HansWurst HansWurst is offline
Car: BMW
Default 07-10-2015, 03:09 AM
Originally Posted by JacquesN55
What is SA1a1
equipmentfor Feul with carbonization tilt.
@bmg4 Thanks for this. Can You make Same with NCSExpert for the Guys here?
Thank You
Car: BMW
Default 07-10-2015, 03:12 AM
Originally Posted by subaru335i
I'm in the same boat. Need a "for dummies" summary on what to do with this info and if I will benefit.
I have a 2011 US 335i MT N55 and a Cobb Accessport running stage 1 aggressive. What would be the effect of me flashing this PPK rom?
Does it overwrite the Cobb tune? Is it better than Cobb? Can I use it with the Cobb flash on top? Will I gain anything from it?
Also, what cables will I need? INPA? BT?
Sorry for the noob questions.
You Have do Deinstall your Cobb bevor do any Flashes with Winkfp.
You Can Install the Cobb after you flash, difference is that you have better Sound!
jtomasf's Avatar
jtomasf jtomasf is offline
Car: 135i n55
Default 07-11-2015, 12:04 PM
Can it be done remotely if someone doesn't know how to do it?
013 135i E82 - JB4 G5 ISO 5.9 - BMS INTAKE - AR ** - ER FMIC - ER CP - BMS OCC - BMS OCV - BMS Meth Kit - Borla Catback - ST COILOVERS - M3 FRONT/REAR ARMS - VMR 18 V710 -
Car: BMW
Default 07-11-2015, 12:41 PM
yes
torr's Avatar
torr torr is offline
Car: 2011 335i
Default 07-12-2015, 04:07 PM
Verified, this is the BMW PPK flash and it does work. Flashed the wife's car with no problems. The increased performance and sound of the exhaust is great on the stock platform. I am considering unistalling E85 BEF to see how the exhaust sound with my ******** **. Hanswurst, thanks for the share, sweet FREE DME upgrade. Surprised more stock turbo JB4 users have not jumped on this yet.
2011 335i E92 AT, JB4, FMIC, **, CP. Pure stg2 w/high flow intake & DV+. Fuel-It! E85 BEF Flash, stg2 LPFP & PI.
Car: 2011 N55 135DCT
Default 07-13-2015, 01:00 AM
How do I return back to stock if I want to remove the PPK
Car: BMW
Default 07-13-2015, 08:15 AM
Read the AIF with Inpa and note your Zusub. after you flash the PPK you can return to OEM when you flash the Zusub you Noted before
aaaok aaaok is offline
Car: 320i
Default 07-14-2015, 02:58 AM
what the rule to find the zusub with different car ?
Technog0d Technog0d is offline
Car: 2013 BMW 335i Sport
Default 07-14-2015, 05:47 AM
Anything for the F series or is that not possible?
worries worries is offline
Car: 2013 135i
Default 07-14-2015, 01:17 PM
A little confused, what would be the zusub for 2013 e82 with DCT in US?
torr's Avatar
Car: 2011 335i
Default 07-14-2015, 07:47 PM
Sorry looks like I need to send my file to Cobb
Car: BMW
Default 07-15-2015, 06:45 AM
Originally Posted by torr
UPDATE!!!!!!!
This flash is the ppk flash but,
After flashing my wifes car with ppk, the COBB AP gives me the ROM support version problems not previously experienced.
Just wanted to give a heads up even though flash stock is possible.
if rom not supportet, you have to save it with Cobb and send it here
https://static.cobbtuning.com/suppor...om-upload.html
Car: BMW
Default 07-15-2015, 06:47 AM
Send your VIN with PM
Car: BMW
Default 07-15-2015, 06:48 AM
not yet
unnaturalaspiration unnaturalaspiration is offline
Car: 2013 Audi Allroad - soon a 335i
Default 07-15-2015, 08:38 PM
How does the PPK stack with a JB4? Do they enhance each other or does the JB4 just mask it completely?
torr's Avatar
Car: 2011 335i
Default 07-16-2015, 06:11 AM
I flashed PPK to my car last night so I need to give a day for the DME adaptation to to do their thing. The JB4 does not mask the new exhaust sound (can flap on or off). I will post up tomorrow what I experience for staked performance.
David N55 David N55 is offline
Car: BMW 335XI N55 e90 2011
Default 07-16-2015, 12:39 PM
Hi im totally interested in this im running JB4 atm but i was wondering if that PPK will upgrade the Gov to 155? I'm located in Germany i have an N55 335XI E90. Also the link for the OBD2 cable is 4 of them what should be the more appropriate for my car i know the 99$ one works but what about the others?
Default 07-16-2015, 12:57 PM
Very cool, thanks! Looking forward to hearing your results.
Car: BMW
Default 07-16-2015, 01:15 PM
please dont buy OBD Cable for more than 40
99$ is usury. Just go to ebay and you see many Cables. Just Buy an K+DCan one
Car: BMW
Default 07-16-2015, 01:20 PM
135i DCT E82 US
8651834 MVED1726
8647156 MVED17
kcbimmer335i kcbimmer335i is offline
Car: 2011 bmw 335i xdrive
Default 07-16-2015, 04:29 PM
I tried to program with Winkfp but it giving me error message. i don't think i have the up to date sp-daten for it. does anyone know where i can download the sp-daten for this? my car is a 2011 335i xdrive. i can pay for it if i have to. thanks.
M31RK M31RK is offline
Car: 135i N55
Default 07-16-2015, 05:13 PM
Anyone here in San Diego down to help me out? I don't have a cord but want to learn how to do this ****
Car: BMW
Default 07-16-2015, 08:04 PM
if some one need Help by the installation or Flashing just PM'ed me. you decide the amount of your donation if you want to donate.
U just Need Windows 7 Notebook, OBD Cable and Wireless Lan or Internet in Ur Garage.
Default 07-17-2015, 03:42 PM
error 106:
Error on setting ecu address.
Please check interface, pabd, p-sgbd
Coapi error entries:
1065 coding sequence description file(CABD)03med172IPO not found or erroneous
1000 error 03mevd172ipo
1000 error run set_ecu_address job
9910... Interpretierter fehler: Cabd-ausfuhrung:cabd 03mevd172ipo Richt gefunden.
Default 07-17-2015, 08:53 PM
it working now. thank you. but now i confuse which one is the correct zusub for my car. is it 8639130 MEVD17or 8639128 MEVD17 or 8639174 MVED17?
My car is a e90 n55 xdirve.
Originally Posted by Bmg4
You did not import your sp daten correctly. Download BMW coding tools and it will import it correctly. This thread will show you how to properly set it up once you have all the software.
http://www.e90post.com/forums/showthread.php?t=859474
