Car: 2011 N55 135DCT
Default 04-27-2017, 10:13 AM
Hahhaha ya agreed hey. Ill see what the DCT will do with the big turbo
2011 135 n55 DCT RHD, MAMBA GTX3576R (5962) single turbo kit by CCD South-Africa
Kurler Kurler is offline
Car: 2011 BMW E93 335i LCI
Default 05-03-2017, 08:11 AM
What made you go with CCD?
Default 05-03-2017, 08:27 AM
Chris does awsome work on the big turbo conversions and it was my choice to go there.
Stoolz Stoolz is offline
Car: 11 135i
Default 05-11-2017, 12:13 AM
Any updates Jacques?
Default 05-11-2017, 10:12 AM
Awaiting turbo to be shipped. As soon as its here then ill update
keyap keyap is offline
Car: N55 135i
Default 06-21-2017, 12:45 AM
Hey Jacques, how's the build going?
Any updates/pictures etc?
Default 06-21-2017, 12:48 AM
Still slow. As soon as i have pics i will put up
DB90 DB90 is offline
Car: M135i
Default 06-21-2017, 02:09 AM
Is your shop looking to release this kit to the public or is it a one off build for yourself? Interesting to see how you get on with the build being rhd and also running TBI plus stage 2lpfp as that's my current setup.
M135i 8AT / JB4 + EWG Harness / N20 TMAP / VRSF 5" HD FMIC / Fuel-It TBI / Fuel-It STG2 LPFP / Pure High Flow Inlet / FTP Charge & Boost ***** / Richter ***** / Backbox delete / E50 Fuel / ngk 5992s / BBS CH-R's / KW V3 Coilovers / M4 LCA's / GP Front Splitter & Side Blades.
100-200kph: 7.8s
1/4 mile: 11.9s @ 120mph
Default 06-21-2017, 02:24 AM
My shops busy with my car and a m135 ewg. Will keep u posted
Default Turbo arrived - 08-02-2017, 04:44 AM
Sorry guys for the late reply. Turbo arrived and the Shop has started doing the conversion. Will keep you all posted in the comming weeks.
bcaz808 bcaz808 is offline
Car: 2011 E90 335i
Default 08-02-2017, 08:53 PM
Looking forward to seeing the outcome.
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 08-09-2017, 12:18 PM
Originally Posted by JacquesN55
Hoping for 560 to 580whp
on pump or meth ? is this turbo way bigger than a ps2 ?
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
Default 08-10-2017, 08:09 AM
In e85 and meth. Im not shure if its bigger that Ps2 wheels. But it will flow way more than pure
Car: M135i
Default 09-11-2017, 12:20 PM
How's the build going Jacques?
Is CCD doing single scroll only or looking to do twin scroll manifolds too?
100-200kph: 7.8s
Default 09-12-2017, 04:19 AM
Nearly done buddy. This will be single scroll for me. Im shure they can do twin
Car: M135i
Default 09-12-2017, 06:28 AM
Great! Looking forward to your results, your power goals are similar to mine and I think the turbo choice is good for that.
This looks to be the only option for us guys for this sort of power goal.
100-200kph: 7.8s
Default 09-15-2017, 03:30 AM
Will post results as soon as its done
Default Progress - 09-26-2017, 05:05 AM
Car getting allong. Awsome work by CCD.
Car: N55 135i
Default 09-26-2017, 05:14 AM
Looking a tight squeeze. LHD or RHD?
Default 09-26-2017, 05:22 AM
RHD bud
Car: N55 135i
Default 09-26-2017, 06:30 AM
Looking good pal - impressive work for them to get that in there. The V clamp on my PS2 is almost flush with the steering!
Any ETA for the car being on the road?
Also, please keep the photos coming - the more, the better :-)
Default 09-26-2017, 06:45 AM
SUPER tight fit. I bet you had to go through the front to fit it in. WOW....
Im going a similar build also DCT but with EFR 7670. I dont think I will need to go through the front but might have to drop the subframe a little. I am hoping I dont have to do anything other than remove mount and lift up engine, but we will see.
When do you think it will be on the road? Are you going to upgrade clutch packs or just see what the flash will get you?
2012 N55 135I, Speedtech 7670, JB4 + MHD, Fuel-it port injection & stage 3 LPFP, M4 A2W IC, Mfactory LSD, KW V1, Apex EC-7
Default 09-26-2017, 09:27 AM
Well races are the 14th October so we trying to get it done before that. No im gana run stock clutch packs. I run a diffrent DCT gs40 zusub and will see what the flash will hold.
Default 09-26-2017, 09:29 AM
@keyap. Races are tge 14th October. Sothey tryingto get it done by then. Will do.
Car: 11 135i
Default 09-27-2017, 04:38 AM
I'm impressed, lookin good
