vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default Rear camber lockdown kits available for E and F chassis $135 + s/h - 08-10-2017, 12:55 PM
When the suspension is modified (firm dampers, stiff springs, solid RSFB) and matched with sticky tires the eccentric bolts become a weak point. You hit a pothole? You go off track? You do a lot of hard launches? Guess what? You alignment will get off! The stock eccentric bolts for small camber adjustments tend to slip under high cornering loads, causing changes to the rear alignment. My rear camber lockdown kit eliminate the stock eccentric bolts to keep your rear alignment where you set it. These lockdown plates will ensures zero change in alignment even in the toughest driving conditions. The plates are CNC machined from stainless steel and supplied with CAD plated grade 10.9 hardware for absolutely zero-slip. Bolts are M14x2x100 with self-locking nut. The shims are installed with the U shape pointing down and can be used in either face up or face down position that will yield a total of 9 possible fixed camber settings because the plates are cut into 1mm increments. Please note that these plates won't allow for more negative camber than what BMW designed the rear end for. Compatible with all M and none M E-chassis and F-chassis.
vwetish's Avatar
Default 08-10-2017, 12:57 PM
Example of slid eccentric bolt and the result from it.
quick99si quick99si is offline
Default 08-12-2017, 09:43 PM
Awesome seller
VRSF ** | VRSF 7" FMIC | ER CP | HKS BOV | BMS DCI | BMS OCC | JB4 G5 | CM10 | Alpina B3 Trans Flash
vwetish's Avatar
Default 08-18-2017, 06:20 AM
I'm ready to start on new orders.
vwetish's Avatar
Default 09-14-2017, 02:39 PM
New sets ready!
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-19-2017, 01:16 PM
Do you get all the spacer plates in the picture above and how do you know which one you'll need to use? I'm assuming the mechanic will drop the correct one in while doing the alignment?
VTT Stage 2+ | JB4 G5 w/ Trebila BEF | Fuel-It Stage 3 | XHP Stage 3 | VTT Inlets | MMP Outlets | BMS Meth Dual 10/5CM | VRSF 7" FMIC | VRSF **'s | BMS CP | BMS DCI | Turbosmart Dual Port | 3.5 TMAP | BMS OCC | VTT PVC | BMS Anti-Lag | NGK 5992 | M3 Rear Upper Controls And Godspeed TB's | Lock-Down Brace | 235/285-18 PSS
vwetish's Avatar
Default 09-19-2017, 01:34 PM
Total of 10 per side (2 sets of 5 shims with different offsets) that can be used in either the normal orientation, or flipped, resulting in 9 different positions, divided into 1mm increments. Mechanic will select the appropriate combo depending on the rear comber desired.
