 135i
Default 10-27-2017, 03:10 PM
Mate, is this a kit i could have sent out here to Aus and have installed fairly easily or is there a lot of modification required?
Default 10-28-2017, 09:22 AM
Hi stoolz
The kit gets custom made while car is at workshop. As water pump and ***** need to be relocated.
Default 10-29-2017, 09:43 AM
Just finished putting on the speed tech kit also a bottom mount there is a lot to fit in a very small spot. Lots of busting knuckles cutting wrenches in half an application of heat wrap. Turned out really clean though. It's no direct quick Bolton I'm sure this one won't be either good luck.
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
Lowon's Avatar
Car: Bmw M2
Default 10-29-2017, 11:00 AM
Did you drop the motor, or just the engine mount and try your best to squeeze things in?
Mods: Stock for now
Default 10-30-2017, 05:39 AM
I removed the engine mount and lifted the engine a inch or so, removed water pump and fan shroud. There was plenty of room. The biggest challenge was the water line, there is SO much going on in this section of the engine bay. I am having to do some fabrication as well due to differences in models for the one water line. I also recommend thermal wrapping of everything if you can. A EFR 7670 fits but I dont think fit is the right word. Its a engineering nightmare of dimensions. I have 2 mm off the block and 2 mm off the frame rail. lol.
Yours should fit a little better, maybe, I hope
Feel free to message me for my number of you want to bounce ideas of someone.
Lowon's Avatar
Car: Bmw M2
Default 10-30-2017, 08:07 AM
Damn those are some tight tolerances, but thanks for the offer man I'll definitely keep that in mind when I get my it I'd appreciate the help! This jobs going to be annoying lol since all my other cars escpecially the cla 45 amg have top mounted turbos that are super accessible.
Mods: Stock for now
Bimmer_Boost's Avatar
Bimmer_Boost Bimmer_Boost is online now
Car: 2011 e92 335i
Default 10-30-2017, 12:06 PM
Originally Posted by Lowon
Damn those are some tight tolerances.
I would want to install solid engine mounts if it were that close. I'm sure the engine would move that much with that much power.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Back to stock
2014 E84 X1 35i 13.9 @ 99MPH 293 AWHP 305 AWTQ
ER Chargepipe | BMS Intake |
Lowon's Avatar
Car: Bmw M2
Default 10-30-2017, 02:44 PM
Maybe speedtech has some more insight on this issue.
Mods: Stock for now
Car: 11 135i
Default 12-01-2017, 01:16 AM
How's it going Mate?
Default 12-01-2017, 08:32 AM
Yes buddy car should be done before end Dec. Will update soon
Car: 11 135i
Default 01-21-2018, 02:21 PM
This is the only rhd lt build i know of, I'm kinda excited.
