WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default Pure Stage 2 Turbo Install & Review - Its Happening ! - 02-10-2018, 12:43 AM
Good Morning Guys
i am Buying the pure Stage 2
1)What are the Gaskets and Fluides that i will need to change during the install ?
2)Any Important install Tips ?
Update:
-Ordered Items from pure:
N55 Stage 2 turbo
DV+
N55 Install kit
-And Since Pure Dont Have F10 Inlets, i Ordered Custom Hi-Flow inlet from : AZ-MCRacer ( He's full of experience and owns a great modified F10)
-The Inlet is on its way & now The only thing left is i am Waiting for Peter@Pure to Ship the Turbo, Shout-out to peter so he can make it happen faster.
-Will Be Installing Stage 2 LPFP from Fuel-IT
-Just Confirmed with the workshop that will make the install:
It will take 2 Full Days & he told me he will take the engine down , perform the install , and put it back in. He Says This way it will be a clean install as we can check that we installed everything and tightened all the connections & check if anything else needs to be changed or fixed in the way & check for leaks.
-I am already on a Tuned BEF with TREBILA for my build & I will be Further Tuning The BEF with TREBILA after installing the Turbo to hit more boost targets with better timing.
-I am thrilled to receive the PS2 and install it and Test it, will update my Review & share my experience with the forum.
-I Have Never Dyno'd my Car
-No EXX Fuel and No Meth : Will only be Using (98RON/93OCT)
-My Car : 2011 F10 535i N55 PWG AT | JB4 ISO - BT.Rv3 | TREBILA BEF Tune | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler |
-Coming Soon: | Pure Stage 2 Turbo | Custom High Flow Inlet | GFB DV+ | Fuel-It Stage 2 LPFP | N20 3.5bar TMAP Sensor
-Pic Of the Car :
https://i.imgur.com/iR4wm3I.jpg
https://i.imgur.com/34R420u.jpg
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-10-2018, 02:59 AM
1. Pure's installation kit makes it easy but you can piece it together cheaper. Replacing the waterpump and thermostat are common during the install. If you change it out you will need coolant.
2. There are a few tips. Search Pure stage 2 installation on E90post and you can see what happened during my install and what people gave me for tips.
2011 E92 335i Auto
12.0 @ 125MPH JB4
12.6 @ 112MPH 92 Octane | 11.7 @ 120MPH E30 MHD
Back to stock
2014 E84 X1 35i 13.9 @ 99MPH 293 AWHP 305 AWTQ
ER Chargepipe | BMS Intake |
Default 02-10-2018, 03:08 AM
What will be inside the installation kit ?
Default 02-10-2018, 07:01 AM
Originally Posted by cnm135i
Dudee...come on...
Haha Thanks
705's Avatar
705 705 is offline
Car: E90
Default 02-10-2018, 10:31 AM
please make a diy to help others out
bcaz808 bcaz808 is offline
Car: 2011 E90 335i
Default 02-10-2018, 11:13 AM
There's already a DIY, in the DIY section.
orteeze orteeze is online now
Car: 08' 335i
Default 02-10-2018, 12:14 PM
There are tons of DIY out there. Here's a good one..
http://www.1addicts.com/forums/showt...5#post21975605
1. Remove the turbo with top oil and coolant lines attached.
2. Buy new coolant return lines (just in case)
3. Buy an o-ring pick to get the old exhaust gaskets out
4. Buy an cordless ratchet
5. Get two of your best homies to help.
6. Stretch out the install to at least 2 days. Don't get in a hurry.
7. Buy the inlet from Pure
Enjoy!
E90 LCI M Sport
705's Avatar
705 705 is offline
Car: E90
Default 02-10-2018, 12:19 PM
Particularly for F-series or F10 PS2 DIY
Default 02-13-2018, 01:39 AM
Hey Guys,
I Just Ordered my PS2 through peter@pureturbos He is a really helpful and great in Customer service.
I've Ordered:
PS2 + Diverter Valve Upgrade + Installation Kit
I will be Further Tuning The BEF with TREBILA after installing the Turbo to hit more bost targets.
Car: 2011 e92 335i
Default 02-13-2018, 11:38 AM
Originally Posted by WaqasRiyami
Hey Guys,
I've Ordered:
You should also pick up the turbo inlet pipe.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
Default 02-13-2018, 12:03 PM
I wanted to, but they dont make it for the F10 535i only for the 135 & 335, i dont know why is that ? Is the F10 not restrictive as the rest or is there no demand for F10 inlet ??
Car: 2011 e92 335i
Default 02-13-2018, 12:11 PM
They have said before that they don't want to be in the business of making inlet ***** and if another manufacturer made inlet ***** they would discontinue theirs. If it doesn't fit then my guess is there wasn't a high enough demand for them. I would look into other options though as you're most likely leaving power on the table.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
Default 02-13-2018, 12:15 PM
I tried to look for other options, no one is making inlet's for F10's
Default 02-13-2018, 12:41 PM
Do you know if any brand are making inlets for F10 535i ?
Car: 2011 e92 335i
Default 02-13-2018, 12:44 PM
By other options I mean find a shop that will fab one up for you. No I don't think anyone else makes this pipe.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
Peter @ Pure's Avatar
Car: F20 M135i
Default 02-13-2018, 01:39 PM
If you are running pump fuel and goal is 450 whp then stock inlet is ok. If your goal is 500+ then inlet upgrade required.
F21 M140i - currently stock
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: 2013 535i (N55 F10)
Default 02-13-2018, 06:05 PM
I have inlets available for the 535i, and with a Pure Stage 2, you will exceed the maximum the stock intake can handle.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1999 e36 M3 - Future Track Car
Car: 2011 e92 335i
Default 02-13-2018, 06:23 PM
Hell yes! Very cool! I understand what Peter is saying and you don't NEED it. You will still be leaving power on the table though and you should pick one up.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
Default 02-13-2018, 06:59 PM
Correct, and I think you hit the number on the head at 450HP. Without the inlet I was just under it. I will be dyno'ing again very soon and will have updated numbers with the new inlet. I can say the logs don't lie and and it seems the bottleneck is gone with the new inlet.
Default 02-13-2018, 11:04 PM
Do you have them for sale ? I want one if you do
Car: F20 M135i
Default 02-13-2018, 11:05 PM
When we beta tested ps2 there was no inlet upgrade. With stock inlet the turbo has to work harder to suck in air. Obviously an upgrade is recommended. But around 450 is np on stock inlet. We made around 500-520 on stock inlet.
But i always recommend to put one. Nice to see someone made a 535 inlet!
peter@pureturbos.eu
pureturbos.eu
Default 02-13-2018, 11:27 PM
I have 5 available to ship right now. Price for the inlet is $495 shipped within the continental US. I understand it is a fairly expensive price, but when I was investigating having them made I would have been around $800 to have it done as a one off.
Default 02-14-2018, 12:05 AM
Way too Expensive for my Budget
Default 02-15-2018, 03:26 PM
Will i be needing N20 3.5 bar Tmap sensor after installing the PS2 ??
Car: 2011 e92 335i
Default 02-15-2018, 04:50 PM
If you want to run over 20psi then yes, otherwise no.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Back to stock
