Copietro Copietro is offline
Car: M135
Default Turbo lag and after oill Catch can and cp install - 06-03-2018, 02:34 PM
Good night!
I recently bought a 1M, 25k miles, and the cp was broken and fixed with a tube and bracelets.
The car was running very good, without any lag with the M button on, and rising the power until 6,5k rpm.
No codes on the dme when bought.
I installed a burger OCC and a chargepipe with the tial bov, to prevent issues and allowing space for more power if I decided to, and install the CDV too.
After that, the car presented a 1 second lag, than it makes some good power.
Tried to go Back to the stock CP, still same sintoms, but now I have a LPFP problem plausibility in the dme. No service lights on the painel.
I didnít tried to remove the OCC to se if thatís the problem because everything is correctly installed, but can de OCC cause turbo lag?
My question is, does a weak LPFP could cause those problems???
Last question, tial suggest to use a 1/4Ē vacuum line, using the stock vacuum line can cause what kind of sintoms?
I canít log because Iím not running jb4 or other tunning yet.
Thank you for the help.
Default 06-04-2018, 01:57 PM
Did you make sure to pull the O ring from the stock chargepipe to new one?
Car: M135
Default 06-04-2018, 04:59 PM
Yes, I bought a new one, and make shure to put the o ring in the bov too.
Does the OCC can make lag? Or a weak LPFP?
JB4 - ER ** -ER Chargepipe
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 06-04-2018, 07:17 PM
Sounds like a major boost leak to me.
You can diagnose this by datalogging. If boost is below target, and the WGDC is pinned at maximum then you've got yourself a leak.
You can then find the leak by pressure testing and listen for the leak, or use soapy water and look for bubbles.
Car: M135
Default 06-04-2018, 09:07 PM
Thank you, like the idea of the soapy water!!
