(#1276)
JBoe JBoe is offline
Car: M240i
Default 06-17-2018, 08:18 PM
Hello Payam and/or Terry. I posted my map 1 logs here: http://www.n54tech.com/forums/showthread.php?t=53725
Probably best to use third pull. If you could, please check them out and let me know what you think.
tZe tZe is offline
Car: F32 440i
Default Yesterday, 08:29 PM
I have a weird bug with v9 on F32 440 B58 -- the green indicator on the shifter is not working. When the car starts, the P light is on but once I shift out of P, the green indicator light goes out and stays off. Can someone with the v9 have a look and see if this occurs on yours?
No other issues otherwise. Great product. Have emailed Terry but just wanted to see if anyone else has this issue
Default Yesterday, 09:05 PM
Don't see anything in the JB4 code that could be related to that...Might be normal stock behavior. Let's see if anyone else reports any issue.
tZe tZe is offline
Car: F32 440i
Default Yesterday, 09:10 PM
I am quite sure it wasn't there prior to the JB4 install so it shouldn't be stock behavior. Small issue - as you said, let's see of anyone else reports an issue.
Could the install have caused this or a loose connection?
Thanks for the fast reply!
