(#2076)
Default Yesterday, 09:57 AM
Originally Posted by dprada01
So in 1st and 2nd gear I have really inconsistent boost levels. From 10-15 psi sometimes. I figure itís probably the traction control cause you canít fully turn it off. Also maybe itís in my head but I noticed if you turn OFF that stupid brake assist function in the personal settings (where you pick sport steering, sport suspension etc) it doesnít interfere as much when you lose traction.
But 3rd up I usually get consistent boost levels.
Hereís a pull I did a little earlier in 5th gear. I didnít take it to redline cause I was running out of road. Mph creeps up fast on me now haha
In lower gears you also have a shorter time for boost to build up. So sometimes you just won't get up to target. Other times the DME limits boost for traction or other purposes.
Ralph091014_R400 Ralph091014_R400 is offline
Car: Infiniti Q50S Red Sport
Default Yesterday, 02:26 PM
Hey guys, planning on installing full cbe and full ********* no cats in my redsport, will there be any problem running jb4 with those upgrades.
Awgd8 Awgd8 is offline
Car: 2018 Q50 3.0t Luxe AWD
Talking Yesterday, 03:05 PM
Weíll if you know a good plastic surgeon, I donít think it will be a problem.
(That grin in your face will not become permanent.....)
Cdubber9 Cdubber9 is offline
Car: 2017 Q50 3.0T AWD
Default Yesterday, 05:25 PM
Is anyone with a Premium/Luxe pushing anything over +7? My Logs look pretty good on 93. I'm thinking about throwing in some E and going for +8-8.5. Figure if stock RS are pushing +6 its worth a try.
Any concerns?
Default Yesterday, 05:57 PM
Any concerns?
Is that data log attached on Map 6 ? (+7 psi max)
This looks like a 3rd gear pull since the boost 14+ is pretty consistent. ???
Seems like you were hitting some 18-19 psi already (AFR low 13’s) . I’ll be happy with this setup. Not sure if the E85 will lean out a bit.
How do you setup your Map 6?
Here is my current Map 6. I haven't done any data log yet.
BTW, I believe you can only go up to +8 psi on JB4.
TorchikRS TorchikRS is offline
Car: 2016 Infiniti Q50 RS400
Default Yesterday, 05:59 PM
Any concerns?
I wanna know how happy +6 RSs are
Default Yesterday, 06:07 PM
Most of them will soon need a plastic surgeon...
Default Yesterday, 06:11 PM
Seems like you were hitting some 18 psi already. I’ll be happy with this setup.
Here is my current Map 6. I haven't done and data log yet.
It was a 3rd to 4th gear pull. I don't count the 18's since they are only during upshifts. I'd say it peaks around 17, but the RS are peaking around 19.
I wouldn't say that I'm not happy, but there's always the want for more
Here's my current map 6 setting.
Default Yesterday, 06:18 PM
Thanks! I never had any chance of doing 3rd gear pull on my +7 (Map 6) setup yet. Iíll report back soon.
Iíll be happy to get a consistent 15-17 PSI on lower gear beside 3rd. I think the ECU really limits higher boost on lower gear..
Infiniti Addict Infiniti Addict is offline
Car: 2016 RS400 AWD
Default Yesterday, 06:32 PM
Originally Posted by RedSport88
I am on 93 as well at +4.5PSI with q60 red sport. Never had any issues with it and the car pulls like a beast. I did a run 2 nights ago with the temp in the high 20s. I took her all the way up to 155 then hit the gov limiter and car lost power due to computer cutting off the gas (It was a curvy road in a school zone) The first time it pulled great and smooth all the way through. The car deff had alot more juice and my guess with jb1 +4 PSI hitting 175mph would be no problem(without limiter). On the second run Some knocking came in at around 115-120 mph (like a hesitation). I feel like the +4.5 is pushing it on just 93. I logged it but my jb4 software crashed when I went to hit stop logging so have no data. How long have you been running with +4.7? and have you taken past 100MPH?
I have put a couple thousand miles on at +4.7 with no issues. I have taken it up to 120mph a few times and it is smooth all the way up.
Car: 2016 RS400 AWD
Default Yesterday, 06:36 PM
[QUOTE=pdqgp;575412]Has anyone here been to the track with their jb1? Curious as to how much it's helped.[/QUOTE
My Q50RS400 AWD with JB1 runs 12.2@115
Default Yesterday, 08:04 PM
[QUOTE=Infiniti Addict;575513]
Stock?
Default Today, 02:47 AM
Would you guys mind posting your map6 setup on +4.7?
