nsb335 nsb335 is offline
Car: e92 335i
Default SMOKING OUT OF OIL CAP - 02-13-2018, 06:54 PM
Guys I need help, my 335i has already gone they a pair of new bmw turbos trying to chase this. I replaced the turbos and my car is still smoking out the exhaust. And this is what I feel is the issue. Any help would be much appreciated.
https://youtu.be/WaNY3N3MPzQ
EuroDouche EuroDouche is offline
Car: 08' 135i
Default 02-13-2018, 07:58 PM
Did you check valve stems seals? If they're leaking could be the cause.
Car: 08 535i
Default 02-14-2018, 07:37 AM
First things first.....any codes?
Now.....
When was your pcv changed?
When was your last walnut blasting service?
Any oil in the coolant or vise versa?
My guess is pcv or valve cover. I would also recommend a low side external pcv. You can get this at rbturbo.com
Car: e92 335i
Default 02-14-2018, 07:48 AM
I have replaced my pcv with a rb one! And last walnut blasting was 15k ago
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 02-14-2018, 07:59 AM
May want to do a compression and/or leak down test to confirm the engine is healthy.
FEDE/E92 FEDE/E92 is offline
Default 02-14-2018, 02:15 PM
Can something like this be caused by clogged up VC internally or maybe the block itself, passages to the VC/PcV?
Are there oil in your plugs?
Car: 08 535i
Default 02-14-2018, 07:57 PM
eligard eligard is offline
Default 02-14-2018, 08:17 PM
I would start with compression test either.
