(#1501)
Matta Matta is offline
Car: 320i 2013
Default 10-27-2017, 09:30 AM
Originally Posted by Msportmadness
I have a 328i ewg, i was told the n20/n26 even with e85 dont have the same kick as the n54's in map 5. To stick with map 2
Map 5 is made for 320i, the problem is not that power is to low, is that the power is uneven.
Msportmadness's Avatar
Msportmadness Msportmadness is offline
Car: 2014 328i
Default 10-27-2017, 09:37 AM
That's true.
Default 10-27-2017, 10:04 AM
Hi
I have a 2013 320i ewg with jb4 running map5, i feel that the power is a bit uneven, hesetates a bit some times. Power delivery is perfect smood when running stock, but not with jb4 map5.
Anyone experienced the same?
If you need tuning help post a JB4 log of your specific issue and we can help you with it.
Car: B46 F56S
Default 10-30-2017, 06:01 PM
I have the jb4 with the flex wires connected, i just mixed 4 gallons of e85 and the rest 93oct a few days ago and you feel the difference right away. I uploaded logs and terry looked at them and said everything was fine but my flex wires weren't installed. I just noticed i didn't have them installed 2 days ago. I'll have to do another log and post them just to make sure.
4 gallons? Car feels ok? Are flex fuel wires required? When I had my JB4 on my B48, it was only needed to manually modify fuel trims. Ill try out 2 gallons for now on my N20.
Car: 2014 328i
Default 10-30-2017, 06:08 PM
The 4 gallons was actually a mistake i ment to add 2 but the gas handle got tuck so i ended up adding 3.7 gallons.
I'm a little more than half way through the gas tank and i have to say that i love it. The throttle response feels faster, and inside the cabin the car sounds deeper.
I've noticed the car does feels a little rougher than usual when cold, last around 2 -3 min.
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 10-31-2017, 10:29 PM
Hello BIGBOYQ,
I also got a E89 Z4. Have you upgraded the firmware? Do you notice any peformance difference?
Originally Posted by BIGBOYQ
I have noticed that there is an new file, or is it just an rename.
I have the following files, are they identical or different
N20_X1_STAGE2_1.hex
N20_X1_JB4.hex
JB4_N20_X1_Z4.hex
Update appreciated
Car: 2013 Z4 20i
Default 10-31-2017, 10:39 PM
Hello Terry,
Looks like that there's new firmware update for X1/Z4 with file name N20_JB4_X1_Z4_2.hex. My JB4 was installed in 2013 with firmware name N20_X1_JB4.hex. Is it worth upgrading the firmware?
Your input is highly appreciated. Thanks!
The latest file is in the first post but there are no significant X1 firmware changes.
phoebee phoebee is offline
Car: 428i
Default 11-02-2017, 08:16 PM
2014+ f32, 428i
Can I on/off Active Sound on jb4mobile?
If it is only on/off on dashmenu, can I on/off on dashmenu with bluetooth connected?
F32 / 428i / 2014+ewg / N26 / 93octane / all stocks / JB4mobile rev.3 on iPhone
Mid_Night_F20 Mid_Night_F20 is offline
Car: Bmw 125i F20
Default Poor dyno results - 11-05-2017, 03:52 AM
Hi guys,
Just had my 125i F20 (n20 motor) on the dyno today with very poor results.
Mods: 3" ******* turboback exhaust, wagner intercooler with metal piping, jb4 map 2, 100RON fuel
I attach the chart....
Can anyone explain this terrible chart?
Car: 2014 328i
Default 11-05-2017, 05:54 AM
Originally Posted by Mid_Night_F20
Hi guys,
You should contact Terry directly just for the peace of mind. Best of luck mate hope if nothing major.
Herc Herc is offline
Car: F20 125i
Default 11-05-2017, 07:49 AM
Hello mid night
Am been getting the same rather disappointed logs in contrast with the 20i or 28i that i seen. The only guess is that jb4 is not suitable for our motor versions...... A log would had helped though.....
Phoebee no only via the dash control
Car: Bmw 125i F20
Default Power Loss - HELP needed - 11-09-2017, 03:31 AM
Hi guys,
Suffering a major power loss on my N20 motor today.... AFR's hit about 17/18 on low rpm with a lightly pressed gas pedal.
I attach some logs
Is it a failing HPFP ?
Can anyone please advise?
thanks
SlowMo SlowMo is offline
Car: N20
Default 11-09-2017, 03:38 AM
most people will experience a 'major power loss' when they run on map 0 and partial throttle...
Car: Bmw 125i F20
Default 11-09-2017, 03:52 AM
i changed from map 2 to map 0 so I don't blow the engine as I make my way home !
Car: 2014 328i
Default 11-09-2017, 04:56 AM
I just have mine on map 1. If i find another crazy head like myself i just open the phone app and put it on map2 to have some fun. Then is back to map 1
Car: F20 125i
Default 11-09-2017, 07:52 AM
nobody can really pin point the main reason. Thats a mechanics job to be fair.
Car: Bmw 125i F20
Default 11-10-2017, 08:02 AM
definitely not a boost leak, the car has ok power again compared to what happened the other day but the high AFR's concern me and I suspect a failing fuel pump?
AFR's momentarily hit 20 around 2000 rpm then get better but not as low as they should ?
